Question about Arris SURFboard SBG900 802.11g/b (motosbg900) Wireless Access Point
192.168.0.1 is not default ip
192.168.0.1 is not working to allow me to sign into the router, any ideas? i have used it many times in the past but yesterday i downloaded utorrent and since then it has been slow and i was going to make sure of my settings and it looks like i cant get in. Any ideas what the ip address might have moved to? when i put it into the adress bar in saffari it say says "page not found" please help!
  • 8,404 Answers
Go get Network Magic free download eval version. It will allow you to do stuff that netrwork managers wish they could do.
192.168.0.1 may not be your address ... unless you set it statically. Most assignments are dynamic ... I guess you know that at some level.
So, I say get the free evaluation copy (read the deal while you are there) I use the paid pro version and I love it.
lete me know what happens
a
Posted on Oct 07, 2009
There should be four sets of numbers each seperated by a dot. These are the address of your router which will allow you to configure the router as you wish. Follow explanation below.
Broadband router manufacturers generally allow users to setup and configure the router settings through their web browsers. You just have to connect the browser to your computer and enter the default private IP address in the address bar of your browser.
The default IP address is factory set and is usually begins with 192.168. Some of the popular brands as given below use 192.168.1.254 as their default private IP Address.
  • some 3Com OfficeConnect routers
  • Netopia / Cayman Internet gateways
  • Billion ADSL routers
  • Linksys SRW2024 managed switches
  • Westell modems for Bellsouth DSL Internet service in the U.S.
192.168.1.254 Router Password
Alongwith the default Private IP Address, these manufacturers also set a default username and password. Users are allowed to change these default password settings. But in case they forget the changed admin and password details, they can use the hardware reset button to change all the settings to the default settings. In this process the password is also reset to the factory default value
Dec 17, 2013 | Dell Computers & Internet
MY PS3 WILL NOT LET ME SIGN IN. BUT I HAVE NOT CHANGED MY PASSWORD OR EMAIL ADDRESS. WHAT IS CAUSING THIS?
Lately I've seen alot of problems with people having a hard time signing in. Just a tidbit of background, the PS3 is very sensitive when it comes to the wifi card and network card sensitive enough that some modems, routers and modem/router combos have a very hard time allowing the PS3 to function online correctly. Now to get to the fix: unplug all cables from the modem and router for approximately 20 seconds and then plug all cables back in, modem 1st the router. Let the modem and router cycle through its powering and connection routine and then see if your PS3 will sign in. If it won't connect the the PS3 server still then find the reset button on the back of your modem/router or router if its 2 seperate devices and take a ball point pen and press the reset button in and hold it for no more than 9 seconds, allow the devices to cycle through and then try your PS3. If it still doesn't work then do the reset thing again but hold the reset button in for 15seconds this will put the device back to the factory setting (which if you use a passphrase, there will no longer be a passphrase and will make your network unsecure. You can put a new passphrase in using a PC and entering 1 of these 2 ip addresses in the web address bar 192.168.1.1 or 192.168.0.1 those are the 2 common ip addresses. Then go into the wireless tab and follow the intructions. If those ip addresses don't work then on your PC click on the start menu and in the search box type in cmd which will bring up a DOS prompt (Any Windows version XP and older you would type it into the run box) type this in exactly as I do ipconfig you ip address is the Default Gateway and thats the number you will type into the web address bar. NOTE; the most comon username and password to get into the modem or router is admin, admin. Comcast is admin, password1.
Sep 15, 2011 | Video Game Consoles & Games
My router stop working every day at a specific time and then after few hours it starts to work again
Log into your router, if you do not know the ip address of your router, open command prompt, type ipconfig, hit enter and you look at the default gateway, that is the ip address of your router. put that into the address bar of IE and sign into your router. Once you are in, check the security tab for timing settings.
Jan 08, 2011 | D-Link Vonage-enabled Wireless Router...
How can I play with two xbox at the same time? Right now when both are on xbox live one has a strict NAT and the other is open how do I set up my router so both can play with open NAT?
NAT (Network Address Translation) allows your router to use one IP address with your ISP, but assign internal IP addresses to your devices using DHCP. When you refer to "strict NAT" I have to assume you mean that the device has a static (set) IP. If you want them both to work at the same time, you'll have to set each xbox to accept DHCP addressing (ie., dynamic IP addresses) and make sure your router is set to perform as a DHCP server (which it probably is...that's the default).
Dec 29, 2010 | Arris WR850G Router (DHWR850G)
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Wireless security enabled and lan not able to work together
Try to set up an IP reservation for your ethernet using the MAC address of your NIC, this way the router can't steal it for the WLAN.
Mkae sure that if the router is run as a DHCP server that there are suffcient on IP address range to allow extra PC's to be leased an IP address.
I suggest that you disable in WZCSVC on both your wired PC and wireless PC and use the laptops own NIC connection software and the routers WEP or WPA-PSK to allow you to connect your wireless
Dec 14, 2009 | D-Link DI 514 Wireless Router (DI-514)
Have a new Hughes net HN9000 satellite service and trying to get the Netgear wireless router to allow me to connect to the internet. Have two other computer set up for the home network and they can see the...
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
Jun 30, 2009 | NetGear MR814 Wireless Router
My ps3 internet doesn't work
Easy Pie! This is a cinch anda guarantee work through. It involves putting your PS3 into a DMZ (demilitarized zone) which simply means opening all of the ports on it.
If you have the following problems, this is likely to fix it.
