Question about Toshiba Satellite A105 Notebook
Those two thing that look like that snap on next to the thing i have to keep plugging back in to get it to come on are they welded on because they come lost i put them back on they look like they run to the on and off switch its a little white cord and a black wire they snap back on but did it make it break contact when they come off dstringfield@hotmail.com
  • 184 Answers
That thing that your describing is something i have never seen in my life, and most probably wont. The best that I can help you is that you should bring that thing your talking about along with the thing that plugs it on to, to a technician who can clearly see that thing that you are describing.
Posted on Oct 07, 2009
I have a120 MW snap-on welder that the wire feed works i accidentally touched to ground clamp sparked, and know nothing. is there a fuse or breaker??? the wire feed works still
Replace your contact tip on the end of the mig gun
Sounds like youve arced it out and the wire is stuck in the end of the contact tip but steel feeding possibly spitting wire out of the drive roll like we like to say birds nest
Dec 06, 2015 | Snap-On Welding Tools
Have a 71 miller big 40 won't ark and no power out of plugs put a new ingniter on welded for an hour then shut it off when back the next day and it wooden weld ageen S\N HE802998
hi, you have 2 big resistor with ajustable tab on it,check for visual damage on it and rusted connector or tab,
replace tab at same place if you disasemble it
Feb 16, 2014 | Welding Tools
I have a 2005 CRF 80. The shift lever has stripped the knerling on the shift rod coming from the gear box. Is this a difficult repair or can the shift lever be welded on?
To fix it properly you need to strip the engine You can just weld it on but cool with water as the seal will melt It isn't good welding it on as they do tend to snap the weld sooner or later. But nothing to loose if it keeps breaking you just replace the worn shaft anyway
Oct 26, 2013 | 2006 Honda CRF 80 F
APC SmartUPS X (SMX1000)- "AVR Relay Weld" error message
I had this exact problem after a major power out: Fault, call support: AVR Relay weld.
I fixed it by resetting the UPS: Remove battery connect at rear of UPS (it is marked, just unplug the bat connect tab). Plug the UPS back in, and then turn on. Let it power up... it will tell you it needs a battery. Next, power it down and unplug. Plug the batter connect back in (see rear). Plug in the UPS.. power up. Presto.. it is reset. If it is NOT reset, there may be a real 'relay weld'.
May 13, 2013 | Computers & Internet
I have a century 125 110 welder, the welding wire backs up to gun when stricking arc
Hi there, Sounds like your wire speed is to slow or not feeding at all.Your wire may be crossed or the spool may be to tight.I lay mine on the side so the wheel shavings fall away from the wheels. and I open the lid to see whats going on.One time I got the wire twisted and It wouldn't work right and it finely snapped in to.Take the label off and that can help to.Feed some wire out with out striking an arc and watch the spool and rollers.Make sure wire is in the proper grove.One last thing you want to feel the wire push your hand back when you weld.Depending on the use you may need a new liner.Thank you for choosing FixYa.............Darryel
Aug 08, 2011 | Century Welding Tools
My snap on welder isn't working properly. With the heat dial turned all the way up, I have to turn the wire speed almost all the way down. Even with it in the hottest setting it welds cold. Won't even burn...
I own and love my Snap-On YA-212A and had a similar problem that turned out to be a power issue, not a welder issue. Repair costs and parts availability of these welders can vary wildly, it may be cheaper to replace it with a Lincoln, Miller, or Hobart. Snap-On uses more than one supplier to make their welders, if you tell me the exact model number I can probably tell you who manufactured it,
For now, try the following:
  1. Unplug the welder from the power outlet on the wall
  2. The power cable where it connects to the welder should be a twist lock type, make sure it is not loose. Take it off and look for any signs of arcing that look like it may have been a bad connection
  3. Look at the power connector that plugs into the wall and look for signs of arcing. If possible, take the back off the plug that goes into the wall and ensure that everything looks tight.
  4. Put the power cable back on the welder
  5. If your breaker box has a load controller turn it off and try your welder again
  6. Replace the circuit breaker in the breaker box on your house
Feb 26, 2011 | Snap-On Welding Tools
Trying to change the oil pan gasket due to leaks. I have removed the oil and all the bolts, but the pan wont come down. It is blocked by the exhaust manifold. I unbolted it but I think is is welded to the...
The only thing you can do if its welded there is cut the catalytic converter pipe and weld it back together when your done. Keep in mind that you want to try and cut the pipe in the easiest place that you will be able to weld it back together.
Jan 07, 2011 | 1988 Cadillac Allante
I am having a issue with the feed and the welder quits welding after about a inch of welding then will intermittently weld for a second or two then stop again. I use this welder to keep my family tractor...
First thing I would check is the relay that sends power to the transformer when you pull the trigger. That can be one of the hardest parts of a Mig welder to troubleshoot because you can read full voltage through the thing with a multimeter when the contacts are dirty and it's not functioning properly.
That's assuming you're losing power. If it's a feed issue then we can address that later.
lp
Nov 22, 2010 | Snap-On 3 Snapon Mig Welder Gas Nozzle Ya...
Have a 120 volt 70 amp stick welder what gauge or stick type do i use
1/16th stick to 3/32nd.
3/32nd being the maximum. Don't use 3/32 for an extended period of time, or you can burn up that welder. (Even if it has a fan. If it doesn't have a fan built-in, I invite you to put a house box fan, close to the ventilation slots for the welder)
I would also recommend using 6011 rod. It's a mild steel rod, and is excellent to begin with. Usually used for filling, and medium strength situations. It does splatter, be aware of that.
Not trying to give you a tutorial on beginning welding, but would like to offer some tips:
1.Make sure the ground clamp has a good, clean surface it's clamped to. If not, it will be very hard to get the rod started, and also to keep it going. (Makes bad welds too)
2.Start with a B U T T weld. (Had to type it that way do to censorship of certain words)
That's laying two pieces of metal next to each other, and laying a bead in-between them. Easiest thing to start with. Go to corner welds next, (Two pieces together at a 90 degree angle), then try Uphill welds.
3.Shield flipped up on helmet, welder on. Lay the rod past the area you are going to start on. Past the metal edge. Lay the ->flux coating of the rod on the edge of the metal piece. The tip of the rod is past the metal edge by at least two inches.
This way you are lined up to begin the weld. Then flip your shield down, draw the rod back, until the tip of the rod touches the metal. Once the arc starts, lift the rod up a little to get the correct height, and keep that arc going.
4.Watch the PUDDLE, not the arc! You are watching the melted metal in front of the arc. You need to see how that puddle is doing, in order to compensate by bringing the rod closer, or further away.
5.Use a Zig-Zag pattern to begin with. Keep the Zig-Zag close to each other, until you are comfortable enough to make a longer pattern. Watch the penetration. Good penetration is the key, not a pretty weld.
6.Use the proper safety equipment. If the welding helmet lens has a tiny little scratch, you will burn your eyes. NO fun, believe me!
You won't know it until you wake up the next day with your eyes swelled shut!
Cover your arms, and use welding gloves. Welders give can give you a radiation burn, worse than a bad sunburn. NEVER just start welding a little with No welding helmet. Welding goggles are for the birds, or Acetylene welding!
Be safe, have fun welding!
Sep 02, 2009 | Welding Tools
Relay clicks, gas blows, rollers dont turn
If you use it regularly, the liner should be replaced about every 6 months. Make sure you get a wiper for the wire. It goes inside the machine, on the wire, just before the feed rollers. It keeps the dust from clogging the liner.
Feb 08, 2009 | Miller Welding Tools
Toshiba Satellite A105 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
