Question about Dryers
We just moved and had to change plugs on my dryer from a 3 prong to a 4 prong. Now my dryer won't heat up. I think the breaker is ok.
    President:
  • 1,187 Answers
Thre are two braekers (or a double breaker). Check / reset to be sure.
The plug may not have been installed corerctly.
Posted on Oct 07, 2009
Dryer wont heat up
Is the circuit breaker a duel bullet type fuse (2) in the case for the 220 line? Try changing them and see what happens.
Apr 07, 2013 | Dryers
I have a Frigidaire Affinity front load dryer that will not come on at all. The lights won't even come on. We had to change the cord out to a 4 prong and when we plugged it in it surged. What could...
Hi, Sounds like you hooked the cord up wrong... tripped the breaker...fix the cord and reset the breaker...
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Jul 10, 2011 | Dryers
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
I have a 4 prong dryer but the plug in the wall is a three prong, ibought a four prong plug and i dont know how to connect a three wire into a four prong plug please help me.. hugo
Do NOT try and change the receptacle please. It is dangerous and we do not want anyone getting hurt. In your case, it would be better to put a 3 prong cord on the dryer. Overall you could call an electrician to install the 4 prong receptacle, which will require new 4 conductor wire as well and run to the breaker box. Get a flat style 3 prong dryer cord and we'll tell you how to install it. Unless you call an electrician. ;-) If this helps you, please rate my answer. Thank you.
Jan 07, 2010 | GE Dryers
I was switching the electrical cord from a 3 prong to a 4 prong and grounded a hot wire. there was a big pop and now i cant get it to start. would i have blown it up?
WHy are you switching the cord from a 3 to a 4? If the dryer came with a 3 prong cord and its a 3 prong terminal block, then i dont think you can change it to a 4 becuase you will short circuit. DOes the terminal block where your cord was hooked up have 4 terminals. Each termial can only have one lead/wire to it. check your circiut breaker panel? Is the circiut breaker tripped?
Jul 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Jul 11, 2009 | Frigidaire Dryers
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
JUST CHANGED MY GE DRYER TO A 4 PRONG PLUG, NOW NO HEAT
Sounds like your heating element is burned out (acually burned threw) when you moved it if the element was weak it may have broke in two along the coil wires.
Happens alot.
Feb 17, 2009 | GE Dryers
No heat-switched from 4 prong to 3 prong-Ground????
There should be a ground bonding ******** the Neutral (White) wire at the terminal block for 3-prong configuration. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Read through the information, thoroughly. Instructions on how to convert from 4 to 3 prong are mentioned in the "Additional Notes" section. If you have questions, or require addtional assistance please let me know. I hope this helps you.
Jan 13, 2009 | Kenmore 67032 Dryer
Dryers Logo
53 people viewed this question
Top Dryers Experts
