Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
My cmm1000 type 4 lawnmower does not start
When plugged in to charge, green light stays on but charger needle stays at empty. Anyone know what may be wrong?
Check to see that the starter cable isn't pushed in or out a bit too far and causing the kill switch to engage. It is only held in place by tie wraps and can cause the machine to act as if it can't be charged and/or won't run. Once the cable has been adjusted into the correct position, everything works as expected.
Posted on Oct 15, 2009
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
When the charger is left plugged into the electrical outlet, will it automatically turn off when fully charged?
when the battery is fuly charged if im not mistaken the green light will still stay on but will not be charging the battery anymore. All the light is doing is indicating that the battery is fully charged. It is not recommended that you leave the battery sitting on the charger for long periods of time since batteries an get a memory from a charger and then you might start having some battery issues. Hope this helps.
Dec 10, 2010 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Battery won't charge on my ryobi 14.4v cordless drill yellow and green lights stay on
I had the same problem and found a solution on another forum...
Plug the battery into the charger. The yellow and green lights come on. Leave the battery plugged into the charger. Plug and unplug the charger power cord from it's power source a few times until the the red charger light comes on..... problem solved!
I think the "smart" circuit in the charger that is supposed to trickle charge before the regular charge cycle needs at least some battery power to test and start the cycle. If the battery is totally discharged, the test can't deternine the battery status and will not charge.... Plugging and unplugging the charger seems to bypass this teat and charge the battery normally. The charging process should work normally after this method.
Oct 22, 2009 | Drills
Black & Decker CMM1000 Cordless Mulcing Mower Won't Start
The gauge is only active when the mower is running! (See page 6 of the INSTRUCTION MANUAL)
Sep 12, 2009 | Black & Decker 19" Electric Lawnhog...
Not Charging.
I have the same problem with my CMM1000. We replaced the batteries but the problem persists. Does anyone have an idea of what the problem could be?
Sep 03, 2009 | Black & Decker 19" Electric Lawnhog...
Kenko
read the owners hand book
normally the lights stay red until the battery is charged then it goes green
if the power is cut or if you switch the point off with the charger still in it and do not remove the charged battery , the battery will discharge through the charger
Mar 27, 2017 | Kenko MC-4 DG for Nikon AF 2x (MC4AFNDG)...
Apple ipod not getting charged
What type of IPod is this? Also what type of charger are you using? If the ipod does not have a charge at all you will need to plug it into a wall charger for it to get a "Base charge" (this usually takes 5-10 minutes) as if the ipod is totally dead then there is not enough of a charge for the ipod to let your computer know it is there to start being charged. After it has the base charge you can use the usb connection to finish the charge or leave it plugged into the wall charger to finish getting the charge.
May 08, 2008 | Apple iPod MA446LL/A MP3 Player
Lawnmower Model CMM1000 Batterys will not charge.
All of a sudden mine also acted like it wouldn't take a charge and the needle wouldn't move. The plastic safety key also wouldn't insert smoothly as it used to and I would have to push the start lever before it would drop in. When I checked the charger, it was putting out 24v. When I opened up the lid I noticed that the starter cable was pushing the safety switch incorrectly. If it was moved a bit, the mower would then start. The starter cable is only secured to the handle by tie wraps. So if it gets moved around, it can cause the kill switch to be in the kill position. So now if I have a problem, I just move the cable in or out a bit. Fortunately, this find saved me a trip to the dealer and who knows how much $$$$.
Apr 21, 2008 | Black & Decker 19" Electric Lawnhog...
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
228 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
