Question about Redfield Optics
How to use accutrac 2x7 redfeild scope , there are lines above the crosshairs and a yardage graph on the bottom of the crosshairs, how exactly do i use this scope
Looking for instructions on the use of an Acu-trac rifle scope by Redfield. There are lines above the crosshairs and a yardage graph on the bottom of the crosshairs.
Posted on Oct 19, 2009
  • baxteraddis Nov 22, 2010
    When you see your target, adjust your variable range until the top cross hair lay on the back of the deer and the 2nd cross hair is on the deers belly. with this done read the yardage on the scale to the right. Say it reads 400 yards, you then turn the elevation knob to 4. you then can shoot the regular cross hairs dead on.
Where can I get a manual for a Redfield 6-18x accu trac scope?
Dear Carl,
I have the same problem and have not been successful finding an actual manual. However, if you go to "abousainc.com" there is a link for general instructions. It is under "Redfield Scopes" and then scroll down to "How to use the AccuTrac." However, it does not give the starting point of the instructions and only gives the table for the different dials. I will try to explain what those 2 lines at the top of the reticle are for.
The average whitetail from the top of the shoulder to the bottom of the chest should fit exactly inbetween these 2 lines when the zoom is used correctly. If you notice, the yardage counter in the bottom left (4:00 position) it will tell the yardage of the deer when you zoom in or out and the torso fills these 2 lines. You may also notice it starts at 200yds. Thats because you need have your rifle zeroed in at 100 yds. So there's no point displaying less than 200 yds. This is where the different dials come in. For example: the deer is 300yds away. You zoom in or out until the torso of the deer is inbetween the 2 lines then look at the yardage in the 4:00 position. It should read approx 300yds. Then you dial up to the number 3 position on the elevation knob and aim as you would if the deer where at 100ds.
Look up which dial you need on the ABOUSA site on the AccuTrac tables I mentioned earlier. You might be lucky and find the dial you have is the right one for your caliber. If not, this company was once the offical repair facility for Redfield, Colorado. They also have the different dials for sale but are quite expensive...$10--$30 each.
Hope this helps,
Mark
Jan 16, 2011 | Redfield Revolution Riflescopes
I can see objects through the finderscope, but cannot see anything through the telescope. What am I doing wrong?
Your finder scope is NOT lined up with the main tube. Get a distant object like the top of a telephone pole into the eyepiece of the main telescope tube.
Without moving the scope adjust the crosshairs or the red dot onto the exact same spot. Now your finder scope is lined up with the main telescope tube.
Dec 27, 2010 | Edu-Science (10166) Telescope
I have tasco #62TR rifle scope. I has stadia crosshairs and an adjustable top turret with various ranges for elk, deer, and antelope. However I cannot find any paperwork describing these features, and I...
Sight in rifle and put the on top turret with zero facing back.do not let knob"click".Aim at animal and adjust power(3-9etc)until body is bracketed by both crosshairs.Look in little window in eyepiece for type of animal.Click top turret to proper yardage(200,300etc).This allows for bullet drop.I've had one on a .270 for 30 yrs and never used this feature.
Dec 05, 2010 | Tasco 3-9x Variable Riflescope
Need a pair of adjustment caps for a Redfield 2x7 Scope Where might I locate?????
go on line with redfield and look for there tech phone number and call them.
Mar 19, 2010 | Redfield See Thru Rifle Scope Mount Base...
Redfeild scopes
turn the back lens holder screw it in or out till it get in focus most people don't know that there supposed to focus there scope or how to do it and most scopes are good enough but they can be made better by adjusting them to your eye
Nov 16, 2009 | Optics
Crosshairs moved after rifle was sighted in
now then,,,did the crosshairs move or did the scope slip back out of line? if the mounts were not tight then its likley to be the scope slipping back but if the crosshairs moved were they just setteling or are they moving,,if there realy moving the scope is claped out or shook apart inside,,,how big is your rifle you put this scope on? 357mag??? i have a simmons scope on a 7.62 and on a .303 enfield rifle its ok on them?
Nov 02, 2009 | Simmons Optics
NEED REPLACEMENT PART FOR TASCO 4X15 I NEED THE CROSSHAIR PIECE
im sorry but the price of that scope is not worth getting new crosshairs, you should just go get a new scope at walmart. they are like 9 bucks. But i myself would get a better scope, you can get decent ones for liek 60 bucks. Last a lifetime if you take care of them. The best scopes can cost 800 dollars on up. Just get a new scope. the part would coast more then the scope.
Dec 13, 2008 | Tasco RIMFIRE SCOPES BLACK GLOSS...
Crosshairs are cocked to the right.
your scope has spun in the scope rings. Loosen the screws holding the scope to the rifle and turn scope until crosshairs are into position. Then tighten screws. You will need to sight in again. If it keeps moving replace scope rings.
Dec 12, 2008 | Tasco 3-9x40 World Class Riflescope 30/30...
Optics Logo
947 people viewed this question
Top Redfield Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Redfield Optic Expert? Answer questions, earn points and help others
