Question about Whirlpool Duet GHW9150P Front Load Washer
FO2 AND SUD
HELP IGET THE FO2 AND SUD CODE HAD A REPAIR PERSIN HERE 2 TIMES AND WAS TOLD THE PROBLEM WAS FIXED EVEN RAN MACHINE WITH NO SOAP STILL SAME PROBLEM THEN WAS TOLD TO RUN A GALLON OF WHITE VINEGAR THROUGH MACHINE SAME PRBLEM WITH ABOUT 15 MINUTES LEFT FO2 MESSAGE AND BEEPING
  • 9 more comments
  • Anonymous Dec 26, 2007
    I have the same issue; however, I am just now looking for solutions to this. I will try the gallon of white vinegar.
    Hi, Don't be upset anymore! I was looking for a solution, to the exact same thing today, I looked through the drain hose and except for a little water, there was not too much in there. Next and this is what i suggest you do too. I checked the pump filter. To do this, simply take the 3 small screws out of the front panel that is mounted just below the door. Once you do this remove this panel. Now simply unscrew the cover on the beige colored plastic housing right in the front middle. I unscrewed the cover, and removed it. The filter is nothing fancy or a separate part. It is just a part of the cover that has holes in it. It catches big items, and keeps them from getting into the pump. I found two small socks, a ball point pen, and two hair clips in mine. When i put it all back togehter, i put a load of wash in and waited for the rinse cycle. Wow i can't remember the last time water came out of it that fast. I don't know if the repair guy did that on yours when he came out, but it sure cured my problem. Hope this helps.
  • LISA ALLAN Dec 29, 2007
    i tried all suggestions left machine unpluged for 4 days took kick panal off and cleaned out filter still same problem i dont really want a repair person coming out again if they arent going to do anything
  • Anonymous Dec 29, 2007
    Man! I was just about to call the doggone repair guy, when I read about the unscrewing of the pump housing. I did the gallon of vinegar, with no help. Today I was going to call the repairman. ...unscrewed the pump housing, as you read on this post, and it was loaded with stuff that I don't choose to type on this. The machine is just as awesome as when it was new! Do this! Even if you don't have problems with draining, do this regularly! Wow!
  • tomnanliz Dec 30, 2007
    I cleaned the filter in bottom of machine and the problem is cured, also when the serviceman came he also told me to try vineger and bleach but you would not believe what I found in that filter.Thank you so much for the solution.
    tomnanliz
  • Leadfoot999 Jan 05, 2008
    have the same problem with my wirlpool model ghw9400pw0, I need to find the filter or the blockage do you have ant ideas
  • Anonymous Jan 06, 2008
    i did this too but it still says f 02 and sud. any other ideas?
  • Kim_BT May 05, 2008
    Hello .
    I got the same problem with my washer last year , F02 and SUD error .
    It ran la champ after I clean all junks from the filter. However those
    errors just come back yesterday . This time I don't find any junks in
    the filter . I took out the pump and check, don't find anything wrong
    with it .
    The washer runs find through all the cycles, but when it hit the SPIN, where the F02 and SUD occur .
    I have to turn off the washer and let it sit over night then I manually turn knob to DRAIN/SPIN then I will complete the load
    Any suggestion what is wrong with this. If the pump is bad then how i
    work from early cycles or after the washer turn off for a few hours
    Thank you very much and have a nice day all
    Hello .
    with it .
  • Anonymous Oct 12, 2008
    I had the exact same problem with the "sud" and "FO2" error codes. Just remove the 3 screws at the very bottom of the front panel under the washer door. Your prefilter will be light brown, just unscrew it and remove all the junk inside. Make sure you put a towel under the washer when you remove the cap. I found a sock, wash cloth, clothes pin, safety pin, and lot of other horrible things. Hope this helps
  • Anonymous Mar 30, 2014
    Soap suds leaks from the bottom of my washing machine. The repair man came several times and found no leaks or any problems. The problem seems to be getting worse.
I am going to try the filter solution and I will let you know how it works. Just FYI my girlfriend had the same problem (FO2 ans Sud) she switched to a powder HE detergent and said it solved her problem.
