Question about Sony PlayStation 2 (PS2) Console
Orange drums don't work anymore!
When orange note comes up & you hit orange symbol it doesn't register.
  • 31 Answers
You shorted out your orange drum.
it happens
dont let your friends beat on it so hard, and you either.
Posted on Oct 07, 2009
Tracfone's instructions for how to text do not work! what's up?
Texting on this model a bit tricky. First pull up name & number of person you want to text to, if it is in your phone. Then hit short dash line under the word 'options'. Make sure #1, 'create message' is highlighted. Hit ok button. Now type message. If you want a 'v', for example, you have to hit the #8 button 3x quickly. If you make a mistake, hit 'clr' button on top right to clear it & retype. So, for example, you want to send the word 'please'. You would have to hit the #7 button once, wit a second for the curser on screen to move to next space, then hit the # 5 button 3x quickly to get to the 'l', wait for curser, then hit #3 button 2x quickly to get to the 'e', etc. You get the drift. This model is not very conducive to sending longer texts. It's too time consuming & annoying. But short ones are ok if you have the patience. IF you need a space in between words, hit the '0' button once (that's zero, not 'o'). This is where text code comes in handy for shortening words, such as "LOL" for laughing out loud, etc.
Once you are through typing note & want to send it, just hit ok button to send. It may take a bit of time for message to go through. If you type a lot, it may take up more than 1 page, if this happens, the phone will ask you 'message is 3 pages, do you want to send now', or something like that. The longer the message is, the longer it will take to send.
One thing to keep in mind, before you start typing, make sure you hit the bottom lower key that has the asterisk & up arrow on it 3x quickly, or else when you type, it will be all garbley goop. If you want a capital letter, you also have to hit that same key once before you hit letter key. It only works for one letter at a time, so if you need to do more than one, say you want to type "DVD", you have to hit asterisk key once, then #3 button for 'D', then asterisk key again, then #8 button 3x for "V', etc. If you need a symbol or punctuation, use the bottom right hand key that has the # sign on it. Hit it once & some symbols come up, you will have to move over to the one you want by using outlined area around the 'ok' button. Once you get to symbol you want, hit 'ok' button it will add that symbol or punctuation to your text & return you to your text area.
If you do not see the symbol or punctuation you want, hit small dash under the word 'next' & it will take you to the next page. I think there are 7 pages of these different symbols & punctuation.
Hope all that helps. Email me at: ldgtreke4@aol.com, if you have any other questions. Put short note in subject box so I know what this is about. Good luck!
Mar 15, 2015 | Tracfone Wireless LG 440G
Some dash lights on my 01 ranger don't work.the bulbs are good
Get an Auto Electrician to trace and fix the problem. There are partial contacts in the wiring system.
Dec 29, 2012 | Ford F-250 Cars & Trucks
My Creda dryer would not work when turned on. Just making a humming noise and smell of burning inside when on.
You most likely have a warn out turning mechanism(not the actual word for it). It most likely does not catch anymore so the tumbler doesn't turn. The 2 parts that come together, one from the motor mechanism and one from the actual drying drum propbably have worn out and don't mesh. This would cause the motor to spin but slip against the part that turns the drum causeing friction that creates the burning smell. Dryers are not very difficult to work on. Your best bet is to have a handyman freind or inexpensive handyman to take it appart and repair it if possible. Good luck.
Sep 28, 2012 | Dryers
My beko condensor dryer is not turning anymore, the heat is fine but it doesn't tumble
Drum will not turn or rotate
1.broken or slipping belt---replace belt
2.jammed or bearings frozen ----check for foreign article between drum & shroud
Replace defective bearing or bearing support which allows drum to sag or hit
3.loose pulley----tighten pulley set screw
Sep 22, 2011 | Dryers
World tour orange symbol doesnt work
This is common on world tour kits, the kit itself is of very poor quality. As a matter of fact, my orange symbol registers a hit once every 5 or 6 hits :/
~Anyway, you can try fixing this by removing the symbol from kit, and unscrewing the plastic protector that is concealing the metal sensor.
~You should see 2 wires glued down to the sensor. One is glued to the OUTER ring, the other is glued to the INNER ring. Pay very close attention to this.
~Pull the first wire out from the glue and try to clean away as much of the glue as possible.
