Question about Frigidaire Gallery GLHS66EJSB Stainless Steel Side by Side Refrigerator
THE TEMP IN THE REFRIGERATOR SIDE IS AT 60 AND BEEPING EVERY FEW MIN
  • heldrn Oct 07, 2009
    WHAT CAN i DO RIGHT NOW, IT IS TO LATE TO CALL A REPAIR PERSON
    President:
  • 1,653 Answers
In side by sides if the fridge side not working correctly it means that the air vent from the freezing unit has stuck in the closed position which causes the fridge to not be any where near as cool as it should be and if it is too cold then the vent is stuck in the open position. The vent is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up, which can be caused by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. Best call a service engineer asap.
Posted on Oct 07, 2009
  • 11,896 Answers
Temp sensor of control is faulty.
http://www.acmehowto.com/howto/appliance/refrigerator/check/tempcontrol.php
copy and paste this link in your address bar for info on testing these. and feel free to ask me any questions.
I have a frigidaire side by side model GLHS37EHSB7 refrigerator makes a continuing beeping sound what could be wrong?
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 11, 2015 | Frigidaire Refrigerators
Flap won't stop humming buzzing
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Oct 07, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
Beeping sound
depends on why it is beeping usually then only beep when a door is open too long or temps too high
Dec 01, 2013 | Samsung RS2534 Side by Side Refrigerator
SAMSUNG RS275 REFRIGERATOR SOLUTIONS
Yes. check the thermostat. mine done the same thing.
Sep 01, 2012 | Samsung Refrigerators
Refrigerator make five beeps every 1 min
Have you got the manual? Sounds like a warning for condenser cleaning or water filter replacing.
May 27, 2012 | Frigidaire Refrigerators
If a kenmore elite door stays open does it turn off
yes it does for temp protection but when closed it should start back few min. after that.
Feb 22, 2011 | Kenmore 53642 / 53644 Side by Side...
Refrig temp 60 freezer icing up
Well, maybe this will help you...I had the same issue a couple of years ago with mine. The tech took the cardboard panel that is at the bottom of the back of the fridge and pulled tons of lint (and dog hair) out from inside where the compressor is. He told me that this has to be cleaned out every few months or else the compressor can't work correctly. It took a few hours before the temp came back up. Hope this helps.
Mar 29, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Feb 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Frigidaire Gallery GLHS66EJSB Stainless Steel  Side by Side Refrigerator Logo
41 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
