Question about Dell Dimension 3100 PC Desktop
Computer will not re-boot
When attempting to boot a black screen appears that reads "Loading PBR for descriptor 2...done." Below that: "A disk read error occurred/Press Ctrl+Alt+Del to restart"
Re-starting, however, does nothing--the same message appears every time.
The problem began when the computer's power source was accidentally cut so the device was improperly shut down.
  • jrob2001 Oct 07, 2009
    Anything you think I could do to repair a corrupted hard drive?
    Yes I've done a diagnostic scan, there are elements of the hard drive that cannot be read, inhibiting the OS startup. According to the Dell troubleshooting options for this particular problem, system restore is the only viable solution (which I can do, though it would be devastating, having never backed up any of my files). Is there an alternate way to access my files for back-up before initiating the restore process?
    Problem Solver:
  • 4 Answers
TRY RESTARTING YOUR COMPUTER IN SAFE MODE ( TAP f8 AS SOON AS YOU TURN IT ON AND UNTIL IT SAYS SAFE MODE) THEN CLICK ON TO LAST GOOD KNOWN START UP
Posted on Oct 07, 2009
  • Dell Master
  • 1,165 Answers
Your hard drive has been corrupted due to improper shutdown
  • Steve Sweetleaf
    Steve Sweetleaf Oct 07, 2009
    i would try to do a factory restore.or if you have the disk redo your operating system.youll loose everything.but better to loose it then your pc. can you get into the BIOS.can you do anything with it.do you have the restore disk.if you can get into the bios you can check to see if your hard drive is being read and or showin up[ or it wont show one].let me know.
  • Steve Sweetleaf
    yes there is away if u are willing to learn it read up on it and join the forum you can get all your info before a redo.I personally use this to get passwords fix pcs and it can hack about anything.ITS FREE.LOL..ITS CALLED UBUNTU LIVE ISO CD.IT WILL BOOT ANY PC, FOR THE DISK ACTS AS THE HARD DRIVE.THERES THIS THING CALLED TERMINAL it is the same as command prompt. this is a linex live cd.you will have to have a pc to download it and have a program thatll make ISO images theres free ones on google..once you have downloaded it tryit t it do NOT install it run as live cd.you can connect the the net also.go to a linex ubuntu forum describe what your trying to do and what commands you will need to do this.you will get good answers.give it time.if you learn to use this cd youll be glad you did its a defenette life saver and has many great tools to work with..if you need the link give me a write back.this will work and is your best option.
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
My Dell says loading pbr descriptor
1)Try F8 safe mode and follow directions.
2) Insert installation disk and use repair option.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Apr 04, 2012 | Dell Computers & Internet
Screen says" Loading PBR for descriptor
And again and again and drives you up the wall.OK-boot sector is corrupted, or hard drive is going south.What you can try is system restore.On boot see which button is designated for that-usually f10 or f12.Start tapping that button and follow instructions. If that failed, the only option is to reinstall OS.If you have a lot of stuff that you want to save, install Windows in different folder, say WindowsA.All your stuff will be saved on the Hard drive-My Documents.Good luck and keep us posted.
Jun 14, 2011 | Computers & Internet
When i turn on my laptop i get loading pbr for descriptor 2 done ntldr is missing on dell vostro 1700
This is saying that the ntldr, which is a file necessary to start windows is missing.
You will need to follow one of these steps in the links, below:
Note, if you have Windows Vista or Windows 7, you'll need to boot from the Windows system disk and follow the prompts to repair Windows
http://www.fixya.com/support/r4501608-when_windows_xp_start_primary_fix
http://www.fixya.com/support/r4501848-when_windows_xp_start_secondary_fix
Mar 26, 2011 | Computers & Internet
I have a inspiron i1011-26600bk and its telling me a message that says Loading PBR for descriptor 2...done. What should I do?
"Loading PBR for descriptor 2 ... failed" would be the exact error message if the MBR is unable to load the partition boot record for the second partition. There may be more, but here are three possible causes:
1) the partition table is corrupted so that the descriptor points to the wrong place (i.e., says the partition is one place when it's really somewhere else);
2) the partition table descriptor points to the right place, but the boot record there is corrupted or has been erased;
3) The hard disk is failing and having trouble reading the sector with the boot record.
To check (1), visit www.goodells.net/dellrestore/fixes.htm and download the dsrfix utility. In short, if dsrfix reports a clean bill of health, then (1) isn't the problem.
To check (3), run hard disk diagnostic tests. Press F12 when the machine is starting and see if the bios boot menu offers you a hard disk diagnostic test that you can run. Or even better, if you know the brand of the hard disk, most manufacturers should have a free diagnostic utility you can download to test the hard disk.
If it's not (1) or (3), then use Ctrl+F11 to run the Dell restore utility to recreate the Windows partition.
Mar 12, 2011 | Computers & Internet
A disk read error occurred press ctl+alt+delete to restart
May I know whether the Hard Drive is listed in the BIOS? Try reinstalling the Windows using the Windows OS disc.
Jul 04, 2010 | Dell Inspiron B130 Notebook
Loading PBR for descriptor 2... MODEL DELL DV051
That is the boot loader message to boot to the NTFS Primary boot partition (Primary Boot Record for Descriptor 1 is the Utility partition)
Normally, this message flashes and the system boots, since it is not there is a failure in the boot process.
#1 run diags on the Hard Drive (CTRL+ALT+D at boot) and see if it passes
If it does
#2 Boot to you XP CD, press R for recovery console, and run the COMMAND CHKDSK /R see if the system will boot
If no go, go back to recovery console, try the command BOOTCFG /Rebuild then see if the system will boot
If That fails, try reinstalling Windows
If Diags Fail or all the above fail, replace the hard drive
Jun 24, 2010 | Dell Computers & Internet
Start up gets to "Loading PBR for descriptor 2... done"
I suspect that the viruses had infected some of the files that windows needed to boot up. The moment you ran the Mcafee, the scanning might have deleted or quarantined those files. That is the reason you're having this Loading PBR message because it is now trying to boot from the network and not from the hard drive. You will need to repair windows using the CDs that came with the computer (the Operating system CD/DVD) and run CHKDSK /R at the screen where it says 'repair your computer using the command prompt". If this does not work, chances are, you may need to reinstall windows and everything and that all information in your hard drive will be wiped out.
Jan 03, 2010 | Computers & Internet
Dell Dimension 3000 system recovery
AH yes, Kristen very familiar with your issue, it is trying to load the primary boot record from a device it dosen't see , ( re: a floppy thats not there) you need to check the BIOS and make sure the booting sequence is correct (re:disable floopy if one dose not exist, etc) please write back if you need help doing all of these things
Apr 18, 2009 | Dell Dimension 3000 PC Desktop
Boot to the Diagnistics FN+POWER at boot, run hard drive diagnostics. The PBR Descriptor 2 message is part of the normal boot process (directing the boot loader to Primary Boot Recond 2, the C: Drive) but usually flashes on an off so fast most people never notice it. Since the boot process is not going past the re-direct it is indicative of a bad hdd (Since the re-image process crashed)
Most likely you are looking at a hard drive replacement.
Regardless you are going to need an XP CD (you'll have to reinstall windows or run recovery console at a minimum)
Apr 01, 2009 | Dell Inspiron 6400 Notebook
Dell Dimension 3100 PC Desktop Logo
274 people viewed this question
Alun Cox
