Question about Pioneer AVIC-N1 In-Dash DVD Multimedia AV Navigation Receiver Car Video Player
I have the REC Nav system in my chrysler 300 Touring.It will not start out on the route but instructs me to ''proceed to highlighted route''The highlighted right is not even visible unless I zoom out a considerable distance.No turn by turn until I reach the highlighted route which is usually miles away.Same thing at the end of route,turn by turn goes away miles before destination.only highlighted route is seen.
My navigation 'set destination' and 'route info' are greyed out so I cannot enter addresses in it
I would try the upgrade again and if that fails contact the dealer to see if there is a problem with the disk or a bulletin about the issue for your year and model.
Jun 14, 2016 | 2006 Chrysler 300
Nuvi 2455 portable GPS sat nav. Why no voice direction instructions?
You are off road or on a road that is not in the street database.
Jan 23, 2016 | Garmin GPS
How to get engine light off with code p0455 for my chrysler 300 2006 touring
code p0455 refers to evaporative emission (EVAP) system--large leak detected===causes--hose connection/s--intake leak---EVAP cannister--EVAP canister purge valve
first check that the filler cap is on correctly ,tight and sealing
Jun 26, 2015 | 2006 Chrysler 300 Touring
Touch screen frozen on my chrysler 300 touring 2010
This would be a diagnosis for a Chrysler tech at a dealership as they would have the correct test equipment and training to diagnose.But if I were to guess my first thought would be the telematics module.
Apr 08, 2014 | 2010 Chrysler 300 Touring
2008 chrysler 300 touring
if it happens to be one with a chipped key that is where I would start replacing it
Feb 04, 2014 | Cars & Trucks
How many valve lifters do a chrysler 300 touring have
I have a 2006 Chrysler 300 touring. Ron Carter told me they have 12 on each side of rocker so 24 in total.
Sep 28, 2012 | 2006 Chrysler 300
2006 Chrysler 300 Touring will not start
sounds like a dead battery & bad alternator
Jun 28, 2012 | 2006 Chrysler 300
How do you open door guidnace CD in a 05 chrysler 300
  • 1
    Turn the ignition switch to "ON" or "ACC."
  • 2
    Press the "NAV" button on the center console, and tap "Accept" to open the navigation menu.
  • 3 Tap "Destination Entry."
  • 4 Tap "Street Address" to input a destination. If you would like to choose a point of interest, tap the "Point of Interest" option.
  • 5 Tape the option to "Input Street Name In." If the current state or country is not correct, tap the "State" or "Country" button to change it.
  • 6 Type the street name, then tap "List" to choose your street.
  • 7 Input the house number for the address, and tap "Continue."
  • 8 Input your city name, and tap "Continue." The navigation system will calculate the route and display a map.
  • 9
    Tap "Go" to activate route guidance. The system will give you turn-by-turn directions to your selected destination.
  • car headlights.
Jun 01, 2012 | 2005 Chrysler 300
Pioneer AVIC-N1 In-Dash DVD Multimedia AV Navigation Receiver Car Video Player Logo
160 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