  • Not being able to join rooms
  • Not being able to speak over your headset
  • Not being able to hear other people over their headset
  • Not being able to join private games
  • Any problems to do with connectivity to the PSN, especially if your computer will connect to the internet, but your PS3 won't.
Part 1-(On PS3)
  • Firstly, you will need to assign your PS3 a static internal IP address. Normally whenever a device connects to your router it will be assigned a different internal IP address. These are normally 192.168.1.2, 192.168.1.3, 192.168.1.4 and so on. Assigning a static one will ensure that your PS3 will get the same one every time it connects.
  • Go to the "Settings > Network Settings > Internet Connection Settings" option on the PS3 XMB. Choose whether you are using wireless or wired.
  • Both selections should show a page called "Address Settings". Here you will need to select "Custom". Another page will then display entitled "IP Address Setting". The option "Manual" will need to be selected.
  • This will display a page where customizable IP Addresses are available to be entered.
  • IP Address - This will need to have the Static IP address in it. Use 192.168.1.80, simply because it is unlikely that 80 other devices will be connected at the same time.
  • Subnet Mask - always set to 255.255.255.0
  • Default Router - Is the internal IP Address of your router.
    1. To get the exact ip of your router you should go to
    2. Start
    3. Run
    4. cmd [Hit Enter]
    5. Type in ipconfig and hit enter, this should come up with all the ip addresses to do with your computer and the network. The address you will need to enter in this option is listed as "Default Gateway".
  • Primary DNS - Same IP Address as "Default Router"
  • Secondary DNS - Same IP Address as "Default Router"
  • Proxy � When you get to the proxy screen, select "Do not use Proxy"
  • MTU � Automatic
  • UPnP � Enabled
Part 2-(On PC)
  • In your Internet Browser, type the address of your default gateway, this will take you to your Router Configuration Page. Look for any mention of DMZ
  • When you have found this, it will ask you for the Static IP of the DMZ host. This is simply the Internal IP that you assigned your PS3. We used 192.168.1.80.
  • Finally, turn off your Router, PC and PS3 for a few minutes to ensure that the new settings are loaded. Then you're ready to go!
Courtesy of http://www.cod4forums.com/index.php?showtopic=3460
Feb 03, 2009 | Sony Playstation 3 (PS3) Console
Net gear router won't install properly and will not let me use the internet
You may want to try:
  • If both your router and modem have DHCP features enabled, disable the one in the modem;
  • manually set the Internet/WAN IP add of the router to follow the IP add of the modem;
  • manually set the default gateway of the Internet/WAN side of the router to use the IP add of the modem;
  • set the PCs connected to the router to automatically obtain IP adds.
  • verify that the PCs uses as their default gateway the IP add of the router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 12, 2008 | NetGear RangeMax WPN824 Router
How do I setup filters on my wireless router?
IP Filters IP filters block access to ports or a series of ports from an IP address on the LAN. For example, if you did not want the computer with IP address 192.168.0.100 to access the Internet, then you would block that IP address from accessing port 80. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Advanced tab and then click Filters to the left. Step 4 Select IP Filters using the radio buttons. Step 5 Select the Enabled radio button. Step 6 In the first field next to IP enter the IP address you want to block access from. If you want this to apply to a range of IP addresses, then enter the ending IP address in the second field. Step 7 In the first field next to Port enter the port you want to block. To block a range of ports, enter the ending port number in the second field. Then select the protocol type (TCP, UDP, or Both) using the drop-down list next to Protocol Type. Step 8 Next to schedule select Always using the radio buttons to continuously enable this filter, or select the From radio button to set a schedule using the time and day drop-down boxes below. Step 9 Click Apply and then click Continue to save the new settings. URL Blocking URL Blocking is used to block web sites that contain certain keywords. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Advanced tab and then click Filters to the left. Step 4 Select URL Blocking using the radio buttons. Step 5 Select Enabled using the radio buttons. Step 6 In the text box below enter a keyword to block. To delete a keyword, select it from the box below the text box, and click Delete. Step 7 Click Apply to add the keyword to the list. MAC Filters MAC Filters allow you to allow or deny access to the LAN by specifying MAC addresses. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the (default password is blank (nothing). Click OK. Step 3 Click the Advanced tab and then click Filters to the left. Step 4 Select MAC Filters using the radio buttons. Step 5 In the section MAC Filters, select the radio button for the mode you would like to use. Disabled - Disables this feature and will allow all wireless clients to connect. Allow - Blocks all clients except for what you enter in the list. Deny - Allows all clients except for what you enter in the list. Step 6 Enter the name used to identify the entry next to Name. Step 7 Enter the Ethernet MAC address that you wish to Allow or Deny next to MAC Address. Step 8 Click Apply and then click Continue to save the new settings. Domain Blocking Domain blocking lets you allow or deny access to certain websites. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Advanced tab and then click Filters to the left. Step 4 Select Domain Blocking using the radio buttons. Step 5 In the section Domain Blocking, select the radio button for the mode that you would like to use. Disabled - Disable this feature and will allow all clients on the LAN to access any website. Allow - Permits access to all websites except domains specified in the Blocked Domains section. Deny - Allows access only to domain specified in the Permitted Domains section. Step 6 In the Permitted Domains section, enter a domain to permit. In the Blocked Domains section, enter a domain to block. - or To delete a keyword, select it and click the Delete button. Step 7 Click Apply to add the domain the list.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Arris SURFboard SBG900 802.11g/b (motosbg900) Wireless Access Point Logo
239 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