~Strip some of the plastic off of the wire, about 6mm will do.
~Either A) re-glue the wire down making sure it has much more exposure to the sensor, OR...
B) Take tape of your choice (duct tape or gaffa tape works well) and tape the wire down to the sensor, making sure it is ONLY touching the ring it is supposed to.
~Repeat this process for the other wire.
~Replace plastic covering and test the symbol. It should work perfectly. If it is still unsensitive, you can have RedOctane send you a MIDI cable to run the drum sensitivity tuner program to increase the sensitivity. Alternatively, you can take some more tape and run it from one side of the symbol (the under-side) to the other, and crossing over the top of the sensor. This increases it's sensitivity by allowing vibrations to carry along a wider area.
Hope this helps you :)
Nov 20, 2009 | Activision Video Game Consoles & Games
Where can i buy a new circuit board for xbox world tour orange cymbal? preferably in sydney australia
If you’re having problems with one of your cymbals not responding to your drumstick hits then you are not alone, this is a common occurrence because as anyone who has ever played this game and gotten hooked on it you can get pretty amped up during extreme guitar and drum passages. Unfortunately for the drummer when you get amped up you start pounding your drum pads harder and harder and sooner or later there is going to be a malfunction. You can go about the repairs a couple of different ways but I’ll address your question and the not getting your hands dirty solution which is a simple replacement. Because this is such a standard and common problem with The World Tour Drum Kit (One or Both Cymbals not responding to Drum Hits) a simple Google or Ebay search with the Ebay of your Country such as Ebay Australia will bring back page after page of replacement cymbals orange and yellow. Both of the cymbals are exactly the same, what designates it either the Orange or Yellow pad is what plug you plug into it, if the left Cymbal plug is plugged in then it registers as an Orange pad the right plug Vice Versa. Each pad has a removable Orange or Yellow colored washer that designates it but this has no bearing because the right or left hand side plug designates the color, simply swap one color washer for another if the need be.
Fix number two and the one I suggest is a repair of your original. The reason I suggest repairing the unit is because, one it’s a very easy simple repair if you have just the very basic of solder skills and two, if you purchase a replacement and get crazy again while rocking out your going to damage the new one just like the old one and then your back at square one. The cymbal uses a very simple design to register drum hits; it uses an almost indestructible switch called a piezoelectric, this switch registers pressure as a reason to close its normally open switch. The piezoelectric is attached to the bottom side of your cymbal pad and when you hit the top side of it with the stick viola~ pressure from the stick is applied to the pad and thus to the piezoelectric stuck to the bottom of the pad which tells the switch to close and complete a circuit which when completed sends a signal to the drum controller brain which then tells the Xbox 360 “Hey 360, my guy just hit the yellow cymbal pad so get busy and register a yellow cymbal hit”. As I mentioned earlier the piezoelectric switch is basically indestructible so that is not the problem and if it is it would be the first I’ve heard of, the problem 99.9% of the time is that the piezoelectric has a bad solder connection from one of the two wires attached to it or the other end of the wires that are attached to a mini board. Simple fix is just re-solder the 4 solder joints (Two sides of two wires = 4 solder joints) one at a time so you make sure you have the right color wire attached to the right connection. For the piezoelectric side you’re going to need at least a 40 Watt solder iron because you need to heat up the metal piezoelectric switch itself so as not to produce a cold/defective solder joint. The other problem is even simpler to fix, the glue they used to attach the piezoelectric to the bottom of the drum pad is loose so it doesn’t register the drum hits properly. Simply remove all of their garbage glue from their crappy workmanship and use standard hot glue and gut to re-attach making sure you do not get any glue on the underside if the switch which should be mounted completely flush with the drum pad. I’m not going to give a step by step for these fixes because its already been done a hundred times but here is a link to a great video step by step that will walk you through. http://www.youtube.com/watch?v=-2QhEVER3ag if link does not work simply cut and paste this URL into your web browser.
Aug 06, 2009 | Microsoft Video Game Consoles & Games
Orange drum not responding when hit
take a look in the box with the paperwork. you should have recieved a card or insert from the manufacturer regarding what to do if the unit has a problem. if this card is there, then they may be able to just do an exchange on the drums allowing you to play with the rest of the instruments.
Mar 17, 2009 | Video Game Consoles & Games
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
