We have a rheem heat compressor pump manufactured 08/2004. compressor is not coming on. Had a tech come tonight, he said compressor is bad and a new one is very hard to find so we should look into buying a new unit. Also we have a 5 year warranty which he said is no good because it starts from the day the unit was purchased by the contractor. We purchased this home new in sept of 2005.Any advice you can give would be greatly appreciated. also both fans inside and outside are working, it has plenty of freon but blows warm air.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 58 Answers
Check your yellow pages find a contractor who will offer free second opion on compressor failors, better yet try to find one that is a rheem dealer. If the compressor does turn out to be bad he can turn in the model and serial # to find the installation date. In most cases warranty info does start day of contractor purchase unless owner fills out and mails in warranty card. But neverless warranty ticks away while house sits unsold. Compressor does not have to be a direct replacement most any brand of compressor ( of proper capacity) will work in there but may have to do a little retrofit. Should be no problem. As for price replacing a compressor is very expensive. About the most expensive thing to replace. It is definetly easier and quicker to just change out the unit. Get a few quotes keep in mind after replacing comressor some other part of unit could go bad costing more money.
Posted on Oct 07, 2009
Testimonial: "We did get a Rheem technician and you were right.also we called Rheem and were told our warranty is good til Feb 2010. Will cost abt $600 Thank You!!!"
Heat Pump Blowing Cold
Unless you just installed or had the thermostat installed recently, I would not point at the thermostat as the problem. With what you have described I would suggest have your units serviced as it sounds like a loss of charge, or failed defrost control board. The "Aux" comes on when the unit is using secondary heating (electric heat strips). That occurs when the demand temperature (what you set it to) in Heat mode is more than the current room temperature, usually ~2-4 degrees higher. Also happens in defrost mode. Defrost is a heat pump cycle that melts any build up of ice on the condenser unit (outside unit). That process is simply the unit running in cool mode which will heat up the outside unit to melt any ice. Defrost cycles vary with manufacture but usually you can tell if is in defrost by looking at the outside unit, during defrost the unit will be warm or hot sometimes there is steam and the compressor will be running but not the fan. Defrost only happens on heat pumps in "Heat" mode. Rheem has a 10 yr compressor and parts warranty, so call the installer or Rheem authorized service company.
Nov 11, 2013 | Honeywell RTH7600D Touchscreen 7-Day...
I have a Rheem rpmc-042jaz heat pump (scroll) that has a bad defrost board (47-21517 - 16) The defrost board was bypassed by a service tech to allow cooling but no heating and I'm now trying to install a...
trace the wiring of the reversing valve.. its an electromagnetic relay in the middle of a cluster of tubing near the compressor. depending on its normal state when un-powered (normal heat or normal cool) the tech may have simply disconnected the relay (normal cool), or connected it directly to the call-for-cool line (typically yellow) (normal heat) regardless of heating or cooling, the compressor always runs the same direction
Oct 31, 2013 | Heating & Cooling
Heat pump kicks out for "Low pressure switch open." Indicated by the leds on the defrost control board Happens 2 times and then shuts down for " Low pressure lockout"
Have you checked the pressures? if you have is it just the suction pressure low or are both the suction & the head pressure low? you could have multiple things cause that ex. low in freon, restriction, bad low pressure switch, bad board. If you don't know what your doing call a service tech. the LOW pressure lockout is a safety to prevent damage to your compressor.
Oct 15, 2013 | Ruud Defrost Control Board 47-102684-08...
Outdoor fan does not come on
most likely it the the cap that is bad. Is this in heating or cooling mode?
Jun 03, 2010 | Heating & Cooling
Heat PumP: Rheem Two Stage Heat, One Stage Cool Thermostat Replac
R = R with jumper to RC hot side of transformer
B = Reversing valve
Y = Compressor relay
G =Blower
C = common on transformer (X on old t'stat)
W2 = Auxillary heat
E = Emergency heat
Mar 04, 2010 | Heating & Cooling
Hello, I have a rbha-17 electric heat system. My
the orange or blue wire should go to the heat pump and energize the reversing valve and the compressor should be running when the heat pump is on. All it does is reverse the flow of refrigerant and pull btu's from the outside air and deliver them to your house. Check to see if your aux. heat is coming on with the heat pump. If it is electric furnace, this will help explain why your bill is so high.
Jan 13, 2010 | Ruud UAMB042 Air Conditioner
Rheem Heat pump 5 ton heat strip 10KW what
I would say this is around 75 amps of draw at max for both the compressor and heat units. . Therefore--at least 90 amp breaker, and probably 100 amps for good measure, and at least #4 or #2 wire to the unit.
Oct 09, 2009 | Heating & Cooling
Condenser fan wont come on nor will compressor I do have fan op
Thanks for your Question,
First thing to check is the breaker in the panel to see if its tripped, I would suggest turning to off, then back to on, if it trips right after you have a short, if not you will need to check your fuses at the disconnect, first, shut the breaker off to the condensor, then pull the fuses and Ohm check them, if you have no reading then one or both is bad, I would recommend replacing them both if thats the case, if they check good, then you have bigger issues with your heat pump, if these suggestions do not work let me know and I can go into more indepth proceedures with you on what to do, thanks again,
mr.grzz
Jan 25, 2009 | Rheem 81VP15S Point-of-Use Electric Water...
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
