Question about Microwave Ovens
Need to replace light bulb in microwave - Microwave Ovens
  • Microwave Ovens Master
  • 8,404 Answers
Remove the cover to get access. find replacement at your applicance parts store or repairclinic.com
Posted on Oct 07, 2009
How do I change the light bulb in a magic chef microwave?
  1. Unplug the Magic Chef microwave from the wall outlet.
  2. Remove the screw from the light cover located on the left side of the underside of the microwave. ...
  3. Unscrew the light bulb, then screw in the new light bulb.
  4. Raise the light cover, then secure the cover with the screw that was originally removed.
More items...
How to Replace a Magic Chef Microwave Light Bulb ' Hunker
https://www.hunker.com/13407988/how-to-replace-a-magic-chef-microwave-light-bulb How do change the light bulb in magic chef microwave Google Search
Oct 24, 2017 | Magic Chef Microwave Ovens
How do I change the light bulb?
It is hard task.
  • You will need special tools, e.g. Torx screwdriver (star) and other
  • Be careful. Oven must be disconnected from mains.
  • The disassembling is complicated and procedure consist of more steps.
  • Microwave oven lamps bulbs are very special. They often do not have usual lamp cap. See Microwave Oven Lamp Bulb with Base
  • Watch this video as example what will your task:
Microwave Oven Lamp Replacement Samsung T170 Light Bulb UK
Some oven lamp types:
Home Office Light Bulbs Microwave Bulbs
Jan 28, 2016 | Microwave Ovens
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
I need to replace the cooktop light bulb-mmv5208ww
You should try to at least find the same wattage. The light bulbs are not dangerous safety hazards if they are made to fit microwaves.
Nov 07, 2013 | Maytag Appliances Over-the-Range Microwave...
Light bulb
follow this steps and fix it. God bless you
If your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Jul 29, 2013 | GE JES1384SF Microwave Oven
    How do i change the bulb on ag821azh microwave x2
    follow this steps and use the VOM for fix it. God bless you
    Light Bulb
    If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
    Main Control Board
    If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
    Light Bulb Socket
    If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
    Jun 19, 2013 | Microwave Ovens
    The lamp of won't work
    follow the steps and fix it. God bless you
    ight Bulb
    Main Control Board
    Light Bulb Socket
    Jun 11, 2013 | Neff H5642 Convection / Microwave Oven
    Frigidaire microwave oven
    Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
    To replace the light bulb to the over the range microwave you will need to follow the steps below:
    1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
    2. Remove the vent grill mounting screws.
    3. Pull the vent grill away from the unit.
    4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
    5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
    6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
    7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
    Note: DO NOT USE BULB LARGER THAN 30 WATTS.
    Oct 27, 2012 | Frigidaire FMV152K Microwave Oven
    HOw do i replace the inside bulb?
    Hi. I just told you, there is no acces for the bulb in microwaves. Bulb replacement is not supposed to be a user level maintenance operation. You will need to remove the microwave outer cover to replace the bulb.
    Here again my instructions: How do I replace light bulb.
    Regards.
    Apr 08, 2010 | Jenn-Air JMC9158AAS Convection/Microwave...
    Replacing light bulb in Microwave Oven.
    if this is a counter top modle this is no problum, unplug it!!!
    open door look for the light hole vents, ( that is where the bulb is )
    you will need to unscrew the outer casing. noproblum there is nothing but reguler insalation in side and a area where the bulb is. replase it you can buy them at any hardware store,
    if is a under cabinet there my be a axes door if not will need to take down,
    hope this helps.
    p.s. 1st time i that there was all kinds of things in side but not
    Jan 23, 2009 | Danby DMW1153 Microwave Oven
    Microwave Ovens Logo
    312 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
