Question about RCA D52W15 TV
RCA model #D52W15 DOES NOT WORK
I REPLACED THE FLYBACK AND CAPACITOR SAME PROBLEM GREEN POWER LIGHT COMES ON BLINCS 2 OR 3 TIMES EVERYTIME LIGHT GOES OUT IT MAKES A CLICK SOUND. CAN ANYONE HELP BY GIVING ME DETAILED INSTRUCTIONS ON HOW TO FIX.
  • dredangz Oct 07, 2009
    i replaced the capacitor cp150
  • 3,037 Answers
Usually this is a sign of the capacitors on the power supply board failing, so you can either try replacing them or replacing the board itself which would be easier especially if you don't know how to replace capacitors. Replacing the board would be a plug in component. If you can, I would get the current power supply board and get it tested at a tv or electronics shop before moving forward. The click most likely is from this board not turning the set on.
Let me know what you find
Benjamin
Posted on Oct 07, 2009
  • RCA Master
  • 5,807 Answers
a) since you have replace the flyback can it be possible for you
to measure the voltage that it is having? , have someone to help
you , if you cant
b) it has a supply coming from the diode should it be still 75V
then that flyback might be not matched or properly not compatible
or partially shorted.
c) if the supply is at least 110V then there is no oscillation,
check the oscillator stages it might be blocked.
d) if there is no voltage it means the horizontal output transistor
is shorted.
e) that transistor is connected to the flyback
f) have that transistor extracted and test the collector and emitter
for short.
g) on the voltage reading the negative probe should be on the
ground side of the unit, not the ground side of the AC plug.
h) please be very careful on the flyback area.
you can safely discharge the big capacitor with a 4.7K 5W
resistor to be safe from output voltages of the psu.
i) use isolation transformer if you have , or a variac when measuring
voltages
j) please unplugged the unit when extracting and looking for shorts
  • 8 more comments
  • Rommel Cana
    Rommel Cana Oct 07, 2009
    have you really replaced the flyback?
    what voltage reading do you have on the pins of the flyback,
    what voltage reading do you get on the capacitor too?
  • Rommel Cana
    is this the same of your board?
  • Rommel Cana
    you should have at least 6V on CP 150 2.2 uF 16V
  • Rommel Cana
    you should have a voltage reading of at least 110 V on positive side DP 110
  • Rommel Cana
    you can measure voltage at pin 5 of the flyback
    check TL010 it might be shorted ( horizontal output transistor) 2SC5717 it is the one connected to
    the flyback LL08
  • Rommel Cana
    Rommel Cana Oct 09, 2009
    what voltages have you got? , have someone to help you if you feel you cant,
    you definitely need your technical skills in repairing this unit, be very cautious
    in the flyback area.
    try to measure just on the positive of the diode , the 2nd image i have posted
    it would be a lot safer pointing the positive probe in there than just pointing
    the probe on the flyback pins.
    if you can read schematic diagram, be sure you can ,cause you will need
    a service manual to guide you repairing the unit. , there are also CD available
    which might possibly helps you too , but i am not very sure of it.
    all i need is your data to further continue , having 75 v , have the flyback
    replaced or extracted, then re-check again for output supply on the positive
    side of the diode.
    or
    i might be needing output voltages when output transistor is connected and when
    un-connected,
    this voltages will diagnose where is the fault on your unit, their might still be other
    problem but we are not sure yet, till horizontal def circuits work .
    have you looked closely if there is bulge capacitor/s?
    you need to concentrate first on these two very important circuits that determine
    the status of your unit.
  • Rommel Cana
    the symbol of the diode is almost like an arrow ( a direction)
    wherever the arrow is pointed it is the positive side.
  • Rommel Cana
    Rommel Cana Oct 11, 2009
    hope you have measure the voltage on it?, have someone to help you measure if you feel you are not comfortable measuring it, better yet solder 2 wires and measure voltages later if it is plugged.
    or you can try having the unit rest for a while, while disconnecting all that is connected to it. for at least 10 minutes.and try it having plugged to a known good outlet
  • Rommel Cana
    Rommel Cana Oct 15, 2009
    you might have also a shorted horizontal output transistor.
    or horizontal oscillator is blocked.
  • Rommel Cana
    Rommel Cana Jun 19, 2010
    There
    might be still other causes, like changed valued
    Resistor
    capacitor:
    other Diodes ( like DL032 )
I REPLACED RCA D52W19 CAPACITORS ONE TIME 5 YEARS AGO,AND THE TV CAME ON AND WORKED,IT LASTED 5 YEARS,BUT RECENTLY IT JUST WONT POWER ON,I REPLACED THEM AGAIN BUT IT WONT COME ON AND FLASHES THE POWER...
You have a bad flyback transformer. This is a common problem that eventually goes bad in the ITC 222 chassis. You have to get the model number with the code at the end of it after the /. And sometimes you must have the numbers from off the flyback itself. Try to contact MCM electronics for the flyback at 1-800-543-4330. First see if they can match it with the model number with the code after the /.
Jul 15, 2011 | RCA D52W19 52" Rear Projection Television
Won't turn on! Green light one greenlight off!
Replace the flyback Its the 259296 flyback available from www.tvrepairworld.com the kit contains the flyback, associated capacitors and ful instructions on CD
Nov 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA 52 inch HDTV model D52W20B when you press the power button the green power light flash about 3 or 4 times and that's it no sound no video. Everytime it flashes you can hear I guess the power...
On Deflection board CK capacitors cp150 2200uf 16v if it is puffed up on top it is bad their is 2 more caps in same circuit replace them also cp114 cp120 220uf 35v also resolder all pins on FBT flyback Transfomer
Nov 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W15. Set's ON light will come on for about 10 seconds only
On Deflection board CK cp150 2200uf 16v if it is puffed up on top it is BAD there is 2 more capacitors you need to change out as well 220uf 35v in same circuit, resolder all pins on FBT flyback Transfomer.Also Ck second Ribbon connector make sure it is in correctly this ribbon can also cause set not to come on.
Aug 08, 2009 | RCA Televison & Video
RCA D52W20 gets power but won't turn on
Hi, thank you for visit fix ya.
Common problem on thi tv.
Capacitors on power supply bad.
Replace this:
2200uf 16V, 220uf 16V. Upgrade to 35V.
Located on power supply- deflection board.
(picture)a57b905.png Thank you
Jul 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv not turn on
you will need to replace the flyback number 259296 and CP150 you can get the parts at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Mar 13, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W15 TAKES AWHILE FOR IT TO POWER ON THE GREEN LIGHT FOR
Ck 3 capacitors cp114,120,150, if any of them is puffed up on top replace all 3 2200uf 16v other 2 are 220uf 35v /resolder all pinns on Flyback Transfomer.
Feb 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca hd tv d52w15
that model is famous for having bad flybacks. fortunately they arent exspensive and there easy to replace. you can get a new replacement at the following link for less than 50 bucks and they give free instructions on how to install it properly.
Jun 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w15
Most likely a bad flyback. It's a cheap part, but service people are even having a harder time getting ahold of one since they are failing often.
Apr 01, 2008 | RCA D52W15 TV
Rca d52w15
Possible short and safety is keeping the set from burning up. A service man should be able to find the short hopefully in a small amount of time.
Nov 05, 2007 | RCA D52W15 TV
RCA D52W15 TV Logo
474 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
