Question about Canon Pixma iP2600 Photo InkJet Printer
I dont know how to refill my canon ip2600 ink cartridge
  • 3 Answers
Problem is resetting the IC chip that they install that calculates that your cartridge is empty, Refilling it doesn't work because the chip tells the printer that it'S empty. No way to reset it yet.
Posted on Dec 10, 2009
  • 117 Answers
Yes yoyr printer cartridge refilling
Posted on Oct 07, 2009
Canon pixma ip2600 cartridge not installed properly
Please check if there is not some dirt, or something blocking the contacts from reading. Also the ink level is measured by optical sensor that can also be dirty. Also make sure you use an Original Canon cartridge. It could be the chip on the cartridge has either gone bad or could no longer be reset. The chip is what tells the printer that it is ok to print (i.e. there is ink available and that the cartridge is approved). Some chips will only be reset with available procedures a few times. Other times refillers are not succesful in resetting the chip or just give you another cartridge that is already refilled and could just happen to have a bad chip. You should probably return the cartridge and try to get one that will work based on the argument that refilling is not only related to ink but also to chip. Otherwise here is a web site that has a special page for your Pixma that contains all possible refill products: http://www.inkfilling.com/inkjet-refill-... Source(s): http://www.tonerguru.com
Aug 07, 2012 | Canon Pixma iP2600 Photo InkJet Printer
I have a canon iP2600 and just bought new ink...but only replaced the black one and recycle the colored one and now there is an eror and I cant print
canon has installed a chip that recognize tampered/refilled cartridges. use new and original ink for the colored cartridges. hope this helps ;-)
Feb 04, 2011 | Canon Office Equipment & Supplies
I have the ip2600 and i just put 2 new ink cartridges in it but it is not recognizing that they are refilled and is stating that they are low and it will not print. My old printer would ask if they have...
Hi
Is there an ink resetter in your printer, reset the ink to dectect to detect the ink cartridge.
If not clean the chipset of the ink cartridge by using cloth will alcohol or warm water.
Also turn off your printer for 5 mins and put again the cartridge.
I hope it helps you.
Jan 13, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Please how can i refill a canon printer's cartridge (canon pixma ip2600), without the ink pouring out through the other end
Place the empty PG-30 cartridge on a layer of paper towels on a flat surface.
Use the thumb screwdriver to enlarge the small refill hole just below the letter "B" on the top of the cartridge.
Fill the syringe with 20 ml. of black printer ink.
Slowly insert the syringe into the refill hole that you drilled and release the contents of the syringe.
5
Allow the cartridge to sit upright for 4 hours before inserting into the printer.
Easy!
~KenjiFox
Jan 07, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Changing ink cartridges
If you have put in genuine Canon cartridges, contact Canon support for advice.
If you have refilled in any other way, your printer cannot detect ink levels. If you have used a refill kit, you might have problems if you return your printer for repair under warranty as evidence of refilling is the first thing checked for
Apr 09, 2010 | Canon Pixma iP2600 Photo InkJet Printer
My canon pixma ip2600 won't read the refilled ink cartrige i installed. I have tried to reset the printer, but it did not work.
You can't reset the printer for a defective cartridge, you either need a new chip or a chip ressetter to reset the cartridge.
Jan 25, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Ink cartridge refill
You can't refill these cartridges yourself. Sure you can get ink and inject it in, but your printer remembers the serial number of each cartridge and how many pages you've printed with it. Because it remembers this information it turns off the cartridge electronics to prevent the use of refills. I would try to get refills for the black but not the color cartridge. I own a Cartridge World ink refilling store and we have a high return rate on the color cartridges. It seems the printers are extremely finicky about color refills. If you get a black refill and your printer won't print with it, exchange it for another one because you happened to get a cartridge with the same serial number as the last one you had. I recommend Cartridge World refills, then Office Depot brand refills.
Nov 19, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Canon ip2600 reset problem, when i change the cartridge sin my printer the ink levels dont reset and it stops printing can any one help me with how to reset the ink levels please
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On most printers this happen with push resume button and hold it for 5 seconds.
The printer shows empty cartridges but it will printing.
Oct 19, 2009 | Canon Pixma iP2600 Photo InkJet Printer
How do I insert the refill ink cartridge?
according to all information i can find you have got the correct cartridges
nip to canon.com and download the user guide that shows you how yo install your cartriges
Regards AL "alstech"
May 25, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Canon Pixma iP2600 Photo InkJet Printer Logo
833 people viewed this question
old marine
old marine
