Question about Kenmore 24032\24036 Top Load Washer
Water level was working . hose came off back. now water level won't stop filling
  • 31 Answers
Either a water valve or a bad control. valves go bad over time much like the gas coils on a dryer, they swell. controls can sometimes get stuck on fill. but the valves are mosre likely to fail.
Posted on Oct 07, 2009
Water will not stop filling up the tube
IF YOU MEAN YOUR TUB WON T QUIT FILLING THE WATER LEVEL SWITCH HAS A TUBE ON IT ITS IN THE CONTROL PANEL THE SMALL HOSE IS PROBABLY OFF THE SWITCH AND IT CANNOT TELL THE TUB IS FULL
Jun 19, 2014 | Frigidaire FWS1339A Top Load Washer
My Whirlpool washer fills up but won't stop poring into the washer. Is this something that is repairable?
Your water level switch could be defective. This switch has a plastic 1/4 hose connected from your tub to the switch. (should be easy to find.) Make sure this hose is connected to your tub and switch and the line has no holes. It is easy to test the switch by disconnecting the line from the tub and while water is flowing into your washer, Blow into the line. The pressure will stop the water flow. If not, Bad level switch.
Level switch part# W10339333
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Whirlpool WTW5100SQ
Won't stop filling up. Water continues to flow without stopping for cycles
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps.
Gene
Aug 28, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My washer wont fill with water what seems to be the problem
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 10, 2011 | Samsung WF210AN Washer
My WF306LAW-XAA Samsung washer will not stop filling with water and hence will not advance to wash cycle. Do you think it needs a new mixer valve?
No, you have a water level switch problem. Simple solution is to pull the hose from the water level switch and blow into the hose to clear out the debris. DO NOT BLOW INTO THE WATER LEVEL SWITCH!!! It will break!!! Replace the hose back onto the water level switch and it should work fine. Good luck
Jun 17, 2011 | Samsung Washing Machines
Maytag pav2300 wont stop filling up. New timer
After the water fill, Switch off the mains, allow little water bleed through the hose that goes to the level switch. As the water flows try fixing into the level switch block.
Clean the water drips to dry and switch on the m/c. It should be alright since you say that the switch is OK when air is blowed!
Apr 01, 2010 | Maytag PAV2300 Top Load Washer
GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
Mar 21, 2009 | GE WCXR1070A
Maytag performa not recognizing when to stop filling with water
be sure the rubber hose runnig from the water level switch to the tub is conected on both ends if not conected to the tub the water will come out the hole the hose is supposed to be conected to and it want stop filling.
Jan 21, 2009 | Maytag Washing Machines
Ge wbsr washer overflows...
Could it be ...this happens only when it is overloaded or the load is out of balance. Please clarify.
If this is not the case .. the water level hose running from the outside tank to the water level switch is likely not making a good seal (otherwise the water level switch itself is bad). Sometimes with age the hose forms a crack in it near or at the end where it connects. This could happen at either end of the hose. Also if you have removed the control panel recently (for any reason) you may have (not knowingly) pulled the water level hose loose from the water level switch. Just slide the hose back onto the tube of the switch before putting the control panel back in place and all will be fine after the first filling of the tub (it may take one filling cycle to build the needed vacuum back up in the hose). Unless of course in the process you have broken the tube off the switch where the hose goes on. In this case replace the switch.
Jun 05, 2017 | GE WBSR3140DW Top Load Washer
Washing machine wont stop filling up
check hose to water level switch, if it has had an out of balance situation it can loosen or detach hose. replace hose firmly back on switch or replace hose if that doesn't work.
Oct 18, 2007 | KitchenAid KAWS750L Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
24 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
