Question about D-Link 4-Port Ethernet Broadband Router EBR-2310 (EBR2310)
I have an ADSL D-Link modem (DSL-300G)that works fine. I hooked a D Link wired router, EBR-2310 and can't get to the internet. It use to work until one day recently the kid moved wires arround because no internet. I had to call my ISP to get the ADSL modem working with no luck to get the router working again. Message says no internet, check with your ISP. Any ideas to help get it working?
  • rpfore Oct 07, 2009
    Thanks Gort007,
    My ADSL works great, still no router.
    I tried your suggestions also tried different wires, all 4 ports,unplugged router for a few, tried their web site (192.168.0.1)nothing.
    Used D-Link roter CD error 103 internet connection not varified.
    Also tried the computer, clicked on double monitors with yellow triangle near clock, repair local area connection, I get could not finish, action can't be completed, contact person who manages network (thats me).
    Any other thoughts?
    President:
  • 1,187 Answers
First: Connect your computer directly to the ADSL modem. It has an Ethernet port.
If you can't get to the Internet while your computer is connected directly to the modem, then ytour router never will either. Call ISP if you can't connect to the Internet when directly conencted to the modem.
Next: Check your router wires again, The modem must be connected to the "special" port on the router. Look at the router. There is one port separated from the rest. Connect the modem to that port. Conenct to the Internet.
Still no Internet?
Reset your router by pushing a stylus (straightened-out paperclip) into the reset "hole" on the router (with router powered ON).
Push & hold for 30 seconds or until the lights do their reset dance. Connect to the INternet.
Posted on Oct 07, 2009
  • Just Gort
    Just Gort Oct 07, 2009
    Yes, thanks for the details....
    Now: Set the IP address on your computer as follows:
    IP Address: 192.168.0.3
    Subnet mask: 255.255.255.0
    Gateway: 192.168.0.1
    The DHCP on the Dlink may not be assigning IP addresses.
    If the above info doesn't work, then reset the DLink again.
Telecom Issue, when a Netgear router (DG834G) linked to a small server unit, dissconnects the telephone line. The router works fine but no dial tone on the phone side of the micro filter. Any assistan
a POTs (plain old telephone) line should never be connected to a router. that adsl filter does not make a phone line share a data line.
ADSL is a type of internet service supplied over a phone line. think of it as raw (unusable) when its on the phone line. then you use your dsl filter/splitter to feed the raw internet into a special dsl modem and the other port can be used by a standard phone.
you will know a dsl modem when you see it because its uplink or internet port will only be big enough to fit a phone cord into, not an internet cord. these dsl modems then feed usable internet to your routers and all devices on your network. but, like i said before, at this point it is too late for your phone and internet to share the same wire.
OK, thats not entirely true
pin out of RJ45 internet
1=orange/white *
2=orange *
3=green/white *
4=blue
5=blue/white
6=green *
7=brown/white
8=brown
1,2,3+6 are used in a typical network
if your network is typical you can "get fancy" and use 4,5,7+8 for telephone or even put 2 data lines on the same wire (not recommended for long distances). however, this may involve cutting some wires and splicing them together or something.
Sep 14, 2012 | NetGear Computers & Internet
Can you help me connect my Zonet Wireless AP Router ZSR2104WE now that I have purchased a new modem (Motorola DSL Modem 3360)?
You must hook these particular items up in a specific sequence. First power down both the modem and the router, only connect the modem to the isp until all appropriate lights on on. Next plug cat 5 to router where it is labeled internet or wan if neither label then to #1. until alights come up on router. Hope this helps.
Sep 06, 2012 | Zonet ZSR2104WE Wireless Router
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
Will my DSL 300G Modem work
it will work if the subscription would also be an adsl line. but you need to know the new providers settings including type of connection (pppoe, dhcp, etc) and the vci settings. once you place the settings correctly, it will work.
Nov 05, 2009 | D-Link DSL 300G+ (DSL-300G+) Modem
What is the default password for Verizon modem using a D-link EBR 2310 router...?? O_o
The default user administrator account is: Admin
The default password is: <blank>
Mar 19, 2009 | D-Link 4-Port Ethernet Broadband Router...
Slow internet connection to my x-box. Problem
Try to open the ports of the XBox to the EBR-2310 router.
Ports of the XBox: TCP 80, 3074 and 53
UDP 88, 3074 and 53
You'll needing to access the configuration page of the router (192.168.0.1) and open the ports under port forwarding.
Mar 09, 2009 | D-Link 4-Port Ethernet Broadband Router...
Adsl led is not glowing 802C D-link
when the adsl is not blinking that means your phone line is having problem plz ask your phone line provider to check the line.
Dec 23, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Can I piggyback a wireless router onto a hard-wired router?
Yes, you can connect the DI-624 to your exitsing EBR-2310, you just need to connect the a cable from port 4 of the EBR-2310 to the internet/wan port of the DI-624, then after that you can already use now the wireless to your laptop and also the wired router to your desktops.
But I may suggest you to just replace the EBR-2310 with the DI-624 so you will only be using 1 router that can cater your laptop and also your desktop, Just connect the cable from your modem that is conencted now to your EBR-2310 to the internet/wan port of the DI-624 then run the setup CD that should be it.
Hope that helps...........
Aug 30, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-LINK WBR-2310 SET-UP
Sounds like you need to 'copy' the mac address of the computer it was orginally hooked to before and put it into the router. Some routers have an option to do this in the settings menu of the router with one click.
May 15, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
412 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
