1) Make sure your game console is set to output audio via the cables you are using.
Solution: The PlayStation 3 (PS3), Xbox 360, and other game consoles have various options for audio output. Make sure you have selected the right audio output option for Elgato Game Capture HD to use.
When using the PS3 with Elgato Game Capture HD, make sure you set the Audio Output settings to Audio Input Connector / SCART / AV MULTI
For an HDMI connection with your Xbox 360, try these settings:
1) Start the Xbox 360 console without a disc in the disc tray.
2) Go to Settings and select System.
3) Select Console Settings, and then select Audio.
4) Select Digital Output, and then select Digital StereoMy Elgato Game Capture HD doesn
· Audio Max Bitrate: No restrictions. See question number 11 for more information.
4. What exactly does the Xbox 360 support for WMV (VC-1)?
Xbox 360 supports the following for WMV:
· File Extensions: .wmv
· Container: asf
· Video Profiles: WMV7 (WMV1), WMV8 (WMV2), WMV9 (WMV3), VC-1 (WVC1 or WMVA) in simple, main, and advanced up to Level 3
· Video Bitrate: 15 Mbps with resolutions of 1920 x 1080 at 30fps. See question number 11 for more information.
· Audio Profiles: WMA7/8, WMA 9 Pro (stereo and 5.1), WMA lossless · Audio Max Bitrate: No restrictions. See question number 11 for more information.
5. Can I mix and match the video and audio codecs outside of those defined in questions 1 through 4 above?
No you cannot. We only support each audio and video codec in the explicit containers defined in questions 1 through 4.
6. How can I determine if a video file that I am trying to play conforms to the specifications as laid out in questions 1 through 4?
You can use a 3rd party tool to analyze your video files to determine what audio and video codec is used. A popular 3rd party tool to analyze video files can be found athttp://www.headbands.com/gspot/.
7. How do I create WMV, AVI, H.264 and MPEG-4 content? What encoders does Xbox 360 support?
You can create this content on one of many 3rd-party applications. Xbox 360 supports many popular encoders. Specifically for encoding to WMV you can use Microsoft Expression Encoder or Windows Media Encoder.
**8. What specific features of Mpeg-4 Advanced Simple Profile does the Xbox 360 support?
The Xbox 360 supports Bidirectional Frames (BVOPs), Interlaced Frames, Quarter Pixel Motion Compensation, Global Motion Compensation, and MPEG Quantization.
9. What are the different ways to play video content on Xbox 360?
You can play video from a USB 2.0 FAT32 removable drive, optical media, and by streaming from the Zune software, Windows Media Player 11, or Windows Home Server.
10. What are the different video codecs that are supported in all the different ways to play video content on the Xbox 360?
donwload amcap on amcap click options video capture filter video image tick the boxes ext audio and usb audio then go back to video capture filter on video decoder change the video to ntsc _433 then you will have audio and black n white picture then change ntsc_433 to secam_B than load pinnacle then capture/import
The optiplex 360 does come with internal speakers(it's in the spec sheet as optional), we bought them for our entire IT department and they worked fine on XP and vista, but when we put 7 on them, we can't get the internal speaker to work.
alright. make sure that your red, green and blue are all plugged in properly and that your audio plugs are also in there correct plugs. i think audio is red and yellow. correct me if im mistaken
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables).
-Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
Did u check all the cords?
