Question about Bose 3 2 1 GSX System
Cd/dvd player noise
When a CD or DVD is playing a grinding noise seems to come from the back of the unit. It does not affect the video or audio playing capability. However the 'noise' is worrisome. Any suggestions?
  • 1 more comment
  • venza Dec 06, 2008
    i also have owned my bose dvd player for 5 years and just a couple of months ago it started making a creaking noise, that just comes and go's every 30 seconds while the movie plays fine, the noise will gat loud and then fade then louder still 30 seconds later, it make watching a quite movie imposiable.
  • pitdogs Jan 26, 2009
    How can I replace the DVD player on the system?
  • chatjoy81 Apr 23, 2009
    i have same problem....can i resolved this with out opening the unit??
    my email is
  • 52 Answers
Something could have been misalligne or not sitting properly in the DVD rom...if the grinding sound is mechanical. The only possible way to cure this is to open the DVD ROM and service its mechanism. Observe DISC that is played if there's any sign of scratches...sign tells that its touching or rubbing something.
Good Luck.
Posted on Jan 03, 2008
How can I record a music cassette to a music disc on my Magnavox DVD recorder/ VHS --Model # ZV427MG9
You can't burn a CD-A with the ZV427MG9. The unit will not burn to a CD to play in a CD player.
You may be able to record the audio to a DVD with no video source. Connect your cassette player to the Line In audio ports (L/R) at either the back or front of the unit. Depending on your cassette player, you may need a 3.5 mm M to RCA F/F adapter to connect the RCA audio cable to the cassette player's headphone jack. Do not connect a cable to the video input of the composite input unless you have a video on a camera or something to play back. This means that the recorded video may say "No Signal" or will be black or static. (Note: this may not work with this signal issue.)
Set the unit to record to DVD on L1 or L2, as needed, by pressing Source on your remote. Advance the cassette to where you want to record. Press Rec on the DVD unit and then press Play on your cassette player. If you want to identify tracks, Stop the recording and play back and then press Rec and Play again. You are at risk of having issues with the volume during the recording. Clipping of overly-loud sounds and distortion is possible.
When done, finalize the disc, if desired, to play the disc on other DVD players.
If you want to make an audio CD, you would be better off using a computer and connecting the cassette player to the Line In jack of the computer. You do have to make some adjustments to avoid recording the default Microphone input. Use a program like Audacity or any other audio editing program. Record the signal and divide it into tracks, if needed. Now you can filter out any distortion as well. Then save as a WAV file. Use a different program to burn the WAV files to a CD-A. (This must be burned as a mastered disc; my attempts that worked on an older CD player failed if there were gaps between the tracks. Lots of programs will do this; Roxio Creator is one option.)
The manual for the ZV427MG9 is available here: .
I hope this helps.
Dec 31, 2012 | Magnavox Televison & Video
My dvd player doesn't support wmv, avi, dat, mpeg, mp4 or 3gp. What should i do
This DVD player is supposed to support:
Supported Audio Formats Audio CD, MP3
Supported Video Formats DVD
Number of Audio Channels 4 Channels
Included Units In-Dash Player, In-Dash Monitor, Amplifier
Supported Media Types DVD-R, DVD-RW, CD-R, CD-RW
Monitor Size 6.5 inch
Touch Panel With Touch Panel
Just stick with these formats and it should work fine...are you trying to view burned movies or something. From the looks of it, it should play any DVD or CD just fine. Try to steer clear of those formats you listed.
Oct 18, 2010 | Pioneer AVIC-N2 Car DVD Player
Lg cd/dvd rw will not play or record. but will play mp-3
It should "play" commercially-produced audio CD disks.
With the correct software (PowerDVD, et cetera) it should "play" commercially-produced audio/video DVD disks.
It seems to be reading "data" disks (MP3 files are just "data" files), and passing them to your software (Windows Media Player, iTunes, WinAmp) for decoding and playing.
You need software (Nero, or AShampoo Burning, or ...) to be able to "burn" CD and DVD disks.
