Question about Vector 2M Pwr Rch Spotlight
New sportspot won't turn on
I have charged my new flashlight - the lower tiny area light goes on, but the huge main light doesn't - any tricks to this? Of course I threw the owner's manual out. . . duh!
Hi, I had the same problem. Your battery is strong enough to power the little light but not the spot light. I connected a motorcycle battery charger directly tot he battery and the light worked. So, you like me, need a new battery as ours are bad.
Posted on Dec 29, 2009
I had the same problem. It was because the main bulb was burned out. Good luck finding a replacement bulb. I couldn't
Posted on May 25, 2010
  • 8,404 Answers
You have charged the device for a full 24 hours?
Is there a two position switch on the device??
Get a replacement owners manual at the manufacturers web site ... im confident.
Posted on Oct 07, 2009
How to repair SunLight Underwater Kinetics SL6 Dive Light
Corrosion is a problem! I found that WD40 with a hard bristle tooth brush sometimes does the trick. Clean the corrosion and check that it hasn't corroded completely through the coil or where it connects. Replace the batteries and try again. If it has a standard filament light globe it can be checked with a multimeter ( should show around 7 ohms).
Apr 04, 2014 | Underwater Kinetics Sunlight Sl6 Xenon...
DSI XL won't power on, but orange charge light is solid (doesn't blink) when charging.
dsi xl getting wrong voltage at plug that goes to the battery. I have 5.78 from charger at battery connections I have 5.78,3.87,0.45,1.98 it bounces all over any ideas?
Jan 25, 2013 | Nintendo DSi XL Console
Ac won't turn on heater ok all fusees an relays ok 2000 silverado
When you hit the button, does the light come on? If so, and there is no cold air try a freon charge kit with dye in it. These kits are relativly inexpesive and come with yellow glassed and a UV flashlight. Fill the freon and let it run for a couple days. Then using the glasses and flashlight in a dim area, look for splashes of green. THen you can get the oring or what ever is leaking, change it, then have a pro evacuate and re-charge the system.
Jun 02, 2012 | Cars & Trucks
Which flashilights you like?
yes you can there are lots of led lights to choose from now a day
Nov 10, 2011 | Home
Where can I buy or what store can i go to to buy a charger connection & adapter for my victor sportspot flashlight?
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service.
Sep 24, 2010 | Vector 2M Pwr Rch Spotlight
I had my mini Maglite taken apart and a small (tiny) metal part fell out....I found it but now I don't know how it goes back on ....it was somewhere near the light bulb area. John
There are 2 tiny clips that hold the bulb in and make contact with the rim of the barrell. They can be difficult to get back in without prying the plastic piece out of the end. Once you pry it out, it never works the same.
Oct 05, 2009 | MagLite Camping, Backpacking & Hiking
Area light works but not the spotlight
Check the contacts going to the batteries. The negative contact is
going the flashlight body. While the other starts at the center of the
bulb socket that goes to the switch and finally to the positive terminal
of the battery. Get it done and send an e-mail .
Oct 03, 2009 | Vector Camping, Backpacking & Hiking
My Vector Vec157 Flashlight won't Charge...
It is the battery, I have a similiar Vector light for a few years and tried re-charging the battery but only the little LED light would come on. I have another Vector light, same model and switched batteries from the worjking one to the non-working one and now it works fine.
I then proceeded to purchase a new battery for the non'working one and when I arrived home I installed it and turned on the main light, still won't turn on, I tried the LED's, they work. I figured maybe the new battery needs a good charge so I plugged the charger in and charged the light for 12 hours, still no main light.
I guess the new battery is defective, so now I will return it and exchange it for another one.
Aug 22, 2008 | Vector 20 Million Power Series Spotlight
Flickering LED flashlight
It sounds as if the connections in the back of the radio may not be continually connected to the contacts on the charging base. You might want to make sure that the radio is properly loaded in the cradle of the charging stand. The reason why the lights 'flicker' is because if your power goes out, the light on the radio will come on when it detects no power to the charging base. This is a feature to many new emergency radio gadgets. Imagine a storm rolling through your area and the power goes out in the middle of the night. Your Vector radio's LED lights come on so that you aren't searching for the radio in the dark.
Jun 23, 2007 | Vector VEC438 AM/FM/Weather Radio
Vector 2M Pwr Rch Spotlight Logo
365 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Lawrence Oravetz
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
