Question about Kenmore Refrigerators
Water is draining into a pan under the refrigerator, once in a while
    Top Expert:
  • Kenmore Master
  • 15,220 Answers
During defrost cycle water runs from drain into pan by condenser where heat from condenser actually evaporates it over time its a normal condition
Posted on Oct 07, 2009
    President:
  • 1,187 Answers
When the fridge defrosts, the water (melted ice) is collected into the water pan. Empty it when the fridge compressor is ON.
4 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool GD25DF auto defrost drain problem
There is a drain hole in the back of the freezer on the bottom. Get back there with some hot water. Most of the time it is just lime build up. Unless you know what feel back there. Another way is to move the freezer out and from the back side you can see the drain line. It just pulls right off
Posted on Feb 11, 2009
  • 123 Answers
SOURCE: Water leak under refrigerator, Frigidaire, FRS6R5ESBC
chk out dis video
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Posted on May 14, 2009
aasc
  • 1606 Answers
SOURCE: DEFROSTED WATER DOES NOT DRAIN TO PAN
Remove the food and the ice maker from the freezer ( if equiped ) and the bottom panel . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER ( ground wire is good ) solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on May 12, 2010
I'VE GOT WATER UNDER MAYTAG FREEGE,I KNOW there have to be some place where i can pour water to unblock it.
You need to access your drain pan. To do this you need to remove your freezer panel and your drain pan will be located under your evaporator coils. You can use a turkey baster with hot water to clear it with hot water. Once its clear you will want to dump an additional cup of water down it to make sure its clear. This will take care of your frozen drain line.
Good luck _MJ_
Feb 14, 2010 | Maytag MSD2756G Side by Side Refrigerator
Our Amana refrigerator is leaking
HI. This may be a clogged drain pan. The drain pan should be removed and cleaned at least once a year. The drain pan is located at the bottom of the refrigerator behind the front grill. Remove the grill, which snaps into place. Grasp the drain pan while pulling slightly upward and forward.
Clean the pan with warm soapy water or warm water and baking soda.
If the pan rattles when it is replaced, it is too close to the compressor. Simply reposition the tray.
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve. The hoses may be loose here.
Nov 11, 2009 | Refrigerators
Freezer side is leaking water & temp is 25
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 12, 2009 | Jenn-Air JCD2389G Side by Side...
Maytag Plus MTB2456AEW leaks from inside refrigerator onto the floor.
condensation- bad door seals. replace seals.
in fridge- condensate drain plugged. unplug drain under coils.
under fridge- condensate pan full. empty pan.
Aug 27, 2009 | Refrigerators
Mine collects water under the crispers also.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 17, 2009 | Kenmore 64802 Top Freezer Refrigerator
Drain pan under unit does not appear to have seen any water and c
you have a blockage in the drain tube, remove panel back of freezer..you will see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. the reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck!
Jun 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water from defrosting unit in freezer is draining inside the bottom of the refrigerator ,not in the water pan under the unit
That means the drain hole is clogh in the bottom back inside the refrigerator.Put hot water in until it goes through, the best way to clear it is blowing presurise air through it but i8f you don't have acompresor you can do it very careful sticking a wire until it goes through to the drain pan and once in a while put bleach through the hole to keep it clean(every 3 or 4months).
Apr 17, 2009 | Refrigerators
Frididaire side by side refrigerator- water freezing in bottom
Frozen or Plugged Defrost Drain
On Side By Side Refrigerator
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models the pan is accessible without removing the back panel and others are not.
Once you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster like this one: Turkey Baster http://www.repairclinic.com/SSPartDetail.aspx?PartID=428708&PPStack=1
To squirt hot water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
Jan 27, 2009 | Frigidaire FRS20ZSG
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Kitchen aid refrigerator superba
hi there,
the drain pan is under the fridge behind the kickplate. the kickplate is the vent-line panel located under the door. it's held on by 2 screws. unscrew the screw and remove the kickplate. the drain pan will slide out. careful, as it's probably pretty full.
Oct 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
109 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
