Question about Asko Dishwashers
Newly installed ASKO D5132. Top draw slides
The top draw slides forward as soon as the door is opened.
If it is pushed back into place it just keeps sliding forwards.
Rotu
  • 175 Answers
SOURCE: Top Rack always slides out fully
Well, you are right on about the level. It is tilted just slightly forward. The only parts to go bad are the plastic ball bearing guides, and usually when they go, you get a rack that wont come out and gets jammed. You 've got the problem, you just need to remove the screws hidden in the holes that are sometimes coverd with rubber plugs so that the dishwasher may move freely, andjust it till it no longer rolls out, then screw it back to the counter to hold it in place. There are no springs in that rack, so either its still tilted forward, or the tank is bowed or bent somehow, and that would mean new dishwasher. Hope this helps!
Posted on Jul 18, 2007
ngfam1
  • 639 Answers
SOURCE: Asko D1996
Peace friend,
ngfam1 at your service
It is the stops .
You can call this parts house and they will help you figure out the part #'s. If they have them in stock they will sent them usually in one day.
or you can see the parts in the user manual too!
Discount Parts
Major Appliance & Consumer Electronic Parts. TOLL FREE 1-(888)-338-3790 8:00AM - 12:00 MIDNIGHT 7- DAYS A WEEK
How old is the appliance?
If it is 9 years old or more it may be putting god money into bad!
The new ones pay for them selves in a few years on the savings of energy, and water because they clean better with less water!!!!!!!
A much better n you electric bill!
If you need a good repair Here is who I recommend nation wide.
A&E Factory service open 24/7 for appointments!
1-800-905-9505
Ngafm1
PLEASE GIVE ME THE BEST RATING BEFORE YOU SIGN OFF! BLESS YOU
Posted on Aug 31, 2008
  • 382 Answers
SOURCE: The top rack on my Asko D1796 dishwasher is defective
call manufactuerer and ask or a good appliance parts and repair they usually are on a spring clip and you just replace the whole roller
Posted on Dec 25, 2009
Macmarkus
  • 2605 Answers
SOURCE: top drawer
Hello, Welcome to FixYa. Based on the info you provided it's likely a pretty easy fix. The machine is leaning forward slightly and it shouldn't be. Remove the top screws fastening the machine to the counter...if applicable, some are on the side if granite counters or similar exist etc. Then take off the lower kickplate/access panel and screw the front leveling legs down ( which will cause the tilting of the machine back slightly ) and screw the back legs up, hence the rack should no longer slide out on it's own. There are also locking nuts for the legs so make sure you loosen amd re-tighten them in the process. Let me know how you make out. The most difficult part will likely be the removal and replacement of the toe panel/kickplate. Good luck, Macmarkus :)
Posted on Aug 02, 2010
Testimonial: "I tried to relevel in the past, butdi not know about the upper screws at the granite, so will start over, thank you."
  • 205 Answers
SOURCE: on 2 door dishwasher model DD603 bottom draw is
Hi- Most likely the lid is stuck in the down, or partially down position. This is usually caused by the lid actuators (motors) not returning the lid to its full up position and therefore the drawer top is dragging on the lid gasket. Replacing the lid actuators should resolve the problem. You'll need a F/P tech to change those for you. Hope this helps.
Posted on Sep 24, 2010
ASKO 1375 Dishwasher top rack keeps rolling out
Your dishwasher may have sagged since being level when installed.
May 20, 2016 | Asko 1375 Dishwasher
How do I balance dishwasher so drawer doesn't slide out
You need to level your dishwasher - extend the front leveling legs, or shorten the back leveling legs (if your dishwasher has rear leveling legs.
Sep 20, 2014 | Asko Dishwashers
Power cannot be turned on. led display not on
Check that the draws are closing properly and evenly , there is a door sensor just inside the frame top and bottom on the right side .
If thr machine is not level the doors can slide forward.
if this does not work , feel if the draw really locks in when closed because at the back of the draw slides on each side are two plastic lock mechanisms. when the draw has been out they need to be upwards facing so when closed thy lock the slides in on both sides . Sometimes thy only lock in one side causing it not to deactivate the door sensors and shut down .
Yes it sounds simple, but most problems i have found are
Feb 03, 2014 | Fisher and Paykel DishDrawer DS605FDSM...
Top drawer
Aug 02, 2010 | Asko D1706 Built-in Dishwasher
Asko dw 95.2 model 1705 after 6 years of use the dishwasher top drawer rolls out. Will not stay inside when main door is open.
Check the level and tightness of the slide rails--they may have come loose after the years of use. Make sure the dishwasher case itself is level. Hope this helps!
Jun 29, 2010 | Asko 24 in. D3250 Built-in Dishwasher
My door doesn't seal/catch when closing. Machine
If the door switchmechanism is still in place inside the door, you should be able to see it when you open the door ,it is visible on the inside if the door top centre if it is intact then it could be that the actuator bracket has moved, this is located under the top panel front centre and is held in position by an hexagonal nut. the top is secured at the back of the machine by 2 screws one on the left and one on the right remove the two screws slide the top to the rear approx 1/2 inch lift off the top you can now access the door catch bracket, close the door and adjust the bracket forward so that it latches securely but don't position it to far forward or it could bottom on the back of the door mechanism, if everthing is in place unit should be fixed, reposition top onto the two front lugs and slide top gently forward replace the two screwws at the back and you should be in business
Apr 29, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Need to open the electrolux vacum
The locking key on the side of the vac has a tightening wedge on it so it doesn't slide easily. Spray the entire key top and bottom with WD40 or similar. Grasp at the bag door area with vise grips and pull the key straight forward.
If the key will not slide, you will need to take a large flat bladed screwdriver and lay the blade flat at 90 degrees against the back end of the key. then strike the side driving the key forward toward the bag chamber door. Do not twist.
Aug 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Asko door latch stuck
The only way is to pull out the dishwasher ,unhook the latch and then unscrew the door panel.your dishwasher is installed with 2 screws to the underside of your countertop. its tricky but youll have to remove them adjust to leveling legs down this will give you more room to get some head bit in ther to remove the screws if its out then slide the d/w foward ,remove the strike plate door will open then you can get your dishes out first
Sep 20, 2008 | Asko D1706 Built-in Dishwasher
Jun 19, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Dishwashers Logo
187 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
