When it opens the black screen, on that black screen press file , then perference, then on the right hand press camera source,when you press that, press that little arrow, so you can see your driver there, select it, hit ok, then ok. close the cam and open it. it should work.
Once your webcam is working on your computer,you can configure it to Yahoo Messenger. YAHOO SPECIFICATION To find out what the requirements are for messenger webcams and automatically download the latest control software , check out the following. http://help.yahoo.com/l/us/yahoo/messenger/messenger10/webcam/mstacamtest.html You have to Use Internet Explorer for that.
Note Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the Yahoo software may have difficulty in locating it, and you can get a 'webcam not located' or 'webcam being used in another program' error message. Mine, I just unplug it from the USB and plug it back in, if yours is integral with the computer you will have to re-start the computer, use the keyboard shortcut or disable / enable from the Device Manager. Of all the chat programs, Yahoo is the most painful software to set up but if you follow these instructions you should be ok.
INTERNET CONNECTION Webcam connected Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have make sure your internet connection and country are correct in the lower two boxes > Apply > OK
TESTING > Messenger > My webcam - the warning panel will launch, click 'OK' and your webcam will start. You should be rewarded at this stage with your happy smiling face.
DEFAULT With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK Take a note of any additional software, if you have multiple choice for Camera Source, you may wish to uninstall any redundant webcam software later to prevent conflicts
PERMISSION OPTIONS > Messenger > Preferences > Webcam - make your selections ( who you will allow to view you) > Apply > OK
IN USE When you are both on line and wish to show your webcam > Actions > 'Invite to view my webcam'. This will launch an invitation on your contacts screen when they 'Accept' your webcam broadcast will start- There can be considerable time lag ( 1 minute) before they see you, so dont be too impatient ( You can check the status on the bottom left of your webcam panel. You can 'drag and drop' the frame to a convenient location by grabbing the top border. There is a shortcut ( webcam icon ) down by your pic as well Your contacts may need to configure their connection the same as INTERNET CONNECTION above or they may get a "webcam not connected" message
Go to Preferences of Yahoo Messenger and specify this webcam as your default camera. Then only will Yahoo look for it. And the webcam has to be installed before that. So,install the webcam and set it up as default in Yahoo Preferences and then use it in Yahoo.
This is happening because the Dell webcam central is accessing the webcam at the same time as yahoo messenger. Click on start and click on Run(XP), Type MSCONFIG in start search (Vista) and you'll get the system configuration utility. Open it and go to the startup tab. Uncheck anything related to Dell webcam. Click on Apply and OK and restart the computer. If yahoo messenger shows a black screen uninstall Yahoo messenger and reinstall with the more recent version.
try to go to yahoo messenger and then preferences and look for the camera source, make sure that the camera source is your webcam if its not choose it, try it and then tell me if it wont work.
I had the same problem... unhook the webcam, uninstall the drivers
& rehook it up & let it install them again & go to Philips
website & download the update & reboot computer. Works great!
If you see a black screen when broadcasting your webcam: There may not be enough light in the room. If so, illuminate the room appropriately. Your camera may not be functioning properly. Try your camera with the manufacturer's software. The correct camera may not be selected by Yahoo! Messenger. To change your camera source: 1. Click the "Messenger" menu in Yahoo! Messenger and select "Start My Webcam." 2. Click the "Messenger" menu in Yahoo! Messenger and select "Preferences." 3. Click the "Webcam" category. 4. Click the "Camera Source" button. 5. Click the pull-down menu and select the desired camera. 6. Click the "OK" button. If you see a black screen when viewing a friend's webcam: Check the status message at the bottom of your viewer window. If it says "Stopped," the person broadcasting has stopped broadcasting images. Ask the person to resume broadcasting and try viewing again. If the person is in fact broadcasting and you still see a black screen in your viewer, ask them to check their camera and take the webcam compatibility test.
