Question about Dryers
I need to know how to take the drum out of the dryer Maytag neptune I've taken the front off, Raised the top off... Now what do I undo the belt and lift it up or slide it out toward the front??
  • Dryers Master
  • 8,404 Answers
Move the front to the side ... the drum will almost take itself off. Normally, the drum rides on the front door opening.
There are nornally two wheels in the rear
good luck ... it is easher than you think. tuff part is getting it back together without a band aid :-)
Posted on Oct 07, 2009
How do I change the drum belt on maytag Neptune dryer
have to remove the whole front section including door the top will flip up after u remove front and screws which were hidden until u removed the front section
Oct 12, 2014 | Maytag Neptune MDE4000 Electric Dryer
Maytag Neptune Electric Clothe Dryer Model MDE6700AZW Problem: Drum will not turn, no heat produced. When I start the cycle, there is one audible *click* sound and then nothing: no heat and no tumble....
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Maytag Neptune MDG9700A Gas Dryer
The beater bar in my Neptune dryer modeL # MED5500AYW has come off and needs to be replaced.
It sounds like you are referring to the drum baffles when you say "beater bar". If that is so, you need to remove the front panel then raise the top cover to access the baffles mounting screws outside the drum. Below is the link to the procedure I posted previously.
Maytag Neptune Dryer Front Panel and Top Cover Removal
Sep 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer
remove the 2 kick panel screws near the front panel by the floor swing the front panel upward and the top clips will release,then remove the 2 hex head screws under the top cover then swing the top cover up like a car hood and secure it so it doesn't fall and pull wires out,then remove drum and restring belt and then around the drum then around the tensioner and reverse the above procedure
Apr 15, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE3000 electric dryer replacement of belt
The top comes off then the front panel is next.
remove the drum by pulling it out to replace the belt. replace the tensioners pully as well for it has a bearing that wears out then squeals loadly when old and dried up
Mar 27, 2010 | Maytag Neptune MDE4000 Electric Dryer
My dryer is making a high pitched squeal?
it could be the rear drum bearing,the front drum glides/rollers or the drum belt is glazed,or the tensioner for the belt needs replacement,all of which require you to remove the front cover by removing the lower front panel screws near the floor, then lift up front cover like a car hood and there are spring clips that will let go, then remove top cover these screws are underneath top cover in front and you can replace those items
Nov 13, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Sounds like I have a coin in the neptune dryer under one of the fins inside the drum. how do I get it out?
Disassembly of the front and top of your dryer can be found in the Service Manual at the link below beginning on page 9-1. Once the top is raised turn the drum slowly clockwise until the screws for the vane you wish to remove are at the top. Loosen the screws just a few turns and turn the drum until the coin or article falls out. Repeat for each vane until you find the noisy object. Reverse the disassembly to reassemble.
MDE5500 Service Manual
Oct 04, 2009 | Maytag Neptune MDE5500AY Electric Dryer
MDG4000 maytag neptune dryer.... When you push start, I see it has power by the light that flashes, but the dryer doesn't start. What is wrong? Thanks
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 13, 2009 | Maytag MDG4000 Dryer
I HAVE A THUMPPING NOISE AS THE DRUM TURNS.
your thumpin noise is most likely a flat spot on your drum rollers. open the door and remove the 4 screws ( 2 on either side ). this will allow you to take the front panel off. after that is removed, there are 4 3/8 nut screws that hold on the front bulkhead. remove those screws and lift up on the bulkhead to remove ( note: you may need to remove the 2 nuts screws and brackets that secure the top so you can lift the top up ). after removing the bulkhead, you will need to undo the belt ( easiest if you do it from the back ) and take out the drum. your drum rollers are on the back of the dryer on the bottom. you can visually inspect them and if they are bad, they will need to be replaced. Joe
Nov 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
Top Dryers Experts
