Question about HP CTO HP Workstation XW6200 Base (DY247AV#ABA) PC Desktop
Xw6200 gives 6 beeps but goes no further, suggestions? Can resetting the cmos back to default solve the problem?
    Scholar:
  • 105 Answers
On any type of desktop o laptop computer, you can access the BIOS settings by pressing at DEL key while it turns on (in some computers you will see a message on the screen after you turn it on displaying the right key to press in order to get into the bios settings.. from there you can look true the options and clear the settings and reset the machine to safe mode o factory settings.
If you can't get in any option at all you need to open up your computer, make sure the FAN on top of the CPU is working. it may gone bad and your computer is overheating. by default it will shut down after the beeps.
if the fan is ok, try pulling the memory ram stick off the slots. turn your pc on, see what is instructed on screen if there is any info.
iffter taking the memory ram modules off, if you have more than one try to just put one at the time and see if if boots up as normal. then just put the second on and if this cause a problem just remove the second memory module and it will be the answer to your problem
TERRY
Posted on Oct 07, 2009
6 beep codes on my alienware aurrora
I think you need to reset CMOS. in your bios to default values
Mar 07, 2014 | Alienware PC Systems Alienware Aurora High...
My pc works only when I reset CMOS
Hi, Some of your BIOS settings are not 100% acceptable/compatible with your current setup. I would suggest that you set everything to default, save and close/restart. Another thing you can check is if the Lithium battery needs replacement. Normally it should read 3.0Volts. If the above does not solve your problem, you can consider other things: 1. BIOS update by flashing; 2. Processor to motherboard compatibility - try underclocking your processor by lowering its FSB; and/or 3. Memory to motherboard compatibility - try increasing your latency Good luck and hope this be of some help/idea to you. Post back how things went or should you need further information. kind regards.
Aug 25, 2007 | Abit IN9 32X-MAX (IN9 32X-MAX WI-FI)...
I have 2 beeps apon startup. how do i reset cmos on optiplex 760
Open the back cover of cpu cabinet then reconnect RAM memory on motherboard there is 1 round cmos cell on motherboard pull it for 10 minutes then power up the comuter then put it back then all settings defaults.Then check.Also reconnect pci or vga card if any.
Make sure motherboard is not ground with cabinet .
Let me know if you need further assistance.
Thanks for using FixYa.
Oct 03, 2011 | Computers & Internet
How to reset the CMOS (BIOS) on an hp pavilion a622n
Turn the computer off....
Open the left side panel.
Find the CMOS battery on the system board.
Take the battery out and short the 2 connections in the round battery casing for 10 seconds.
Reinstall the battery and power up the computer. CMOS/BIOS should be at the default settings afterwards.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 20, 2011 | HP Pavilion a622n (PC108A) PC Desktop
Mobo fried? Beeps when startup but no video. I reseated ram and video card, with no luck. Both fans work and it sounds like it is booting. I tried older video card too but nothing. Thanks for any...
Try removing the display card and using the onboard VGA. Remove the BIOS/CMOS battery for about a minute and then reinstall it in the correct orientation. This will reset the BIOS/CMOS to it's default settings. You say it beeps once, this means that it is fine the mainboard is ok, it is not experiencing any problems. If it beeps in a continuous manner then it is the RAM that is causing the problems, I would say that the default settings may solve your troubles. Remember to enter the BIOS/CMOS when during boot up to reset the date and time by hitting the delete key. Also try entering the BIOS/CMOS even if you can't see any thing on screen, by doing this it may come up. let me know how it goes, I am here to help.
Thanking you
damnor01
Nov 09, 2010 | HP Compaq Presario SR5450F Desktop PC
Monitor won't come on..just blinks..
a common way to solve this is to put the BIOS into its defaults...
i.e, loading the BIOS with default settings..
to do this you need to open the case of your CPU then, on the motherboard there is a small battery called CMOS battery...
take it out and after a minute or so put it back...
in this one minute, the BIOS will get reset to its default settings...
you should now be able to work........
If this sol. helps please give a vote....
Feb 28, 2010 | Compaq Presario 1725 Monitor
Sir, I have Intel D485PEBT2 mother board.Whenever I do a cold start it does not boot.If I do CNTL+ALT+DEL it restart and boots.cmos battery is ok.date and time ok.I tried several times to change Boot...
I would suggest that you do a factory reset on your mobo. To do it, here are the steps you can follow.
1. make sure that computer is OFF and unplugged from the wall
2. locate the 3-pin jumper on the mobo that is near the cmos battery
3. once located, remove the cmos battery
4. then from the 3-pin jumper, if the jumper is connected to pins 1-2, switch it over to pins 2-3
5. return the cmos battery back
6. plug the computer back then turn it ON
7. you will probably get an option to reset or restore settings back to factory, it that's the case, continue with it
8. after doing so, turn the computer OFF again and unplug it
9 remove cmos battery then return the jumper to it's original position
10. put in the battery back then turn the computer on again
11. go to the bios and set it back to the setting that you have set it before
12. check and see if problem has been resolved
* I would suggest getting a new cmos battery if it's already old
Jon
Oct 16, 2009 | MSI MS-6547 Motherboard
HP Workstation XW6200 starts to power up and then just stops - will not boot
First open cpu cabinet.
Then Refix your RAM memory .
Reattach ATX power connector from SMPS to motherbord.
Remove pci cards from PCI slot.
Pull cmos cell from motherbord for 10 minutes so all motherbord settings are defaults.
Reattach both connection to harddisk.
Make sure your harddisk is detected in bios.
When you power up the computer press F1 or F2 or "del" key to enter in bios.
Then check harddisk is detected.
Let me know if you need more assistance.
Thanks.
Oct 04, 2009 | HP CTO HP Workstation XW6200 Base...
Hp xw6200, 6 beeps, and red power button...failed start up.
6 long beeps indicates that there is a problem with the memory, take them out, clean the contacts and the DIMM slots and reseat them.
Hopefully this will resolve the problem, if not new memory may be required
kind regards
Dec 12, 2008 | HP xw6200 PC Desktop
My Toshiba laptop just beeps when powered on
here is the link to beep codes:
http://www.computerhope.com/beep.htm
Nov 14, 2008 | Toshiba Computers & Internet
HP CTO HP Workstation XW6200 Base (DY247AV#ABA) PC Desktop Logo
717 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
