Question about Coffee Makers & Espresso Machines
La Graziella Espresso Machine is leaking at the lever. I need to find gaskets seals and a parts manual.
  • samshio Oct 09, 2009
    This machine was imported from Spain and branded as La Cara. It is also known as a Pavoni clone,
5 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: breville espresso machine 800 ES
http://www.breville.com.au/
Posted on Apr 02, 2008
  • 4 Answers
SOURCE: breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Posted on Sep 26, 2008
SOURCE: Alessi coban rs04 espresso maker
Hi All,
I had the same problem. There is ONE authorised dealer for Alessi in Italy. They are Arthur Eugster Italia srl, in Asti (Piemonte). I don't have the contact number, but my friend in Italy got a complete set of seals from them, FREE OF CHARGE (don't ask me how he got it) and sent to me in Australia. Good luck
Fulvio
Posted on Jan 18, 2009
  • 3 Answers
SOURCE: Need parts for Thermoplan Black and White CTS-2 espresso machine
I have parts for sale. You can contact me at lattefarms@yahoo.com
Posted on Feb 28, 2010
Coil sealant
HI you shouldn't use sealant. if the silicon seals are broken they should be replace, they are available from sellers on ebay.
May 22, 2014 | La Pavoni Coffee Makers & Espresso...
Why water drop before lever raised until top position?
\\this might be caused by a worn piston seal. see here how to replace seals.
dr pavoni
May 15, 2014 | La Pavoni Europiccola EPC-8 Espresso...
I need to pull up very ******* the lever for water to come out.
Again sounds like the seals are damaged and or need some lubrication and a service link below to a good site
dr pavoni
Apr 04, 2014 | La Pavoni Europiccola EPBB-8 Espresso...
Tengo un problema con la maquina rancilio classe 6E, el boton q tiene del agua caliente no funciona y activa la electrovalvula de agua caliente y deja pasar agua sin que active el boton, y se queda...
my spanish is not good but i think you have a the hot water solonoid valve is stuck open or has a piece of scale keeping it from sealing,if it is a manual valve the plunger gasket or valve seat needs to be replaced.
Sep 16, 2011 | Rancilio Classe 6 E 2 gr Espresso Machine
Espresso comes out of comes out of spout before handle is raised
Hi there, i am Mr La Pavoni and am based in Glasgow, Scotland. I service and repair these machines all day every day and basically it could be a couple of different things. If it is pre 2000 then it could either be the piston gaskets or the piston shaft has come slightly unscrewed from the piston head. If it is post 2000 then it could be any of the above but also in these models there is an additional sleeve inside the group head which may be cracked or the seal on this part may need replacing. It could even just be a tiny bit of debris on one of the piston gaskets. If you have removed the shower plate and gasket and then taken out the piston assembley then you should really replace these gaskets anyway. You can purchase the parts on my website www.theespressoshop.co.uk which are all individually priced and every part is available for the lever machines. If you require any further assistance then please do not hesitate to get in touch at domesticespresso@live.com
All the best
Mr La Pavoni
May 14, 2010 | La Pavoni Europiccola EPC-8 Espresso...
On a La Pavoni europicola which way do the piston seals get installed, both the same way or opposite to each other?
Normally on lever machines the top seal sits with the cup area(slash in gasket) facing up and the bottom facing down.
May 16, 2009 | La Pavoni Europiccola EPC-8 Espresso...
Water leaking from the group
You can buy a service kit for your machine at www.theespressoshop.co.uk and that contains all replacable gaskets and washers and gives you an exploded diagram and sachet of grease and descaler to get your machine back in as new working order. The service kit you require is the "old group service kit" and is about £20. If you go to the website above and click on the la pavoni machine on the right hand side of the home page it will give you the full parts list.
All the best
LaPavoniBoy
Feb 18, 2009 | La Pavoni PC-16 Espresso Machine
Turn off machine at night?
Turning off an espresso machine at night is a bad idea. There are many gaskets and seal's that mate to different types of metal surfaces all of which contract and expand at different rates when hot or cold. If you keep doing this you will eventually break the seals.
Jan 02, 2009 | Espresso RMI La Cimbali Espresso Machine
Coffee Makers & Espresso Machines Logo
175 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
