Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
Brother MFC-490CW won't scan
I've set up my MFC-490CW on my wireless network and now it won't scan. what should I do? Does it have to be plugged into anything?
  • 3 Answers
I have had this problem with multiple different Brother products and this has worked for me every time providing your network is up and running.
Reason behind problem: Brother uses a Network Name for the device for access to the printer by the TCP/IP Port, occasionally your dns cache will hold the incorrect IP address for the printer and you need to force the network name to point at the correct IP.
**Note the steps to find your printer IP may change depending on the model of your printer but you can find out where it is in your manual if this doesn't work.
1. On your printer press the menu button. 2. Naviagate to LAN -> TCP/IP -> IP Address 3. When you press ok on IP Address it should show the printers current IP at the top of the page. It will look something like 192.168.0.164 keep a note of this. 4. Back on your computer go to Control Panel 5. Open printers (this may vary slightly by operating system) 6. Find your Brother MFC and right click on it. Then press Properties. 7. Click on the Ports Tab. 8. Select the port that has a tick next to it and press Configure Port... 9. Note down the Port Name: It will be something like BRN_984B5C 10. You can now close all of the printer windows. 11. Open File Explorer 12. Go to C:\Windows\System32\drivers\etc\ 13. There will be a file called hosts (no extention) double click on it and choose Notepad to open the file. 14. At the bottom of this document after all the other text you will need to type in the following (using the information we have found): 192.168.0.164 BRN_984B5C 15. Close and save the file. As you are in Vista you may have some funky UAC windows asking if you are sure you want to save etc. etc. just say yes.
That should do it, your printer will now be able to scan, print & fax from the printer and the printer will be able to find you if you do the same from it's menu.
Hope this helps.
Posted on Oct 29, 2009
  • 2 more comments
  • Craybe
    Craybe Oct 29, 2009
    Sorry first post, will have to work on formatting.
    Hope this helps.
  • ITFOLK Apr 26, 2011
    Thank you so much, I have been trying to get scanning working for a few months and this worked perfectly. Thanks again.
  • JanPhad5258 Jun 25, 2011
    I followed the last solution Brother helped me with and it said I was connected but I still could not scan. Then I went to your instructions and after many "learning attempts" I got as far as configure port but my computer will not allow me to Configure Port....but I do have the port name...Then in the System 32 drivers....it will not allow me to save!! Even when Vista asks me if I want to .... so I guess it is now to the help call center!!
  • ITFOLK Jun 25, 2011
    If you cannot configure, you may just need to start a new port and forget trying to update the original one. Also, with Vista you need to be logged in as an administrator.
My brother printer will print from 2 PC, but will only scan from 1.
HAve you installed the printer software to your Both Computer?
Still having Problem Then follow Us For
Brother Printer Support
Feb 24, 2014 | Brother MFC 490cw Color Inkjet...
HI! my printer brother mfc-490cw is offline and wont print .what do i have to do to get it on line ? i own a mac . Louie
Go to system settings and select the 'Printer' option. Right-click on the printer and enable the 'Use Printer Online' function. Cancel all the printing jobs till that moment and redo the process. Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue. Check all network connections and functions. Be sure the network interfaces work properly. Turn the printer off and on to see whether the device is working properly.
Mar 18, 2011 | Brother MFC 490cw Color Inkjet...
Hello, I have a brother MFC-490CW mult-function printer (wireless) and I am having trouble setting up the wireless feature so my laptop can print to it via through my home network (Linksys wireless...
You have to make sure the following are used on your wireless settings on your router -
Wireless Network Security SSID (32 chr), WEP 64/128bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
This means your SSID is less than 32 chars and your running either WEP, WPA. Or WPA2
Then on your printer make sure you have the wireless enabled and Just a good rule of thumb - When putting in a wireless printer just fudge with the wirless/TCP/IP settings on the printer until you can ping the printer from the PC. Do NOT bother running the software installs until you know you have a good ping from the printer as it will just bomb out.
do rate the solution plz
Nov 25, 2010 | Brother MFC 490cw Color Inkjet...
I CAN NOT CONNECT WIRELESSLY?
My MFC-490cw connects to the wireless internet and so does my computer. However I am still unable to print, scan, etc... The status monitor claims it is offline. I recently switched routers and it seemed to cause the problem. Any ideas on a fix?
Feb 18, 2010 | Brother MFC 490cw Color Inkjet...
I have the MFC-490CW, I am trying to install it to be wireless. But I can't figure out some of the items. How do I find the WEP key?
My brother MFC490-CW is connected wirelessly to the router. It printed OK wirelessly yesterday when I set it up but today it will not print. The printer has a strong wireless connection to the router. My PC also has a strong connection to the router. But the printer seems to have lost the connection to my PC. How to I re-establish the wireless connection from the printer to my PC?
Nov 03, 2009 | Brother MFC 490cw Color Inkjet...
My printer is connected to the internet, but status is 'offline'
Hey Bud. I had the exact same issue with mine. I called around and no one had an educated answer. I remembered that my Uncle Lester works for the IP department for the city of Beaumont. I called his house and of course he was at work. Just for grins I asked his 8 year old daughter how to fix it. She simply said, "Just unplug the router and plug it back in.... What a ********...." Then she hung up... Neddless to say this seems to work for everything else too.... Good luck.
Dec 31, 2008 | Office Equipment & Supplies
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
10,484 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