Jul 03, 2010 | Computers & Internet
Dvd not playing dvds
Basic Information:
i) try to choose  right burner for eg: Nero CD/DVD Burner
ii) try to choose the right format,
     for eg: MP3/MP4/ Audio Songs will come under Audio format
               in such case select "Audio CD/DVD format" in Nero CD/DVD Burner
     for eg: .DAT/MPEG/MP4/Video will come under Video format
                in such case select "Video CD/DVD format" in Nero CD/DVD Burner
     for eg: "DATA CD format" is only storing some data on CD/DVD iresspective whether it is                            Videofile or Audio file,
                these "DATA CD formated" CD/DVD when played in DVD Player will play only Audio files
                but no Video Files
Dec 26, 2008 | Televison & Video
Using remote to play video DVD
You need to bypass your A/V tuner for your video connections (if possible). Plug your video directly into the TV and audio into the tuner. This will also give you a cleaner signal/picture as it does not have to processed by your tuner BEFORE it goes to your tv. Think of it as cutting out the middle man. Your tuner is best left for powering your speaker and not controlling your video despite all of the available connections in the back of it.
I would also get rid of your VHS and cassette players as they are dead technology. Clean up your system and remove the clutter. This will lessen your chance of getting interference. Good luck!!
Oct 01, 2008 | Toshiba 32D46 32" TV
Problem playing DVD's
bring (cd cleaner)cd from near radio shack and run it until you get good result.
Jul 05, 2008 | Panasonic SA-HE90 Receiver
LG DR6921W DVD Recorder. Unit will not recognise DVD discs (Blank or commercially recorded)but will recognise and play audio CD's. Unit is 3 years old.
That is most common problem of DVD player recorder,when getting old cannot read DVD discs,only video cd and audio cd,sometimes does'nt read video cd also. The problem is in inside of the unit the DVD processor is defected already or maybe the solder is crack, need to resolder again or reheat the processor solder, or that processor change with a new one,so the performance will back again,good as new.The lense of that unit is good,i can assure that.
Jun 14, 2008 | Audio Players & Recorders
Magnavox DVD Video Player DVD609AT
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• Compact Disc-Interactive
• Compact Disc-Recordable
• Digital Video Disc-Video
Recordable (DVD-VR)
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
12 cm
12 cm
Approx. 4 hours
Approx. 8 hours
Approx. 80 minutes
Approx. 160 minutes
20 minutes
8 cm
8 cm
Disc Type Contents Playback Time
Disc Size
74 minutes
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
Recordable (DVD-VR)
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
What video formats can you play with slv-d360p?
Hi al - your unit can play the following formats:
DVD -R / - RW
DVD +R / +RW
CD -R / -RW
The player can play CD-ROMs/CD-Rs/CD-RWs recorded in the following formats:
- music CD format
- video CD format
- MP3 audio tracks and JPEG image files of format conforming
to ISO 9660 * Level 1/Level 2, or its' extended format, Joliet Kodak Picture CD format.
*(A logical format of files and folders on CD-ROMs defined by ISO)
The player can play DVD-ROMs/DVD*RWs/DVD+Rs/DVD-Rs recorded in the following formats :
- MP3 audio tracks and JPEG image files of format conforming to UDF(Universal Disk Format).
In other words, just about everything. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
May 12, 2008 | Sony SLV-D360P DVD Player/VCR
Problem with original dvd
Before performing any operations, make sure of the following: ? Check the connection with the TV. ? Turn on the TV and select the correct input on the TV to view the pictures or on-screen indications on the TV screen. ? For DVD playback, you can change the Setup menu setting to your preference menu... Alos, make sure thay the system and disc region code numbers are incompatible: The following discs cannot be played back: ? DVD-Audio, DVD-ROM, DVD-RAM, DVD-R, DVD-RW, CD-ROM, CD-I, (CD-I Ready), Photo CD, etc. Playing back these discs will generate noise and damage the speakers. * Note on Region Code DVD players and DVD Video discs have their own Region Code numbers. This system can play back DVD discs recorded with the color system of NTSC and PAL whose Region Code numbers include ?3.?
Dec 15, 2005 | JVC TH-A5 System
Bose 3 2 1 GSX System Logo
853 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
