Question about Air Tools & Compressors
Air ratchet will not stop operateing. Needs new air valve.
Just had same promlem with old crafsman. took the valve apart and the stopper was deteriorated. Cut the tip of a yellow wire nut using that as the stopper put it back together and works fine.. Should have done it 10 years ago....
Posted on Jul 21, 2010
  • 8,404 Answers
Check with the manufacturer web site ...
You are going to have to remove the existing valve to replace it ... get started on it ...
You will probably find it is rusted because 'someone' didnt use the oil they were suppose to put in BEFORE and AFTER each use. Maybe you can get it cleaned up enough to function without replacing it.
I hope this helps you
a
Posted on Oct 07, 2009
At what torque should lug nuts be tightened
Instructions
    • 1 Check the maximum pressure rating of the air tank. The rated pressure is indicated in pounds per square inch (psi). If there is no indication of limit on the tank, do not use it.
    • 2 Drain any accumulated moisture from the compressed air tank before filling. If the tank has no drain valve, you may skip this step.
    • 3 Remove the cap from the fill valve. The valve is the same size and type as used on automobile tires. The location of the valve differs depending on manufacturer.
    • 4 Attach the fitting of the air supply hose to the valve stem of the air tank and depress the fitting firmly. If the air tank has its own pressure gauge installed, keep a close watch to avoid over-pressurizing. Wear safety glasses when filling the air tank.
    • 5 Stop filling the air tank periodically and check the tank pressure using an air pressure gauge if the tank does not have one installed. As the air pressure in the tank increases, check more frequently until the maximum amount is reached.
    • 6 Remove the air supply fitting and replace cap.
Jan 20, 2013 | Campbell Hausfeld 3/8" Ratchet
3/8 air rachet will not stop spining
The ratchet needs repair. I would check the throttle lever valve inside. Either the spring inside or the valve o-ring are worn out.
Nov 08, 2012 | Craftsman 3/8" Pro Air Ratchet Rapid...
It keeps spining will not stop
Air rachet? The valve probably got something in it and won't shut down the air flow. You will have to take the valve portion apart and clean it out. Look for any bad o-rings while you have it tore apart.
Feb 05, 2012 | Craftsman Professional 38 in Ratchet...
When air is turned on it wont stop turning
The trigger valve is leaking. Disassemble it and find if the seal has failed or is sticking. This is a fairlky common problem with air tools,
ake sure you ALWAYS out air tool oil in the tools daily.
Apr 09, 2010 | Chicago Pneumatic CP7830HQ 1/2" Super -...
My ratchet does not shut off when handle is released.
probablu the spring to shut the valve is broken or the valve us stuck, also dirt in the orifice will do that, dissassemble and repair
Nov 17, 2009 | Chicago Pneumatic 3/8" Heavy Duty Air...
The trigger stop working the ratchet works but i have play with the air hose on and off to use it. i oil it.
sounds as if it needs servicing ,not expensive -----what do you oil it with ? if you dont have the correct oil use auto transmission fluid DONT use wd40 or the likes the o/rings will go in no time
Sep 29, 2009 | Craftsman Mechanics Air Tool Kit Impact...
I have a brand new husky 1/2'' air ratchet. It was working fine yesterday and today I went to use it, no go. When I hit the trigger, air just shoots out of the release port. The ratchet does not turn. ...
There could be a couple of things wrong with it. First and foremost make sure your compressor has the correct cfm's to operate the tool. Psi is only half the battle when it comes to air tools. Second, make sure that your reversing switch on the ratchet is properly engaged. Sometimes it will get stuck in the middle. You may have a crimped hose so check the hose. There may have been debris in the line that got into the motor. If this is the case, then you are going to need to have to take it apart to see what is wrong. If you just bought it though you should take it back to Home Depot. I had a customer who basically had the same thing happen. He used the ratchet twice and the valve pin cap just popped off. It is plastic and just broke in two. I tried to look up the part and it is unavailable. Husky is made by Campbell Hausfeld for Home Depot. Sometimes it is not that easy to get parts for certain models. I believe they make a run of tools and then discontinue the line they just made, and do not make parts available. You could try taking it back to Home Depot and swapping it out for a new one. Or my suggestion would be get your money back and by a better brand ratchet like IR or CP.
Sep 22, 2009 | Air Tools & Compressors
My 1/4 ratchet operates with air applied, without moving the pin. The pin and spring are there and free. This ratchet has sat in my tool box for 10+ years. Was there a plastic "ball" that used to be in...
Most CP ratchets have an oring that seals the trigger valve. You can remove the screw on the top of the trigger and then remove the spring and valve pin. There should be an oring around the bell of this pin. You can probably get away with using any oring that is the same size, and not having to get the exact oring from the manufacturer.
Aug 09, 2009 | Chicago Pneumatic 1/4" Air Ratchet
Chicago Pnuematic air ratchet runs continuously
under the lever you push to make it operate you will se a pin .if this pin is stuck down the ratchet will run all the time.also this could be a bad O ring on this same part,
May 16, 2009 | Chicago Pneumatic 1/2" Heavy Duty Air...
Ratchet support
Like any power tool, air tools are safe to operate when the proper precautions are followed. Always read and follow the manufacturer's recommendations.
Aug 27, 2008 | Astro Pneumatic 3/8" Palm Ratchet Wrench
Air Tools & Compressors Logo
939 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
