Question about Nikon D70 Body Only Digital Camera
My Flash stop working, do i need to replace it? The built-in flash does not stay up. I can hear the clicking sound when it wants to pop up, but it stays in place. At this point it's pretty easy to open it manually, so I noticed what it seems to be a small spring on the right hand side. I guess it is there to hold the flash and it looks like it is off it's place. Is there a picture somewhere of how it is supposed to assembled? Thanks in advance, Gene
  • 667 Answers
I just checked my service info and do not have a good picture of the top cover. The top is sold as a unit by Nikon. An independent repairman may be able to repair the top if there is no damage. A work around would be to use an external flash. It would not have to be a Nikon brand, but you would have to set speeds and aperture manually to get proper exposures. Replacing to top cover would be more than 100$
Posted on Dec 24, 2007
My auto built in flash won't open on my canon 30D
The built in flash will (or should) pop up automatically if you are in the basic zones and the camera detects a slow shutter speed. If you are on a creative zone you need to manually push the button on the front of the camera it's a little button with a lightning bolt beside it. The flash will pop up take a few seconds to charge and you are on your way to flash photography. Two other things the internal flash will not pop up if you have another flash or accessory mounted in the camera hot shoe. When the flash is ready you should see in the viewfinder a green lightning bolt that telly you the flash is charged and ready for use.
Dec 21, 2010 | Canon EOS 30D Body Only Digital Camera
I can't seem to turn the flash on my Nikon D70 on! I've been playing around with it for hours and have read through the manual. I've followed the steps clearly, but nothing is working. The previous...
If nothing else it should pop up when you put the camera in A or M or S and then press the flash button on the side. It might or might not fire, depending on the light available, but it should for certain pop up. When you do this, you should hear a click and the flash should pop up. If you hear the click and it doesn't pop up, then it's jammed or glued or somehow being mechanically prevented from coming up.
In Auto modes, you can select the flash to off with the side button and the back rotary selector. This is where the flash symbol with the slash through it tells you the flash is off. If you push the flash button in Auto modes with the flash selected off, it won't pop up.
There are also some things the D70 can do to control external flash units that may be set abnormally.
The best way to make sure those aren't messing you up is to select "reset to default". That will take the camera back to a base setup that should work.
If none of these things gets it going, take it in to the Nikon dealer in town.
Sep 01, 2009 | Nikon D70s Digital Camera
Canon eso err 05 how do I fix it ?
This means a flash problem.
The reasons for it may be several ones. Let me go from the one with higher probability to the lower one.
1. Flash is stuck. It is the most comon reason, and more easiest to confirm. When pressed the shutter (or pressed the flash side button in P mode) you hears a repetetive click noise, and the flash won't pop up. If this happens, the flash is stuck.
Sometimes is solved when at the same time you press the shutter button, with the finger (or nail) you gently pull it up. Once is up, check for dirty, or any residues (such as tape glue, sand or something like that) that stucks the flash.
Some persons apply a thin layer of lubricant on the side hinges. Don't put so much lubricant or oil because will get inside the camera, and cause other problems.
2. If not click sound is heard, the either the flash actuator relay or the DC/DC board (that provides power to the flash board) or the flash board are defective. This can be confirmed only in a camera repair shop.
If you need further support, please let me know.
Best regards,
Jul 17, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D40X built in flash doesn't pop up automatically
This is a common fault with the D40x. You will need to contact Nikon for repair details.
Mar 31, 2009 | Nikon D40x Digital Camera
Nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Mar 11, 2009 | Nikon D40x Digital Camera
Nikon d 80 flash will not pop up while in auto mode
The flash up button is located on the left hand side of the camera right near the top.   You should use this button to pop up the flash. Prying it up could/has broken this button.
Also, depending on what setting you are using, the flash doesn't always pop up automatically.   Check to see what mode you are in, on the round dial on the left -- ie  Auto, Portrait, Manual, etc.   I can move sometimes without your knowledge, and this may be the problem.
Apr 15, 2008 | Nikon D80 Digital Camera with 18-135mm...
Flash
Sounds like the bulb might be a gonner. Can you hear it charge when you turn it on flash mode?
Nov 26, 2007 | Fuji FinePix S5000 Digital Camera
Built-in flash auto pop-up problem
Does the 'pop up' pop up? If it does and still says obstructed- closes it and pop it again If it still persists Canon customer support will advise the next move. If a repair price seems high you could perhaps get a separate flash if the camera accepts them.
May 09, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D70 Body Only Digital Camera Logo
77 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
