Question about Garden
601 ford tractor weak starting, battery runs down, new starter, alternator, voltage regulator & coil. Any thoughts or suggestions.
  • 718 Answers
Check your ground(s) wire or something is left on like lights or some electric option or something is shorting out.
Posted on Oct 09, 2009
Testimonial: "I have limited knowledge about mechanics. The answer to my problem was right on the money. Thanks"
" HI " Where is the Voltage Regulator Located on a 2002 Dodge Stratus R/T 3.0
The way to check for an over or under charge is to connect your volt meter to the battery, before starting the vehicle.
You should have a reading of 12.5 to 13 volts. If it's 11.8 like you stated or less, it means battery is not fully charged, or it's bad. Now start the car & check voltage again while running the engine, the voltage should exceed 14+ volts, this means your Alternator is charging, the voltage should drop after battery has been charging for awhile. When you turn the engine off after letting it charge the battery, & if the battery is good, you should now have 12.5 volts to 13 volts.
Now to answer your question, the Voltage Regulator is inside of the Altenator, I believe you xcan take the alternator apart to replace it, or simpler to just replace the complete alternator.
Nov 15, 2014 | 2002 Dodge Stratus
What alternator comes on a 1981 ford f150 truck with a 302 engine And how do you wire up the voltage regulator Won't charge the battery I've changed the alt,voltage regulator& battery I'm not sure if I...
The capacity of the alternator ( 35 amp or 100amp ) will make little difference to charging a battery. It has to do with the voltage regulator which may be internal in the alternator or external on the engine bay. The other fault that will not allow a battery to charge is the rectifier as if a diode has burnt out then the voltage that is being regulated is ac and it will not work anyway. The capacity of the alternator is determined by the total current draw when everything is switched on and should be around 10 amps more than what is required. IT not then the battery will slowly drain down because the alternator is not capable of running every thing and charge the battery as well. I suggest that an accredited auto electrician be engaged to sort this problem out
Jul 18, 2014 | Cars & Trucks
Not starting, and not charging the battery
I see this was posted 2 years ago, and hopefully you have your truck running properly again, but for the benefit of anyone else who may have this problem as well, here are a few suggestions...
Apparently the starter, alternator and battery are all new, and were all tested to be good. I also see the truck won't start after running for a long period of time "til it cools down." I take it to mean that after the engine cools down it WILL restart. So the problem appears not to be a problem with the battery or the alternator, but may be something else entirely. There is no mention as to the status of the voltage gauge in the dash, as that would be an immediate heads-up as to a problem. If the voltage gauge is showing around 12 volts or less, then the alternator is not applying charge to the electrical system and may be in fact, faulty. If the vehicle has a voltage regulator separate from the alternator, (most have an internal regulator found inside the alternator), then the regulator may be bad and needing replacement. However, again there is no mention of this. If the voltage gauge is reading 14 volts or just over, then the alternator and regulator are operating normally and should be applying charge to the electrical system.
If it in fact will restart after a cool down period, then I would suspect something in the electrical system having to do with starting the vehicle is overheating or is getting overheated due to a missing heat shield and will not allow restart until the part cools back down.
If it will not restart without jump starting the vehicle, then there may be a loose wire or connector someplace in the wiring system. These kinds of issues can be very difficult to diagnose, and may require an experienced certified mechanic to find.
Good Luck.
Jan 25, 2013 | Charging & Starting Systems for Chevrolet...
Alternater wont charge battery and fusable link on starter keeps burning
Bad voltage regulator. Usually built-into alternator.
Start car and unplug battery, if it dies your alternator is dead. Get new alternator. If car keeps running, get a voltmeter and check voltage coming through - should be higher than 12v but less than 18v. Any other number means your voltage regulator is dead, cheaper to get a new alternator.
Jan 11, 2013 | 2000 Dodge Neon
1982 Yamaha XJ 550, the battery will not take a charge. New battery, checked all connections, ran all the tests (stator, brushes, and alternator). Replaced the voltage regulator/recifier. Not sure what is...
It is corrected properly, right? + to the wiring harness and - to ground ... right? Are you certain about the rectifier? Is the battery charged at this time?
You know a alternator cannot make power unless you first put power into it ... right? Alternators (unlike most generators) are not self exciting. If your battery is weak or "dead", the alternator cannot make electricity to charge the battery. I don't know what the rating of your alternator is. Your battery should be fully charged before you do any more tests. If you have a 1 amp charger, allow at least 10 hours for a full charge. Don't cook your battery with a big, powerful, fast charging automotive battery charger.
Good luck with your repair ... I hope you find this response helpful.
Thanks for your question @ FixYa.com
May 02, 2011 | Yamaha XJ 650 Motorcycles
Can I use a 8 volt battery on a 6 volt tractor or will it trip the voltage regulator and blcck the generator?
YOU CAN USE AN 8 VOLT BATTERY, IT SHOULDN'T HURT ANYTHING. THE ONLY THING IS IT WON'T STAY FULLY CHARGED. THE GENERATOR IS DESIGNED FOR A 6 VOLT BATTERY NOT 8 VOLTS. WHAT I DO IS CHANGE THE SYSTEM TO 12 VOLTS. NOTHING WILL HAVE TO BE DONE TO THE STARTER, IF THE TRACTOR STARTS LIKE IT IS SUPPOSED TO. IT WILL JUST START FASTER. YOU WILL NEED NEW POINTS & CONDENSER & A RESISTOR FOR THE DISTRIBUTOR. ALSO A 12 VOLT BATTERY & A MID 1970'S INTERNALLY REGULATED ALTERNATOR, MOUNTED IN PLACE OF THE GENERATOR. THIS A LITTLE WORK BUT THE TRACTOR WILL START AMAZINGLY FAST. I HAVE DONE THIS SEVERAL TIMES & IT WORKS GREAT. IF THE FUEL GAUGE STILL WORKS YOU WILL NEED A SPECIAL RESISTOR FOR THAT. OF COURSE ANY LIGHTS WILL HAVE TO BE CHANGED TO 12 VOLT GOOD LUCK. DR. VOLT.
Jan 25, 2011 | Ford Expedition Cars & Trucks
Battery want charge... ok i paid to talk w/ a
Sounds like the voltage regulator is bad--will run the battery down!
Feb 27, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Ford 8N 1949 cannot start no spark
Hi I am Vortash this sounds like a spark gap problem at the distributor points or maybe a fault in the ignition switch .. but the voltage regulator would only regulate the power coming from the dynamo to the battery and as long as the battery is charging then it is ok I would check the following ... Points gap for a fourstroke engine of the age you say I would have thought no less than 12- no mre than 18 thou .. check the distributor rotor arm and cap are connecting properly ..sometimes the carbon connection sticks and doesn't touch the rotor strip , make sure the rotor arm end is not carbonised .. check there are no breaks in the contact breaker wire .. run a wire direct from the battery to the coil and distributor bypassing the ignition switch and see if it starts then proving a switch fault ..hope this helps regards vortash
Jul 22, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Battery light randomly comes on
Sounds like the voltage regulator is starting to fail. Your voltage regulator is built in to the alternator, so you should replace your alternator before it dies completely and leaves you stranded somewhere.
May 24, 2009 | 2006 Ford Mustang
John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
May 08, 2009 | Garden
Garden Logo
341 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
