Kyocera Copystar CS-1620 Black and White Copier
Problem for Kyocera Copystar CS-1620 Black and White Copier
Message stating install MK
By craigl659 on Oct 07, 2009
i have a kyocera FS-3900DN printer which flasshes up a message install Mk, printer still functions correctly, what is MK?
how do i install it?,
Best Solution
posted on Oct 16, 2009
Very Helpful)
Copier_God
Rank: Guru
Rating: 88%, 10 votes
You have done more than 300,000 pages. I wouldnt waste your money on a Maint Kit, just stretch it out by doing the following.
Press Menu/Ok (Main menu)
Go into [>>Service]
Then press the right arrow.
Then find [>> Maintenance]
Press the ok key, then it will show [>> Maintenance?]
Press the ok key twice, and it will reset all the counts on your consumable components (Drum, Developer, Transfer Roller, ETC)
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 12, 2009
Somewhat Helpful)
The Experts
Rank: Wiz
Rating: 81%, 221 votes
MK is tha maintenance kit, when the copier counter pass250k or somtimes 500k depends on the type of the copier, it ask for MK, to renew all the parts.
Was this helpful?
Yes
No
Popular Solutions for Kyocera Copystar CS-1620 Black
Questions and Unsolved Problems for Kyocera Copystar CS-1620 Black
Do you recommend Kyocera Copystar CS-1620 Black and White Copier?
Answer
Answer
While taking test nr 6 I have noticed a colors displacement which sometimes is larger, sometimes is... (More)
Answer
We have an old Konica 2330 copier system that is giving us a code 36-01. We are the Elks, so this... (More)
Answer
check to see if the fuser is working yu should be able to tell if you open the side door up at the... (More)
Answer
I need to unlock my cell phone so I can get service through my curent provider.It use to be hooked... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kyocera Copystar CS-1620 Black...:
Top Copier Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
