Question about Dishwashers
KitchenAid Dishwasher streaking /residue
Our dishwasher has stainless steel interior. It is around 2 years old. I use Cascade and Jet Dry products. Dishwasher has started leaving glasses and silverware streaked and cloudy. Even the inside of the dishwasher itself is has a residue on it and is streaked. The silverware and door of the dishwasher has almost a rainbow effect residue - kinda like oil on water looks like. I tried running the dishwasher empty with a cup of bleach on top rack and a cup on bottom rack with no effect.
  • 2 more comments
  • Anonymous Dec 31, 2007
    dec 31, 2007
    i have the same problem. what can i do to fix this problem
    janet, fresno, ca
  • Anonymous Sep 26, 2008
    I have the same problem and it is also on my glassware. We do use jet dry and granular soap (only about 1/3 full).
    Thanks!
    bnknott@sbcglobal.net
  • James Head Nov 30, 2008
    Same problem, new Bosch top of the line dishwasher - use granular soap and Jet Dry - tried an number of different settings on the dishwasher
  • cearns Mar 08, 2009
    We have a Bosch, streaking and cloudy glasses started about 6 months ago when Cascade changed their formula.
    We have tried Costco brand, Cascade tablets and newer liquid Cascade. Same result.
    Using cascade powder specifically for cleaning glasses from Ace Hardware is gradually returning to the clean situation.
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: streaks on glassware/silverware
usually indicative of clogged spray heads, or spray arms not spinning, too much detergent for your water type, wrong detergent, and low water temp.
Link to manual:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203381187.pdf
Check the manual for amounts of detergent to use based on your water hardness.
Posted on Jan 06, 2009
Macmarkus
  • 2605 Answers
SOURCE: My dishwasher is not quite 2yrs. old and has
Welcome to FixYa,
Based on your description I`d suspect a plugged wash pump.
The place to start for that is to pull the pump filter, spray arm and check for food deposit, broken glass, undesolved detergent and general water deposit built up in the sump well.
The key is to get in there and clean it all out, I`ve attached a link at the bottom that will show you how to go about it. It is not really referring to the heating issue, or maybe even your model, ( Most Whirlpool, Inglis, Kenmore, Kitchen-Aid, Jenn-Air ) but it is the same procedure.
When you`re finished run it through a test cycle and see how it goes.
Let me know how you make out and what you find.
macmarkus :)
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Posted on Aug 19, 2010
clrvuedoc
  • 175 Answers
SOURCE: my glassware is coming out cloudy! the dishes are
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Posted on Mar 01, 2011
I have white residue on dishes. I use Cascade Extra Action and Jet dry I have it on hi temp wash and sanitize. Our hot water heater is on high. Thank you
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Jun 09, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
I have the KitchenAid Superba dishwasher in stainless steel. I've noticed that my tupperware (especially) are never dry after a cleaning cycle. Even if I wait a couple of hours after to empty the...
You might try using Jet Dry in your rinse aid dispenser, but plastic things tend to hold water and there isn't much you can do except try using Jet Dry.
Apr 09, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
My kitchenaid dishwasher leaves a white residue on clean dishes. 4 year old appliance, worked great until 6 months ago. under warranty, service repairman said i was using too much soap( am not). he cleaned...
heatman101
Mar 10, 2011 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher is 3 years old have white residue on my dishes.I have been usinf cascade products along what could be problem
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Jan 25, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Cloudy film left on glasses and white residue on edgings on inside of door as well as white residue streaks on inside of door.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jan 23, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
Stainless steel drum-some hard water build-up inside leaving residue on some dishes...how do I clean interior of dishwasher. A home-made solution worked years ago but have forgotten the ingredients!
heatman101
[][][p
Sep 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
White film on dishes and interior
White streaking is caused by too much rinse agent. (jet dry) Most all dishwashers now have adjustable rinse agent dispensers, so you can set them to a lower setting when you have soft water, and a higher setting if you have harder water. The adjustment is generally right where you add the jet dry. Other possiblilities would be a leaking jet dry cap, or a defective jet dry dispenser.
Apr 16, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
New dishwasher leaving powder residue on dishes.
Quit using the new Cascade. The formula change is what is causing the problem. No research from Cascade before releasing the product
Nov 18, 2008 | Dishwashers
Streaks on stainless steel tub of both kitchen aid dishwashers
Hi, Emilychee1
Do you have city water or well water?
How old is you home and the plumbing?
How long do you have the stainless dishwasher and sink?
Ill wait for you reply!!
ngafm
Sep 11, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
456 people viewed this question
Top Dishwashers Experts
Oloyede Monsuru
Marvin
Marvin
