Question about RCA R52WM24 52" HDTV Projection Television
How do you wire tv to cable box? Followed all
How do you wire tv to cable box? Followed all cable instructions and still no picture or sound
  • 56 Answers
Hook up the wires properly and?
Posted on Oct 07, 2009
I was trying to set the cable box so the remote that came with the cable box would opert the tv and i lost the picture . the blue button comes on and off but no sound or picture the remote that come with...
Make sure you are on the correct input on the television and that the cable box is on. Do this manually. Hopefully you will get picture and sound again. If yes, then check the cable company website for the remote codes for your television manufacturer and the instructions for programming. Often times there are multiple codes for each brand so be patient.
Apr 08, 2014 | iLO Televison & Video
Polaroid led tv ssdv311-11 sound but no picture, connected thru cable box
The TV electronics for the picture may have failed. Do you get any picture ever, like when you turn it on, or when you connect a DVD to it?
If you do then replace the scart cable with a good known brand. Cheap scart cables often do not have all the pins connected up.
Dec 21, 2013 | Polaroid 1521-TLUB LCD TV
No sound but picture on an RCA L32HD31R
Check all ur tv inputs cables connections from the back of the tv,for like AV components and or HDMI cables for losed connections or damages cables wires.If u have cable boxes,satalite boxes or telicom compannies boxes and it plug in 24/7?Yes?Unplugs,replugs those boxes and the tv also back about an hour later.For those boxes to reboot and upgraded it softwares and the tv to do a resetting itself back to the tv factory settings.Than goes into the tv menu,go to the tv Audio Settings,to do a whole resetting to all the audio settings back to the tv factory Audio Settings.These steps,will help for ur tv to have and to get it audio sound back again.
Nov 29, 2011 | Televison & Video
I can't get a picture or sound. It's brand new
Ur other tv work with the Fios signal?If yes,ur tv have problems,brand new tv call for warrenty service or return it where u buy it for the replacement.
Mar 13, 2010 | Sansui HDLCD-3212 32 in. LCD TV
Plays movies in surround sound great,however tv shows in 5.1 do not play in surround sound.
With no knowledge of your TV source component (cable box??) and how closely you have followed its connection instructions, no one can really help you out. I'm pretty sure you might need to run either an optical or coaxial (RCA) cable into your 'system' for it to decode 5.1.
When in doubt, Read the Manual.
Nov 17, 2009 | JVC TH-M505 System
No picture but only sound
If you are expert and have experience then follow the instruction given below:
Check first Filament is lighten-up ? If yes then check ABL Voltages, if filament voltages not present check horizontal out put transistor. and check also safty resistances in surrounding area of H OUT Transistor.
And if you are not a tech person then i advise you to please contact any expert nearby, this problem bit technical.
Hope this will solve the problem.
Thanks for using fixya.
Jul 24, 2009 | Sony KV-36XBR250 TV
No picture, blue screen
Use the TV input selector to select the right channel, that should fix it.
Jan 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Best picture and sound
connect coaxial cable connector from your cable service company to cable box-----in jack.
2-using coaxial cable connect cable box out to tv-vhf/uhf jack.
connect projection tv audio out (var-fix)jacks to avr 230 line in.
Aug 22, 2008 | Audio Players & Recorders
Sony Bravia - picture don't fit the screen
I have a Scientific Atlanta cable box w/ Time Warner. I followed the instructions below for the cable box. Somehow it reset my picture and I can now read the ticker at the bottom of the screen and the different picture sizes seem to work properly. Good Luck.
http://newteevee.com/2007/12/15/six-steps-to-get-more-hd-from-your-scientific-atlanta-set-top-box/
Aug 03, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No sound from plasma to home theatre
First off it's always best to start from scratch when it comes to home audio. LoL. Many times I've been in this situation.
So with everything disconnected. You should have your HDMI, COMPONENT, RCA(R,W,Y)
HDMI and COMPONENT are the exact same thing and in all preference COMPONENT is far better thand HDMI for the pure fact that each wire is in it's own casing and insualted to avoid feedback from the other wires.
Anyways, with everything disconnected we begin
From you Cable/satellite box- Run your HDMI cable from you cable box to your HDMI 1 input on your tv.(If your speakers were to work on your tv you would automaticaly get sound and picture)
That should be all that you should be running from you cable box. Now that we have one thing running we go to the next thing.
From your TV run your audio out (RCA Red/White) to your amp. Usually your preference but more than likely your TV IN on your amp.
With your amp now set on TV, you should automatically get sound from your tv. and if your running an HD cable box even though your only running RED/WHITE to your amp, you will still be receiving Digital sound.
Most new amps Should have a digital input and if your running and 1080iUp this one RCA plugin will give you dolby digital sound from your dvd player to your amp. Then running a video rca up to your tv, will give you the picture, while the digital out on your dvd player to your amp will give you dolby digital sound.
It's a basic simple step to get sound. Like a continuing current. So just as long as you have your cable to -- tv -- home theatre. Everything should work. Otherwise I would go and check your cables and make sure they are not faulty.
I hope this confusing walkthrough helps.
Jun 23, 2008 | Panasonic TH-42PX60U Television
RCA R52WM24 52" HDTV Projection Television Logo
53 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
