Refilled 926 black cartridge but pc does not recognize as full
  • A Miller May 11, 2010
    All I can tell you for certain about this topic is I have never had trouble with manufacturers original replacement cartridges. I have ruined no fewer than three otherwise good printers by saving a couple bucks on ink.
    President:
  • 2,600 Answers
The electronics on print cartidges are only good for a limited number of refills if any, they then will sometimes not be recognised or report the incorrect amounts, or not properly align....and this goes for aftermarket discount cartidges as well.
Posted on Oct 07, 2009
SOURCE: machine does not recognize refilled office max cartridge (black)
sir,
try to clean the cartridge on the copper side with tissue with and alcohol maybe the contact points doesnt meet or the cartidge itself is already defective. try also use an empty good cartridge just to to determine wich cartridge is defective.
yours,
alecz
Posted on Apr 23, 2008
SOURCE: x5470 Lexmark printer
Just unplug the printer from the back and plug it back in. Problem solved. I did this on my mother's printer and it worked like a charm for this same error msg and issue.
Posted on Jul 07, 2008
SOURCE: Dell 926 Printer ink refill instructions
gently push a wooden cocktail stick in each hole and it will tell you. Presume the 926 cartridge are all the same and on mine the bottom left hole is yellow, bottom right is cyan and top is magenta
Posted on Oct 28, 2008
  • 52 Answers
SOURCE: refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
Posted on May 05, 2009
  • 1335 Answers
SOURCE: Won't recognize the cartridge UO43 error
Do you have another cartridge you can try. This sounds like a defective cartridge. Thanks.
Posted on May 06, 2009
My Dad bought new ink cartridges ( black and color) and installed them in the printer and it is not registering that they are installed. What are some things I should check for and how can I fix this????
After installing new ink cartridges in your Dell all-in-one 926 printer, you may receive an error message telling you the print does not recognize the new cartridges. Refilled or third-party cartridges, which Dell does not recommend using with the 926, often trigger the error message. You may also receive this error after you have been using the same ink cartridges for some time. Whether the cartridges are new or not, the error can be caused by a number of sources. Following the steps below should clear up print cartridge problem.
  • 1
    Open the Dell 926's front cover with the power on and wait for the cartridge carriage to come to a stop. Remove the ink cartridges by pressing on the tabs at the top of each cartridge. Check the cartridges to make sure you have removed all of the blue protective plastic film. Look for the "Dell" logo stamped into the cartridges' lids to ensure they are genuine cartridges.
  • 2
    Clean the shiny metal portions of the ink cartridges with a damp microfiber cloth. Allow each cartridge to dry completely.
  • 3
    Clean out any paper, staples or other debris that you may be able to see, then reinsert the cartridges into their appropriate slots. Put the black ink cartridge into the left slot and the color cartridge into the right slot. Make sure both click back into place.
  • 4
    Close the Dell 926's front cover and turn off the printer. Unplug the power cord and USB cable from the printer for five seconds, then reconnect them.
  • If your Dell 926 fails to recognize the print cartridges after following the above instructions,
    take it to a repair shop for servicing.
    Good Luck and Happy Printing
    Jan 26, 2011 | Dell 926 All-In-One InkJet Printer
    *see the manual and follow the instructions and fill it
    * contact manufacturer about details
    Jul 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
    I just had my cartridges refilled but my printer still says low ink i used my old cartridges from dell how can i get my 926 printer to work with the refilled cartridges it will not print.
    With this type of cartridge your printer will always think refills have low ink. This is because the electronics on the cartridge cannot be reset to tell the printer it is full of ink. However you should still be able to print and just ignore the ink levels. I think the problem you are having is that the electronics on your cartridge are no longer functioning. Unfortunately there is no way to fix this problem. I know you can buy refills from Cartridge World stores, but I don't know about other retailers.
    Jan 17, 2010 | Dell 926 All-In-One InkJet Printer
    I filled my 926 cartridge but the computer but my info window on my computer doesn't recognize it as full and will not operate it. Put in a new cartridge and it works fine.I used to have an Epson that...
    yes, they both work on the same technology. if you get it refilled. it will still show as empty but you cna take prints. actually the cartridge is empty, but you have refilled it. so the cartridge doesnot know that there is ink. you cna use the cartridge but it is highly recomended not you use it. becasue it can also blow up your printer. i have seen cases in which people refill the cartidge to save money but it cost them a printer. so you better not do it. replace the cartridge. dont refill it.
    Oct 13, 2009 | Dell 962 Photo All-In-One InkJet Printer
    Dell 926 won't recognize new color cartridge
    Try this...shut down the printer. Insert new cartridge, let the printer cycle out with new cartridge. then reboot the computer. This should solve the problem. The cache in the printer will not cycle out. It wants to see the printer as a new entity
    Jun 17, 2009 | Dell 926 All-In-One InkJet Printer
    Lexmark x5470
    Let the ink settle in the cartridge for awhile. Make sure no ink is on the outside of the cartridge which adversely effects the signal to the printer.
    Apr 14, 2009 | Dell Dimension 4500 + Lexmark Z35 Printer...
    Dell 926 injection refill kit didnt work
    The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
    Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
    Canon ip1200 black cartridge wont recognize after i refill
    Dear lim,
    Here a solution for you. The cartridge of this printer has memory chip that store ink level data inside. Once the cartridge is empty we cannot restore ink level data to be full. To continue using refilled cartridge you need to deactivate ink level detection function first. Perform this step: when the message 'The following cartridge cannot be recognized' appears press Resume/Cancel button. Do this for each cartridge you refill;if you refill both black & colour cartridge do this tip two times (once for each cartridge).
    Please rate this as fixya ok.
    Regards,
    Dec 02, 2008 | Canon PIXMA iP1600 Printer
    Go to this webpage: http://www.ldproducts.com/Dell-Ink,Photo-all-in-one,926,Ink-Cartridge,3234,printer.html Click on the links for InTec Refill Kit for Dell MW175 Black and InTec Refill Kit for Dell MW174 Color. Scroll down to Specifications and click on the Instruction Video link for each. That should help some.
    Feb 25, 2008 | Dell 962 Photo All-In-One InkJet Printer
    44 people viewed this question
    k24674
    jasbo
    jasbo
