Question about GE (PSS26MSRSS) Side by Side Refrigerator
The fridge half isn't cold anymore we can't feel any cold air coming in the freezer seems to be ok
  • 31 Answers
Your freezer is not okay. in fact, it is the problem. take off the back wall in the freezer. more than likely you are going to find an ice ball encasing your evaporator. melt the ice with a hairdryer, careful not to melt any wires, or damage any of the evaporators thin fins. melting the ice will save you what could be a $80 dollar labor charge compared to a $120 charge JUST FOR LABOR!
your problem is (in order from most likely to not) defrost bi-metal (a.k.a. defrost thermostat or termination switch). This is 90 percent of the time your problem. the next two cover the other pieces of the pie.
defrost heater (after you melt the ice CAREFULLY off of what is the evaporator underneath, you will find either a glass tube with a coil of wire in it, or a black graphite colored rod...both have a wire on each end. you will need to specify if it is a radiant heater (glass tube one) or a calrod (greyish one) This is the problem if your unit goes into defrost (you hear nothing inside the freezer; no fans, no compressor running, nothing. this is what you should hear during defrost on a properly operating fridge. if you look under the evaporator, you will see it glowing during this time (DONT TOUCH IT, ITS HOT) if you see this glowing, it is good.
all else fails, its the defrost timer
Posted on Oct 07, 2009
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Fridge part working freezer not
The fridge is just the end of the freezer evaporator. If the freezer isn't cold inside, check the rear panel. It is probably frozen solid with no air getting through. Switch off, leave doors open for 24 hours and be prepared for lots of water to come out. Clean the condenser and make sure the fan inside is ok. Reset the thermostat to middle of the range and be sure to come back to tell us how you get on.
May 17, 2012 | Hotpoint Refrigerators
Only half of the freezer and half of the fridge are working
heat rises and cold stays down on the lower shelves,if the evap fan motor isn't blowing this will happen,next time send the brand name and model number off of the machine,open the freezer door,if you don't hear the fan blowing you have a bad evap fan motor,all it does is the freezer gets cold,the fan blows the cold air from the freezer to the fridge section,also if the fan isn't working when you remove the back inside wall of the freezer if there's any ice melt it out with a hair dryer,unplug the machine before you start working on it,call your parts store,give them the model number and they will sell you the parts you need.
Oct 10, 2011 | Refrigerators
I have a sharp fridge SJ-P49N-SL. A recent power outtage in the area lasted 8 hours. When the power came back on, the fridge seemed to be ok. But, after 5-6 hours of operation, the freezer is not cold...
Checked Freezer Fan is working. Also checked defrost Fuse in freezer.
To checked freezer fan is working or not open freezer door press Door Switch and checked Cold air is coming from duct or not.
Aug 10, 2011 | Sharp Refrigerators
My Amana fridge #ARB2215CB seems to be cooling the
Your refrigerator probably has an issue with its "damper control assembly", which regulates cold air coming from the freezer compartment. Contact an appliance service company.
Apr 13, 2010 | Amana ARB2217C Bottom Freezer Refrigerator
Freezer cold, fridge part cold at first then warming
hi friend
it is fan problem check it....it may also be a thermostat not working proper,,check them both ,
thank u,,,,,,,,
May 03, 2009 | Estate TT18TKXKQ Top Freezer Refrigerator
Fridge too cold
There is a damper motor that is behind the vent where you feel the cold air coming out in the fridge section.  That damper should open and close after making temp. adjustments.  See if you can look in the vent and see if it is wide open.  Set your freezer on the coldest setting and check this vent again an hour or so later.  If it is still wide open then that damper motor is bad.  Let me know if you find something different or have any questions.
Oct 10, 2007 | GE GDS20KBS Bottom Freezer Refrigerator
Refridgerator not cold but freezer is freezing fine.
This model uses the cold air from the freezer, defrost complet unit for 24hrs, turn back on and it should work ok. Regards Advisor
Aug 19, 2007 | Whirlpool ET0WSRXML Top Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
95 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
