Question about Polaroid Televison & Video
TV turns on...displays Polaroid then shuts off. Sometimes i can't even get it to the Polaroid point just turns on and turns off.
You have a bad power supply, call a local tv repair man 2 fix it for ya. Unless you think you can do it urself, but recommended a professional takes a look, dont want to damage anything else in the tv or hurt urself
Posted on Oct 07, 2009
Testimonial: "Bad power supply....got it! I will be calling Mr. Fix It, thanks a lot!!"
Hdtv 27" screen polaroid model 2700 , problem is
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions. It is the "Noise" that gives it away, among other things.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
Nov 15, 2010 | Polaroid Televison & Video
Does Not Stay On
When you insert the card and get the CHA Flashing error, remove the card and format it. Reinsert it again.
Should work.
Oct 16, 2007 | ViewSonic VPW505 50 in. HD-Ready Plasma...
37" Polaroid HD LCD black display but appears to be "on"
The power supply board was having problems before.That the board,where the power a/c cord plug into it Now might also the Tuner board are dead too.The tv Tuner board,that the board where the tv broscast signal cable plug into it.That the Tuner board.Tries Websites like shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement to see if solved the problem,not probally will have to buy the refurbish Tuner board for the replacement too.
Jul 13, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
I have a polaroid tlx-04244b and just recently my tv had turn of by itself. the led stays on but the tv is blank. when i turn it off and on, the led is on but the tv shows the polaroid than blinks and shut...
I dont have a solution but I am serching for the same answer to your question. As I had purchased the same TV from wallmart and they did not give me the warranty, because as i was told by a manager that they do not input the warranty option for BLACK FRIDAY PRODUCTS, which they do not willing offer as I have found out since with other products that have died. This TV had just suddenly turned off one day not even a year and a half after I purchased it and it flickers and stays black screen withg only the RED LED light on. PLEASE ANY HELP ON HOW TO GET THIS FIXXED WOULD BE GREATLY APPRETIATED!!!
Kevin
248-342-5213 text me if you know anyone that can give me a solution to this problem or point me in the right direction to get it fixxed as it cost 700$ and was a second tv...the SHARP I use in my living room which gets used 3 times as much is working and 2 years older then the poloroid. I RESIDE IN THE PHOENIX AREA IF YOU KNOW RESONABLLY PRICED TV REPAIR MEN. THANKS A LOT!!!
Apr 11, 2010 | Polaroid TLX-01911C LCD TV
I have a 46 inch polaroid lcd tv that when you turn it on everything is fine but after about a minute it starts making a loud squealing noise,even if you mute it, but it will stop after about 15-20...
my 46'' inch tv polaroid lcd has been working fine for 3 years. today my wife and I noticed the tv is shutting off the screen will go black and the power light does switch to red. you can here something inside the t.v clicking but you can turn it on and it will start back fine for 20 minutes then shut off again? Does anybody know whats going out on the tv? let me know
Nov 16, 2009 | Polaroid Televison & Video
Polaroid LCD tv - model TLX-04244 Shuts itself off...
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
If your TV is less then a year old, still under manufacturers warranty.
I service these power supplies, for more info write to jah2mil@hotmail.com
Dec 06, 2008 | Digimate DGL26 Television
Screen shuts off
It's supposed to shut off to conserve battery life. The camera will display on the tv screen instead. Make sure your tv is on the right channel for external source (ex/ video front).
Apr 03, 2008 | Polaroid CAA-03040S Camcorder
Polaroid hd widescreen lcd tv tlx02610b/03210b/04240b/04640b
are you sure the remote is working if you have a digital camera point it at the digital camera and the view finder in the camera will pick up the infrared light if the remote is working, if it is go to polariod .com codes and they will have the right one's if not you will need the remote its 28.oo plus tax and shippimg for a polaroid factory replacement. ordered from polaroid.
Dec 01, 2007 | Polaroid FLM-3225 32 in. LCD Television
Turn off
this happens to my tv as well it simply will just shut off and turn itself back on and then shut itself off every 2 - 3 minutes...can someone help??
May 24, 2007 | Polaroid FLM-2011 Television
Televison & Video Logo
1,035 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