Posted on Jun 24, 2010
Hello .
I got the same problem with my washer last year , F02 and SUD error . It ran la champ after I clean all junks from the filter. However those errors just come back yesterday . This time I don't find any junks in the filter . I took out the pump and check, don't find anything wrong with it .
Any suggestion what is wrong with this. If the pump is bad then how i work from early cycles or after the washer turn off for a few hours
Posted on May 05, 2008
Thanks,
I just cleaned the filter as suggested here and all is fine now.
Thanks again.
Posted on Jan 07, 2008
Ok first put the washer on fill then pull the drain hose up to the top of the stand pipe have some one switch it to drain and lets see how strong the flow is should be pretty strong but just because the pump runs doesnt mean its at peak efficency let me know what you find your drain hose could be partility blocked especialy if youve wased rubber backed rugs in it ill be with you so let me know what ya find we will go from there
Posted on Dec 29, 2007
HAVE YOU TRIED UNPLUGGING FOR A LONGER PERIOD SO COMPUTER LOSES ITS MEMORY.
Posted on Dec 25, 2007
My maytag5000series has sud and code f-35 whats wrong
Your probally not using H.E. detergent!!!Or using to Much of it!!!Have to use he detergent and proper amount!!!! Try running machine with no soap a few times without adding soap:)
Mar 15, 2013 | Maytag Washing Machines
Duet washer , clean filter still get sud reading. Washes well without clothes. Wash with and without soap and did not put in clothes. The machine went throught the cycle with no problems. When you
do you get a lot of suds when you run it without soap and clothes ? if so put about a cup or 2 of vegetable oil into the washer and run a cycle . soap suds will adhere to the oil and it will help it to remove from washer . after you can run a clean cycle with bleach or white distilled vinegar.
Feb 20, 2013 | Washing Machines
My kenmore washer showes sud code
If it is similar to the Whirlpool duet,
Try using less soap (hi eff machine)
try using more fabric softner
to clear the occasional Sud warning, I run the machine on "quick wash" with no detergent/additive. gives it two more quick spin cycles in 30-35 minutes, usually clears it.
Jul 14, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sud code appeared
If you have a front-load washer then you probably have put too much soap in or not used "he" soap. Front loader use very little water and need low-sudsing soap. Most all brands now sell this "h.e" soap. What has happened is that suds have travelled up the tube to your pressure switch and have told the washer's computer that there are too many suds in the machine. The machine thinks that there is water in the tub even it there is not. You can either let it sit for a day or two or try unplugging it and then run a few hot rinses, without any soap, until you don't see anymore suds in the tub.
Jul 21, 2009 | Washing Machines
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool ghw9150 help !!!!!!!
I would run the drain hose into a bucket or the sink to make sure that it is not your plumbing if it still gives you the code replace the pump just because this pump is putting out water doesn't mean that it is doing it as fast as the machine wants it too. Those pumps are not that reliable and have tricked me a couple of times until I replaced them. good luck.
Dec 27, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
F02 Error Code & SUD message
Knowing from our washer, the SUD code is too much foam from the detergent. Since most soaps today are highly concentrated, or High Efficiency soap, try using less soap as a starter. :)
Nov 17, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE4t Washer
WE had a person with the same problem with her HE4 front loaded washer. What we discovered was when we opened up the soap resivour was that soap built up around the float valves causing them to stick.
A technician I knew put vinegar down the soap dispensor and ran the cycle, with the washer empty. He put it on in the hot water mode and ran it for four or five complete cycles like washing clothes.
It worked for him. Try it like it did for him to see if it helps. If not, you will need to contact a service technician to see if the SUD error code means something else.
Sometimes the timer boards get a bit of moisture on them and cause a corrosion headache. I have yet to see anyone figure out a way to dry them off, and when condensation builds up, it usually means there is a problem causing the condensation to get that far up. On some versions a foam seal gets worn out from time, often needs to be replaced to prevent moisture built up.
Another thing that sometimes does it is the back of the machine, will be too close to the wall or have debris back behind there causing it not to be able to breath.
May 14, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
465 people viewed this question
Dan Webster
Dan Webster
Sal De
