Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
Dewalt battery charger won't charge
DW9107 unit has a blinking red light when you try to insert the battery for charging. Yesterday, it was solid red for several hours when this is a one hour charger. Any advice?
I see on the internet that the unit was recalled in 2000 with certain date stamps. Where would I find that? is it actually stamped into the bottom of the plastic followed by the initials DB?
  • 30 Answers
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Posted on Dec 12, 2009
  • harold souza Jul 04, 2012
    the to hot or cold coment is wrong , its just bad
  • Anthony Snow
    Anthony Snow Sep 01, 2012
    Add a CommentBad? So you are saying that a hot/cold delay indication and a replace battery indication are both bad batteries? If that is the case then why have the hot/cold indication at all?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
My Battery charger DW 9107 has 50 VDC output is correct this voltage?? thanks in advance my friends.
Posted on Mar 13, 2016
    Scholar:
    New Friend:
  • 49 Answers
You must have put in a battery pack that was already charged, the second time you went to use your charger, I'm guessing that you are not real familiar De Walt power tools and when you saw the solid red light maybe you thought it was broken?
On the front of your charger right above "De Walt" there a "scale" that tells you the 5 different red light indicators.
If you took that Batt pack out of charger and put it back in your cordless and used it for 2 minutes and put it back in charger the"red indicator light" would start to blink.... PLEASE READ. You can really damage or shorten the life of any battery pack by charging it when there is ANY charge even a small charge left in the pack- so you want to only charge battery pack when the drill wil not move inside the battery pack are like 18 0r 20 rechargeable batteries if any cell inside the battery has a charge it you will damage it and it wont hold a full charge every again...
Perry Tradesman-..
Posted on Oct 21, 2014
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Brand new, never used. Plug into wall to charge and just get flashing red light. After 16 hrs on charge, still flashing red and when turn on, screen blinks then shuts down.
check that you have the battery in the correct way
if it has batteries like AA , AAA or what ever the negative terminal of the battery goes against the coil spring so if you have them all facing the same way, that may be why they are not charging
the screen shutting down at this stage would be cause the batteries are flat
of course you could always bet new fully charged rechargeable batteries and put them in correctly to see if the rest works
Apr 30, 2017 | Sylvania SDVD7015 7 in Portable DVD Player
Why does my gateway nv53 battery light blink while charging?
Hi, The LED light on your Gateway NV53 Blinks while charging because it was designed to do so. According to the user manual, if the battery light is:
Solid Orange: Battery is fully charged Blinking Orange: Battery is charging Blinking Red: Battery is critically low Solid Red: Battery problems, contact Gateway support immediately.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 22, 2011 | Gateway Computers & Internet
The batterie charger for my Casio Exilim EX-Z77 has a blinking red light instead of a continous red light when i try charging the batterie. also, it doesnt appear to be charging it at all. Left in in for...
The blinking light indicates a charging error. Try connecting a 9 volt battery to your camera battery. Sometimes if the battery has lost all charge, the charger doesn't recognize it properly.
Dec 05, 2008 | Cameras
Battery charger flashing red light
Clean contact points of both battery and charger with q-tips dipped in rubbing alcohol. This solved my problem with blinking lights and not charging of the batteries.
Nov 03, 2008 | Olympus Stylus 710 Digital Camera
Charger light
I had this same problem and all I did was to unplug the DC adapter at the phone and plug it back in after a few seconds. The solid charge light came on immediately, like usual. I let the battery charge for several hours before using the handset again.
Apr 06, 2008 | Uniden Cordless Phone
The battery wont charge
i had the same problem.
if your battery light is blinking a red light then you should call up casio's technical support and they'll send you a new one within 2-5 business days:)
call 1-800-435-7732 for technical support! :)
Apr 01, 2008 | Casio Exilim EX-Z77 Digital Camera
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
7,189 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
