Question about Dell 962 Photo All-In-One InkJet Printer
I need to scan a form to my PC to make changes and I don't know how to do this.
  • 523 Answers
Well is your printer connected and ready to scan? what type of connection you have? you have to know those type of machines scan pdf , tif or jepeq only, but if you planning to scan as microsoft word and make changes, you need to have ocr software to do that.
Thanks for using fixya
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Oct 07, 2009
Gateway sx series sx2110g-uw318 boot menu with AMD E1-1200
It's either F1 or F2. However, once I had a Gateway which needed "Delete". You can try to put one finger on each button and press them successively. If everything goes right, you will enter BIOS and then you will have to enable lagacy usb support, change boot order so that you can boot from USB or CD (it depends...). Hope this helps!
Jan 26, 2014 | Gateway SX2110G-UW318 Small Form Factor...
What graphics card is compatable for hp d530
I'm not going to go through a list for you, but I can tell that you don't have many options. The HP Compaq Business Desktop D530 uses a small form factor which means you don't have the same space as normal desktop users inside of your machine for the vast majority of display adapters. You would need at least a medium form factor for that.
The other problem is that your power supply is only 185W and can't supply the the amount of power needed for most desktop class display adapters.
The machine you are using wasn't designed to ever be used for gaming, and it shows. You would need to get a bigger computer case and higher watt (around 400 to 600 watt) power supply to support most desktop display adapters.
Jun 26, 2012 | HP Compaq d530 CMT PC Desktop
I now have office2010 how do u scan a form in to be able to type on the form?
what you want to do, is not possible. Only way to properly write on a form, is that you have the original digital computer version of it, sure you can scan it, but you can not use / write on the same way. Sure you can use the computer to ADD text into the form, if you scan it as a picture, and then use the Microsoft paint program to add text on the fields. But its not the same as having the original digital form to write on.
Or then I'm not informed on how to Scan a form, to turn it into a form and then to fill out that form on your pc.
Sep 28, 2011 | Microsoft Office Home and Student 2010
My hp all in one will not scan the whole document. It only scans part of it. I have tried changing the settings but apparently I don't know how to do it correctly. I changed to scan as a documnet...
Wht must be done is to first uninstall the drivers from your PC and then install once again the software with the PRINTER DETACHED. Connect ONLY when the PROMPT appears and then rrun an alinment of the paper- you need to take a test print and place it on the scan table to make the printer alignment correct.
Please read through the manual to confirm- which can be downloaded from the Hp/support site.
Aug 30, 2011 | HP Office Equipment & Supplies
Since the change of VAT in UK I don't know how to change to 20% from 17.5%
Here is a detail summary to instruct how to do so.......................
http://www.hmrc.gov.uk/vat/forms-rates/rates/rate-rise-guidance.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 03, 2011 | Computers & Internet
I cant insatll cursor mania in my pc
This is desired behavior. :)
Cursor mania is part of a spywhere and adware. Trust me you don't want it. Same goes form smiley central.
I would highly recommend running a virus scan Here are a few good applications.
http://www.safer-networking.org/en/index.html
http://www.lavasoft.com/
However if you really really want to install it try right clicking and running and select RUN as ADMINISTRATOR.
ONCE AGAIN I DO NOT ADVISE INSTALLING IT.
Jun 22, 2011 | Computers & Internet
Need to scan a form to be filled out to computer
If you scan a form onto a computer, it won't behave as a form by default. This is because the computer is just storing a picture of the form, and doesn't see it as a form.
To make a scanned form into an electronic version, you will need some software that lets you define the regions of the form that can be filled in by the user. the full version of Adobe Acrobat lets you do this, as do the less expensive programs CutePDF Professional or PDfill.
Basically, you scan your document into a pdf format and use the aforementioned software to define which regions on the form should have typable text, checkboxes, etc., then you re-save it as a fillable pdf.
This works well, I do this with all my rental applications, etc.
There is a little bit of learning required to do this, but if you spend some time with the program and its helpfile you'll be creating forms with the best of them!
Apr 22, 2008 | Office Equipment & Supplies
Save scanned document in PDF
didnt' know you can scan to pdf. what software does that?
Feb 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
75 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
