Question about Marantz SR8001
What type of speaker wire terminals does the Marantz sr8001 allow?
    New Friend:
    Problem Solver:
  • 8 Answers
Hello there.
These are blind posts (i.e the unscrew back) but will not allow you to unscrew them fully to use spades.
Only bananas (of any type) and bare wire (do not recommend it).
I own the same SR and faced many issues (even going into "protection mode") due to bad quality binding posts used on this machine.
For any clarifications (specific type of terminals) let me know.
Evangelos
Posted on Nov 04, 2010
Hi I brought sr8001 receiver I had connected the same to all speakers I connected to Homi cable then i switched on the amp, from left side of amp there was some burn smell was cmg. Just I had switched off....
It sounds like you may have damage to the capacitors, fuses, or other printed board circuitry.
What type of voltage (current) was this system plugged into? 110 Volts or 220?
Feb 23, 2015 | Marantz SR8002 7.1 Channels Receiver
Harman Kardon AVR 350, Unit powers off into standby mode after a few seconds. Removed all connections and wires, problem persists. Weirdly enough, if I keep pressing the source button, the unit stays on....
It needs to be serviced. Bad caps, resistors, & possibly a transistor or two. Not an unbearable repair, but you can count on it being 100-175 depending on the shop. You followed all the troubleshooting you could without opening the unit.
Oct 02, 2013 | Marantz SR8001
Connecting Speakers to Marantz NR1402
HI,
You can use banana plugs to connect speakers to the speaker post. Connect the wire to the banana plug then insert the banana plug in the speaker post.
If you serch in google with the name speaker banana plug then you will get picture of different types.
You can buy this banana plugs in any nearby electronic spare part shop. They all stock this item. Normally comes in pair ( red, black)
Ajin
Feb 22, 2012 | Marantz Audio Players & Recorders
For no reason I know of, my Marantz SR8001 will not come on and the display will not light up. It will not respond to activation using the power button on the display panel, or the power activator on the...
blinking power lights are a factory setting to inform the customer there is an internal electronic fault. and the unit needs to be repaired by a service pro in 99% of cases the owner can do nothing to fix it.
send it in
best luck
Oct 14, 2010 | Marantz SR8001
Hi, my Marantz sr8001 is on standby mode, can you show me how to reset standby mode. Thanks
Mine is doing the exact same thing! All I want to do is get it OUT of standby mode!
Sep 13, 2010 | Marantz SR8001
Marantz sr8001: standby light blinks rapidly,
Hello there Ed.
For anyone that has ever had such an issue with a MARANTZ SR series (6001. 7001. 7002. 8001...etc...) issue a question and I do HAVE the answer.
I could be just anything, or just the low quality binding posts used by MARANTZ for that.
Please describe to me in details how you've connected your speaker wires at the back, and give me description when and how did this problem came up.
Kind regards
Evangelos
Oct 17, 2009 | Marantz SR8001
Marantz SR8001fail to standby mode, will not reset
Test all your speaker impedances and check for shorts on both wiring and speakers. Use a digital multimeter. If you still have an issue, disconnect all speakers and test receiver. If you still have a problem, post a comment and I can help some more.
Aug 07, 2009 | Marantz SR8001
How to do Bi wiring in 6.1
Remove the bridging links from the speaker terminals and run two equal lengths of speaker wire from the amp to the speaker. At the amp - speaker terminal, twist two of the same wires together. ( normally marked with a tracer color) Connect these into your left speaker output - terminal and tighten. Connect the two wires to both the negative terminals on the speaker. Repeat the same for the + side. Make sure wires are not shorting across the terminals.
Mar 20, 2009 | Marantz SR-6300 Receiver
Shuts off !!
check your output stage
Nov 18, 2007 | Marantz SR8001
Marantz SR8001 Logo
133 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
