Question about Fisher and Paykel AeroTech - OS302M Electric Single Oven
F@p oven model 635 builtin
Door squeeks when oven hot
  • 38 Answers
Replace the hinges
Posted on Nov 22, 2009
Amica oven door gets so hot that my child has burnt hes hands and needed medical attention
Amica is a European brand, I recommend you contact the company headquarters or a competant local repair shop. Any oven left at a very high temperature for a long period of time gets pretty hot, though, and an eleven month old baby has pretty tender skin.
Jul 19, 2014 | Ovens
Noisy oven door hinges
Spray the hinges with some spray lube. This should help.
Dec 05, 2013 | Jenn-Air Ovens
I have an AEG competence 5020 B fan oven (single) which has a very noisey fan, does this need a new motor and can I fix this myself?
ISOLATE THE MAINS POWER BEFORE OPENING THE REAR OF THE OVEN.
Remove the oven, open the back, remove the fan, and clean with WD40, afer the fan is dry, fit the fan back into the housing, replace back and put into cabinet, switch on low, if the fan makes a whirring noise, or unusual squeeking replace the fan, if however the fan sounds normal and good pressure when door is open, it should be okay. If you require a part go to whitegoods.co.uk
Hope this is helpful
johnf1
May 17, 2011 | Ovens
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Indesit FIE 56 K.B GB oven The circulation fan is squeeking
The symptons you describe are typical of the fan motor bearings failing. you could try spraying the bearings with WD40, but this would only be a temporary solution, in the end you will probably have to replace the fan motor complete.
Hope this helps.
Jan 07, 2010 | KitchenAid KEBC101 Electric Single Oven
Replace broiler heating element Whirlpool builtin oven
do you want to know how to replace it? turn the power off first. open the door to the oven usually there are 2 screws that go to the broiler. unscrew them pull the heating element out remove the wires, make sure you pull them out far enough or you will loose them in the back of the oven. plug the new one in screw in the screws and you are good to go. let me know if this helps
Jul 18, 2009 | Ovens
Fisher and Paykel AeroTech - OS302M Electric Single Oven Logo
125 people viewed this question
Top Fisher and Paykel Ovens Experts
Dan Webster
Dan Webster
Joseph Hoffmann
Oloyede Monsuru
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
