Question about Dell Inspiron 1501 Notebook
My dell inspiron 1501 power supply green led on until you plug into laptop. voltage shuts off instantly when plugged into laptop.
  • 3,940 Answers
Most likely the motherboard is bad. About $100 or so on Ebay
Posted on Oct 07, 2009
I have a dell inspiron 570 when I turn on the dell it starts to power up then shuts down with in 3 to 5 sec , but when I wiggle the power supply plug to the mother board it trys to power up again only to...
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 28, 2013 | Computers & Internet
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Dell inspiron 1501 wont trun on
There are a couple of things you should try:
Try booting with the battery out, check the power supply does it have a solid green led?
Remove both memory chips and try booting with just a single chip.
Any noises, led blinking, etc?
The more info you give me the quicker I can help.
May 25, 2010 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 won't turn on. When charger is plugged in the green light turns off once it's plugged into the laptop
Power supply problem or power supply connector problem. I can take a look at it for you if you want.
Jan 04, 2010 | Dell Inspiron 1501 Notebook
Green light on ac charger goes out when i plug it in to lap top
This indicates a short in the computer or power supply. The power supply senses the problem and shuts itself off. Does the laptop run at all? More info. is needed to correctly solve your problem. Send me a message and I will help you out. Phil
Dec 09, 2009 | Dell Inspiron 1501 Notebook
DELL 1501 INSPIRON THAT SHUT DOWN AND WANT POWER UP
Short or broken lil jack on the mother board. Needs a professional to look at it.
Oct 11, 2009 | Dell Inspiron 1501 Notebook
Inspiron 1520 Power Fault?
dead motherboard, highly likely to be fine if the battery is full
Aug 01, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
220 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
