Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
My fridge keeps freezing my food
I have a four year old GE Profile refrigerator and it continues to freeze my food in the fridge and I can not get water from the dispenser. I unpluged it last weekend to completely defrost thinking the water line had frozen and once I plugged it back in the water worked, it made some ice, but in two days the fridge was freezing my food again. What should I do?
  • 4,070 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Oct 10, 2009
The frezer is developing a huge block of ice.
Posted on Oct 07, 2009
GE Profile Brita Fridge. Have setting down as low as possible and crisper foods continue to freeze. How can I fix that?
You need an internal digital thermometer to see if 1 is the coldest or the hottest. If you turn it to 6 and the temperature remains the same, the thermostat is faulty.
If 1 is the warmest and it continues to freeze crisper foods like lettuce, you need a new thermostat. Your ideal temperature is between 3 and 4' Centigrade at the coldest part, usually above the bottom shelf.
Aug 23, 2016 | GE Refrigerators
Freezing food in frig. , not making ice .
Freezing food in the fridge also freezes the water line for the ice maker.
You have a thermostat problem. Get a new thermostat fitted.
Mar 31, 2011 | GE Profile¿ Arctica® Energy...
Ge side by side profile Artica, the bottom drawer on the fridg side keeps running and freezing everything. I can't seem to shut it off. Please help!
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 16, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile Ps27sgra refrigerator and freezef are
Hi, this problem is going to be with the running thermostat2.gif (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge2.gif to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
All the food is freezing in the fridge
The thrm.a stast is bad can't spell temp. control. bad.
Sep 22, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Top of fridge/freezer will not cool
hi..the tubing that goes to the automatic defrost
gets clogged up and keeps the fridge from getting
cold.
check this out..
thank u..
rate me..
May 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Fan keeps freezing
HI .did you pull the fridge, away from the wall, and clean out the drain tube ,at the back. if not pull fridge away from wall, find the drain tube, and clean. thanks the appliance doc
Aug 04, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Refrigerators Logo
715 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
