Question about LG Dryers
The dryer does not heat up, it starts and everything, but no heat
  • LG Master
  • 7,482 Answers
Sounds like your problem is with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with a continuity meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
Good Luck,
Hope this helps
Posted on Oct 07, 2009
Lgq9030pqo start dryer ,everything normal gas kicks on starts heating., heats for a couple of mins then cuts out doesnt come on again drum keeps on going everything else is normal
Typically - when this happens - the gas valve solenoid is failed, and needs replacement.
The flame sensor (thermocouple) may also be the culprit if it is failed - it will not tell the valve there is a flame present.
Check those out.
Thanks!
Aug 23, 2011 | Dryers
My kenmore elite he 3 dryer is not working. well, the buttons go on and the dryer starts to spin when everything is set but when I open the dryer, everything is soaked still. there is no heat at all. on...
more then likely it is the thermal fuse, or the heating element here is a link:
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
May 06, 2011 | Dryers
I have an LG dryer Model # ddle7177rm/dlg7188rm.when we start the dryer it starts to heat then stops and it blows cool air. the ducts are all clean.
Hello
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | LG Dryers
I have a Kenmore Elite Gas dryer 2002. Everything works on it except you have to hold the start button down on it. It turns fine, Fires up and heats but let off the start button and it stops. I took it...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Kenmore Dryers
My kenmore elite electric dryer inconsistantly starts to heat and
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
It just stopped heating
If you have a gas dryer the burner is ignited by a eletroniic ignitor. It will make a ckicking noise upon starting it when set in the heat mode. You should hear the click or clicking noise it makes within 30 seconds after starting the dryer. If no click is heard, replace the spark ignitor
Mar 30, 2010 | Dryers
Dryer comes on but does not heat up
the electronic ignitor is at fault
Jan 30, 2010 | Whirlpool LGB6300 Gas Dryer
LG Gas dryer will not keep heating
sounds like the heat sensor on side of heater pan is bad and needs to be replaced ,,, its mounted on side of pan the flame blows into and has 2 wires plugged onto it / larry
Dec 12, 2008 | LG DLG5932W Gas Dryer
Dryer heat shuts off after a few minutes.
replace the 2 black solenoids on the gas valve ..after heat up they sometimes will go bad and burner will not reignite even though the ignitor glows
Sep 23, 2008 | Dryers
Dryers Logo
60 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
