Question about ZT Group CISNET A7022 PC Desktop
I CANNOT SEE ANYTHING ON MY MONITOR THERE IS NO RESPONSE
  • Jay
    Jay May 11, 2010
    is everything plugged in? do you see all the little light turned on?
  • 523 Answers
Check your display setting, try to load into safe mode and adjust the display setting, also try to check the cable if it is connect good, and check your vga card if it is connect right on the board.
Is your computer gives any beeps when you turn it on? if yes, how many beeps? is it long or short? if there is no beeps your problem is only settings.
Posted on Oct 07, 2009
How can I troubleshoot an Asus monitor that won't display an image?
check you surface pro display setting.
check if it is enable to give signal to 2 display image of surface pro
Aug 31, 2014 | Computers & Internet
I have a lg monitor flatron w2353v and non of the controls are response any more. do you know anything? thanks!
clean its control with thinner using prush teeth be cureful monitor is crt not lcd if lcd is worong
Mar 27, 2011 | LG Computers & Internet
Monitor turned dark. Is there anything I can do to fix it?(Set Brightness All the way up, still to dark)
Sounds like you may have lost your signal. The only troubleshooting solution at this point would be to find a temporary monitor replacement and see if you get any response out of it. Know anyone who may let you borrow their monitor? If there is no response from a replacement you may have to put the 'puter in the shop.
Sep 04, 2010 | Computers & Internet
Hpvs17e white backround is pink
hucknannie, Power down the pc and monitor. Then disconnect and reconnect the VGA cable a few times to the rear of the pc. then turn system back on and re-boot. If your "PINK" screen still there, then you may need to have unit refurbished with new "cold-cathode-fluorescent-lamps" or have the internal "switch- mode-power supply/ccfl-inverter-supply" inspected and repaired. Yes, before you do anything, visit this web blog about HP monitors!!! http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Read and make note that people are still visiting the blog even after 4 years!! Hope this response helps. Feel free to leave a comment and also rate this response on fixya. 12fixlouie
May 03, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My monitor show me bright for 4 sec only
morinj_04, "Switch-mode-power-supply" going into partial shutdown mode. Read more of my BLACK screen and BLACK and BLANK screen responses in my profile. You will get the hint as to what to do!!!
12fixlouie
Jan 30, 2010 | ViewSonic VX715 17" LCD Monitor
I am having trouble when I first turn monitor on. I get a flicker of an image and then black screen. I have to do this multiple times and eventually it stays on. Anything I can do?
m_v_schwartz, Best guess is problem with unit's "switch-mode-power-supply" / "CCFL inverter supply" has a bad "cold" or "frosty looking" solder joint (thermally intermittant solder connection) on the printed circuit board!!! Unit WILL NOT fix itself!! Only you or a qualified electronics technician will fix it. Use your warranty first if valid option!!!! See more of my responses to other LCD black screen symptom OWNERS that I have replied to in my fixya profile. Know and understand the "FLASHLIGHT TEST" that every LCD owner should know how to perform when "black screen" shows up. If this response steers you in right direction, please return to rate this response on fixya. FYI, Also visit web sites I have mentioned in the other responses in profile. Good luck with the repair. 12fixlouie
Dec 25, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
My AL2223WD 22" turns on with a white screen, vertical colored lines, then shuts off. I can't access the menu or get anything to come up on the screen at all before it shuts off.
Try this :--
Try connecting your monitor to another computer and see the results.
If it remains the same, change the monitor cable and see the results.
Hope it helps !
Awaiting response.
Thanks.
Sep 08, 2009 | Computers & Internet
I cannot install my monitor
Need some more information...
what type of monitor is it? What connection type does it use?
do you get anything displayed on the monitor? if so what is it?
More information you can give, the better the response ;o)
Apr 16, 2008 | Computers & Internet
My monitor will either stay on and wont' turn off (even if you click the green button)
your Mnotitor Panel Switches gone bad replace all the switches and your monitor will be ok.
Ashok
Jun 08, 2007 | HP Compaq FP5315 15" LCD Monitor
ZT Group CISNET A7022 PC Desktop Logo
48 people viewed this question
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Kyocera HP Expert
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
