I was using Vinyl_V700b sound driver........but now it doesn't work after getting a virus which is fixed now
    Problem Solver:
  • 16 Answers
Reformat your system that's all it takes. That virus is very strong to disable your sound.
Posted on Oct 07, 2009
  • dench_manaba
    dench_manaba Aug 31, 2014
    download driverpack solution to fix all your missing driver..
How to transfer vinyl to cd-simply-I have manual but very confusing-simple step by step needed-thank you-Al B
The popular recording software known as Audacity is a good choice for getting all sorts of sounds saved in a digital format. The easy-to-use features of this program will help you to create complex musical compositions, or just record incoming audio streams. One of the basic things you can do with Audacity is to record sound from vinyl records. Many people still keep vinyls on hand, though the production of this medium has diminished. Here are the basic steps that will help you to use Audacity to record vinyl.
Steps
  1. Get your phonograph or record player. Assemble your collection of records and make sure that your record player is in good functioning condition.
  2. Use a cable to connect your record player to the computer with Audacity installed on it. In order to record from vinyl, you'll need to make sure you have accurately connected your record player as an incoming audio stream into the microphone jack of your computer.
    • Use hardware adapters to secure your cable connection. Many older record players utilize a 1/4-sized input jack. The modern laptop computer, as well as many desktop models, use a smaller, 1/8-sized input jack. You can buy simple adapters at your local electronics store to fix this problem.
    • Make sure that your cables and adapters support stereo.
  3. Open the Audacity program on your computer. You will see the signature Audacity screen, with controls at the top, and an empty space to accommodate created tracks.
  4. Start playing the record on your record player.
  5. Hit the red circle that represents the "record" button in Audacity.
  6. Observe the sound coming into Audacity. You should see the track being populated with sound, represented by a fluctuating line as the cursor moves along.
  7. Hit "Stop" to stop the recording.
  8. Stop the record player.
  9. Repeat this process with the entire track. Reset the record player, start playing and hit the Audacity "Record" button again, allowing the entire track to populate with the sound of the vinyl record.
  10. Save your project in your desired format. Audacity supports a number of file formats for the finished product. You can select one of these when you have recorded the entire track. Make every song its own track, or simply record the entire side of the record on one track.
Aug 26, 2015 | Audio Players & Recorders
How to fix sound
Buy a new hardware or check the sound is not disabled. Right click on the volume icon in the system tray and check the playback devices.
If that is working fine then check drivers for the hardware you are using, is installed on or not. get the compatible drivers for the hardware you have.
Jul 14, 2014 | VIA Technologies VIA Vinyl AC'97 Codec...
Crosley CR249 warped table
Sounds like you need a new platter. Has the platter worked OK before or has it always been like this?
I suspect you might have to contact Crosley to see who supplies parts.
Jan 10, 2013 | Crosley CR249TA Turntable
I did an installation and after the installation the sound did not come.
Try removing your sound card drivers restart system and re-install them if this does not work then it sounds like the virus has not been completely terminated with the method you have tried as just reinstalling without fdisk and format is just writing the information over the top of the virus and not removing it.. My suggestion is to fix this is, fdisk your hard disk and reset the MBR ( Master Boot Record ) and to repartition you hard disk format the drive this is a must before you can use the hard disk again and then try a re-install of your O.S and all drivers for your system. If this has worked then great you should be clean and clear, If by the off chance that it does not fix the problem then it is a case of using a virus scanner of some sort to disinfect the virus. I personally use Norton 360 Version 6 and find it very helpful with viruses etc. If after all this and the problem still exists it could very well be that the virus is attacking your hardware and these are the most dangerous form of virus you can get as they slowly but surely take control of your hardware and without professional removal it will eventually render your system completely useless. I hope this helps.
Sep 25, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
I got a couple of virus infected my PC a week ago (Essential Cleaner & MS Removal Tool). I had to download instructions on how to remove such virus on the internet. I managed to remove the first virus...
Even if you remove a virus, most of the cases, the damage cannot be repaired. Remove the sound driver and install it once again. If that doesn't work, you should consider reinstalling the OS.
May 24, 2011 | Microsoft Windows XP Professional
I HAVE A PACKARD BELL EASYNOTE ED1 AND IT RUNS ON XP PROF. I AM LOOKING FOR THE FOLLOWING DRIVERS:1 1. MASS STORAGE CONTROLLER 2.MULTIMEDIA AUDIO CONTROLLER 3.NETWORK CONTROLLER 4. PCI MODEM 5. VIDEO...
For the chipset drivers go to: www.intel.com there, you can search for the intel 852 / 855 chipset drivers. they also have the video controller driver ( Media Graphics Adapter ).
For the audio driver go to: www.viaarena.com there, search for the vinyl drivers there's only one listed. the version is v700b.
For the wireless network adapter you can search for the 2200BG driver on www.intel.com
As for the mass storage controller: it's a PCIxx21 flashmedia controller from Texas Instruments. search for the drivers at www.driverguide.com it may be neccesary to sign up. driver id = 869508
for the modem download this:
http://www.conexant.com/support/files/HSFac97_WinXP.zip
it's a conexant AC97 modem.
good luck.
Aug 30, 2010 | Computers & Internet
Virtual vinyl 6 64 bit driver
i have virtual vinyl and have the interface box , it will not read on a 64 bit laptop on windows 7 , do i need to buy the dj /io box for it to work ?
Sep 24, 2009 | Numark DJ/iO Sound Card
Vista Black Edition 2009, Audio driver not wrkng. Suggest best 1?
May be one of missing file, can i get the device ID of the sound card??
May 02, 2009 | Intel D945GCCR Motherboard
Computers & Internet Logo
652 people viewed this question
David Payne
David Payne
