Question about Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV
Blue Spots I have a blue light in the lower left corner of my TV as well as blue spots in the center of the TV. What is the problem??
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 157 Answers
This is a failure of the optical block of your TV. This was an inherent problem for your model. The only way to fix it is to replace the optical block. It is very expensive (over $700) and time consuming (takes over a hour for an experienced technician).
Sony extended the optical block warranty for your model that covered parts and labor but it expired on June 30, 2008. Contact Sony, they might be able to pay for at least part of the repair.
Here is a link to the Sony response to the issue with pictures: http://7402519399385937065-a-1802744773732722657-s-sites.googlegroups.com/site/sonylcdrptvproblems/sonyrearprojectionlcdtv-opticalblock/2003GrandWEGABlueHazeAdditionalCoverage.pdf?attachauth=ANoY7cqH-wG8F6xCLp07es9MJWf0B9tr36oyw8conVtRyMlYrQTo-iZ-dba8Nq2VTMzjXKhDY_FEX-ho-9o2iYDqTkzqtsoHY1URYyWt2tAuoQZN7XMvcCPOiA4bgQupIqffnXIuB0ldeVn8bbMwfxVB7Y9cTbRXUxV_eVqVk1YuV-m_ElE7jhtlxfQ5eG6zRY6dCmnVl-_e-eGOFdgcddmrc_Vz2iRgCGkPBL3wZAK3-KFHw2kRV-w7AHaV6-A-OqHnbU8hCU0CkFwDL-6kvxWwhg-Vn4fwsDFHLeOXn3xNgvjoxPt6i6E%3D&attredirects=0
Posted on Oct 07, 2009
  • bradcooley Dec 12, 2010
    great advice. I just called the phone number on that site, got a very helpful rep from Sony, would not repair the KDF-70XBR950, but would offer me the kdl60ex for $350, and I could keep the 70 (which I plan on replacing optical block myself). I took the offer - sweet.
Blue spots on Sony WEGA KDF60XS955
Thats caused by a bad optical block. The cost of that repair will almost always be greater than replacing the TV.Thats a very common issue with alot of Sony DLP models which suffered that optical block issue with the blobs of color usually blue or green
Dec 10, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
Blue pixelation spots all over main viewing screen.
Your dlp chip needs replacing. It's a job to do but you can do it.
Jul 23, 2017 | Sony Video Cameras
The lower left hand corner of the screen is turning blue
catually is problum is related with blue lcd & blue polizer but first you clean the optical unit if the problum gon then ok other wise must chang blue lcd & blue polorize with uv filter plese contect to your nearst sony service centre
Feb 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Blue spots
This is a Light Engine problem. Call a good TV Tech and explain the problem. These can be rebuilt for around $450. New ones are $800 to $1200.
Jun 30, 2009 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Large yellow spot in center of tv screen
Sorry, but there is no cheap method of repair for this unless it is in warranty.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty.
Good luck.....
May 18, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Screen appears blue
Try Moving The Speaker You Have There Away From It?
www.Myspace.com/CrossRoadsToNowhere2007
Jan 05, 2009 | Sony KDF-E55A20 55 in. LCD Television
Blue Noise/Pixels Bottom Left Corner of my Samsung Plasma
You would need to have a technician remove the back of the TV and make the adjustment. There are 2 small adjusters that they change to adjust the voltage.
Jun 10, 2008 | Samsung HP-S4253 Television
Purple and Blue Spots on Screen on Mitsubishi WD52527 52 Inch HDTV
It could be only dust building up and it needs a good cleaning or it could be the DMD board is going bad and needs to be replaced.
Mar 23, 2008 | Mitsubishi WD52527 52" Projection HDTV
Bright blue spots on lower right corner of Sony Grand WEGA KF50WE610 50 in. Rear projection tv
The spots are from dust in the optical assy. It would need to be replaced because the only way to fix the part would be to disasemble it in a dust free room.
Oct 29, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV Logo
469 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
