Question about Mitel Lands Phones
Working on a Mitel SX50... can receive calls fine but can not call out... get dial tone but goes busy as soon as start dialing
5 Suggested Answers
  • 84 Answers
SOURCE: telephone connection problem with DSL
unplug everthing from all jacks in the house. call your # a couple of times. if the line rings, plug everything in 1 at a time, but call again after each hook up. if the line goes dead or is busy, that phone you just plugged in is the problem. [ a short in the phone, computer, answer machine, or any piece of equipment plugged into the phone line.] if the line is busy when everything is unplugged, call your phone company. there maybe a problem with your inside wire.there also maybe a box [called a nid] inside your basment/garage or on the side of your house, where you can plug your phone directly in, bypassing all the jacks in your house
hope this helps.
wg
Posted on Feb 13, 2008
SOURCE: Mitel SX50 Equipment Busy Problem
Press "function", then 32. This will clear all alarms and error codes.
Posted on May 31, 2009
FreeTech
  • 426 Answers
SOURCE: Mitel SX50 busy signal
sounds like ur pstn gateway is the cause check all connections and make sure that the sytem is completely unpowered then plug in restart and test a local call, leave line open and see what it does
Posted on Jul 11, 2009
carlsbiz
  • 1124 Answers
SOURCE: Can receive calls but cannot dial out on Verizon landline phone
Try punching in the number to call first THEN hit talk.. It should dial and call at that point..
Just like when making a call from your cell phn - dial the # first..
good luck ;o)
Posted on Sep 17, 2009
How can i fix lock on mitel sx50 console ?
Lock? Can you elaborate? I hope you've gotten this resolved already.
Mark
Jan 12, 2011 | Mitel 9104-001-000 Power Supply SX-50...
I HAVE MITEL SX50 AND THERS ONE EXT THAT IT SHOWS LOCK WHEN I TRY CALLING IT & THAT EXT DON'T HAVE DIAL TONE EITHER. HOW CAN I FIX IT?
The phone is either off hook or the line is shorted out somehow. If it's shorted out, it's likely a jack and you should replace it. I suggest you contact your vendor for assistance.
Aug 04, 2010 | Mitel 9104-001-000 Power Supply SX-50...
The extension is shorted somehow - likely corrosion on the jack. Replace the jack and see if that corrects it.
If it doesn't, contact your vendor for assistance.
Jun 15, 2010 | Mitel 9104-001-000 Power Supply SX-50...
Mitel 5212 no dial tone and goes straight to voicemail
Not too sure about the no dial tone issue, but you can check to see if the DND is turned on...
Press the Blue Superkey and scroll thru till you see DND (Do Not Disturb) is on and shut it off.
Jul 20, 2009 | Mitel 5212 IP Phone
Jul 10, 2009 | Uniden 5.8GHz Cordless Phone
Apr 06, 2009 | Uniden 5.8GHz Cordless Phone
Cannot receive calls and dial tone flashing
You have a feature active on your phone it's more than likely a call forward feature which would redirect you calls. The broken dial tone or stutter dial tone is an indicator a feature is active. Contact you system admin for the clear all feature code and the clear all call forwarding codes.
Feb 26, 2009 | Mitel 5220 IP Phone
No dial tone
The feature you are looking for is called "prime line" or "Line preference" but not "ringing line preference". It is not usually on by default on a multi-line business phone system. Your system can do this but I suspect it's a system programming feature and not something you can set yourself. You would have to have the phone system administrator make the change. Or you may pay an installation company to make programming changes?
Jun 01, 2007 | Mitel Superset 4015 Corded Phone
Lands Phones Logo
43 people viewed this question
Top Mitel Lands Phones Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
