Question about JVC AV-48WP30 48" Rear Projection Television
JVC 48 inch rear projection tv with 2 spot in center of screen. one is blue/green the other is yellow. ther are stationary and appear only when the tv is on. Looks like someone used crayons on the screen but disapear when tv turned off. any thoughts?
    Top Expert:
  • JVC Master
  • 14,553 Answers
Yes, I know what is wrong and there is a simple way for you to confirm this.
Have you ever seen a TV with just a white line across the screen from left to right? On a regular TV if this happens and you leave it on long enough it will burn the mark into the screen.
I suspect what you have is two of the picture tubes in this projection TV have a burn--it is caused because the set lost either horizontal or vertical sweep--picture either closed from left/right or top to bottom for a moment and then came back on instantly---burns a mark in one or more of the 3 tubes screens.
Way to confirm is simple--with the back cover removed cover each lens one at a time with the set turned on--be very careful when you do this not to touch anything else---
if you cover a lens and one of the marks goes away that tube is burnt----my guess is you are going to find at least 2 of the 3 tubes are burnt on the screen---
Problem here is the tube or tubes need to be replaced to correct this AND whatever caused this HAS TO BE FOUND ALSO OR IT WILL DO THE SAME THING TO THE NEW TUBES--
CONSIDERING the cost of two or more replacement tubes you are most likely better to buy a new TV---I have seen about 100 sets with just exactly what your are describing---It does not happen a lot--but once it happens the damage is permanent.
I know I am not giving you good news but I am sure from your description this is what has happened.
Sorry to give you bad news---see for yourself if you cover each lens one at a time--if you do this and the marks are gone you know exactly what has happened.
IF YOU HAVE ANY QUESTIONS OR NEED MORE INFORMATION--let me know here--I am here to help but cannot always give good news.
SD TECH
Posted on Oct 07, 2009
Cannot boost yellow on screen
A few suggestions here--first if possible look into the lens of the tubes with set on--is one brighter than the two others? A loss of blue to some degree would mean yellow (red and green).
Also ( you may have to remove entire grill from front below screen) with set off make sure all 3 of the circuit boards that plug onto the bottom of the necks for each tube are not loose or one has not slid down a bit.
Jun 12, 2012 | JVC Av-48wp30 Iart Pro 48-inch Widescreen...
Jvc manual
Well there is no yellow, there is only red, blue and green, Blue is the set line the other 2 need to be aligned to. If blue is bent or out of alignment then there is a problem with some internal chips that would require a good deal of soldering skill
Jan 03, 2012 | JVC AV-48WP30 48" Rear Projection...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Feb 10, 2010 | JVC AV-48WP30 48" Rear Projection...
Cleaning JVC rear projection screen (behind cover)
You will have to do some dissassembling of the cabinet to remove the screen and bezel assembly. If you are will to do this I can give you the directions.
Mar 22, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC Model AV-48P575 Green/Yellow Screen
i would check the red color first it sounds like your loosing red
Feb 22, 2008 | JVC AV-48P575 48" Rear Projection...
Jvc tv picture quality
sounds like your crt tubes...meaning Red, Green and Blue are out of alignment...or possibly 1 of the crt's is burned out.
Jan 29, 2007 | JVC AV-48WP30 48" Rear Projection...
Lcd rear projection fixed pink and yellow shadows on the screen
you can't do anything about this TV. Theres no such thing as a LCD rear projection television.
Sep 01, 2006 | LG RU-52SZ51D 52" Rear Projection...
Lamp issues
No its a tube and not a bulb. If thew line is green then theres an issue with the red and blue as the green is stationary on most sets unless thers a green centering ? Its a componet on the convergence board thats bad or going bad but if you replace any components on the board most likly your gonna need to do a convergence alighnment I would let a pro handle this repair unless your an experineced repair tech Good Luck
May 21, 2006 | JVC AV-56WP30 56" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
337 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
