Question about Sharp Televison & Video
Screen appears to be able to display but no image appears.
I have a Sharp HDTV model 32SF56B that the CRT display lights up and will display graphics (i.e. channel number, menu, settings etc) but when the tv tuner is selected for input, it has a screen but no snow. When the screen displays the channel number there is no snow in the background only black screen, I can read the tv menu for settings etc and I can change it to a blue screen but when I hook a DVD or Satellite receiver up to the cable input, the signal or picture does not appear on the screen. No video device output ported into the back of the tv inputs will show up on the screen. No audio either. How can I get video to display on the screen? When I change the INPUT to Input 1, 2, or 3, I get a audio hum like the amplifier is working, but no video. In blue screen mode this makes no difference. I still have audio but no video even though the screen is blue. Where do I begin to troubleshoot? When I turn the tv on, the high voltage raster is evident because you can hear the common voltage surge sound. And the tube has a blue screen in blue screen mode. Graphics display in Menu mode are clear and appear on the screen. Why does the video from satellite receiver or DVD cabled or RCA jacks not display?
  • canovey Oct 12, 2009
    Nope. Drifters response has already been tried and there is NO input that offers a picture or provides video to the screen. I have tried ALL input/source possibilities.
    Novelist:
  • 102 Answers
Hi if you don't have display than select Video options from TV Tuner card Menu try AV1 or AV2 if both options don't work than check connections of Monitor and TV Tuner Card , Checked if Connections are connected in the correct port or try different connection ports combination and try different Connector cable in case if the cable is faulty.
Posted on Oct 12, 2009
  • Sharp Master
  • 4,924 Answers
Try to select the A/V mode on the tv and than change channels from the receiver ...anyway the A/V mode is the input mode for dvd-es....I think you have the option on the remote control too ...
Posted on Oct 07, 2009
2010 Macbook pro i5 15" Image seen only with flashlight.
As always the Apple products are proprietary and DISPLAY post has issues. Disregard all the testing with other adapters and displays and replace the inverter first, it is the cheaper option.
Mar 02, 2017 | Apple MacBook Pro Notebook
I have a problem about my laptop if i turn it on my screen are still blank but my laptop is still working.. can i ask if what is the problem about my laptop. pls help me... tnx!
Although your Toshiba portable computer appears to be on and running, there is no image on the built-in LCD display screen Look closely at the LCD display screen. If you can see a faint image on the screen, the display screen's fluorescent backlight may be turned off. Shining a flashlight directly at the screen will make it much easier to see whether or not there is a screen image actually present, though not lit up. On most Toshiba portable computers, there is a small plastic or metal pin near one of the LCD display lid hinges. When the display lid is shut (closed), this pin is pressed against an internal switch which turns off the backlight, saving battery power. You may be able to turn the backlight on again by tapping this pin repeatedly. The normal screen image will then suddenly appear, or re-appear.If there appears to be no display image at all, the problem is probably not related to the backlight. In this case, press and hold the Fn key and then press the F5 key several times, pausing several seconds between each keypress. This will cycle through several display output modes: Internal, External, Simultaneous, and possibly one or two more.If no image appears on the LCD display after cycling through the Fn-F5 sequence, try doing so with an external CRT monitor attached, if possible. If you still see no image, on either screen, try restarting the computer with the CRT monitor connected.If you see a screen image that looks normal when the computer is first powered on, or when you try to enter the BIOS Setup during the power-on sequence, it's an indication of a software problem (a driver or an application that's launched while the computer is loading Windows, possibly). Try downloading the display drivers for the computer from the Toshiba Support website, and then re-installing them.If the LCD screen or an external CRT monitor is blank only while the computer is first powered-on, but then works fine, it's probably not an indication of a problem. Some models display no text or images during the startup process. Additionally, installing some Windows Updates may delay the appearance of the familiar Windows desktop.If there are blank margins bordering the image on the LCD screen, launch the Windows Control Panel, then double-click the Display icon. Click the Settings tab, and then adjust the Screen Resolution setting until image fills the entire LCD screen, which will cause the margins to disappear.If the font size on an external CRT monitor seems too small for comfortable viewing, try clicking the Advanced button on the Settings page, and then adjust the DPI (dots per inch) value. Try 120DPI and 135DIP, to begin with. Avoid changing the DPI to much greater values, in order to avoid settings that will be difficult to change.
  1. Hold down the power button for approximately 10 seconds until the computer turns off.
  2. Verify that neither one of these keys are stuck in the down position:
    the Tab key (arrows pointing left and right)
    the tilde key ( ~ and ` characters)
  3. Turn the computer on.
  4. If either of the keys above appears to be stuck in the down position, and if the issue is not corrected by pressing these keys repeatedly, then service is required.
Aug 17, 2011 | Toshiba Satellite L455D-S5976 Notebook
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
The image appears to have excessive yellow tint. and there are no images coming thru the blue projector
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • TV shutdown - does not display video
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | Philips 55PW9363 55" Rear Projection...
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
No picture
If model of your TV is LC19SB25U, TV powers up, TV has back light,but on picture or menu, The problem is the part called main unit.
Oct 14, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
I will to know the code for the precision Tv
Hi, I have a sharp 32sf56b. sound OK. Picture went dim and fuzzy. Clears up a little when turning brightness control all the way down. Picture has no snow. Can see fate vertical line on screen
Mar 08, 2009 | Televison & Video
Image on screen of a Sharp Aquos 42"
Call P.T.S. Electronics at 1-800-844-7871 they can assist in correcting the problem. They will need the model #. Ask for technical support and they will tell you which module needs to be sent in to repair.
Feb 23, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
SAMSUNG 42inch HC-P4241W MODEL CRT AGING
explain what the picture looks like? Does it look like the edges are in 3-D?
Jul 25, 2007 | Samsung HC-P4241W 42" Rear Projection...
Televison & Video Logo
81 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
