Machine does not drain water. Have checked for loose electrical connections and have tried knob in ever position.
  • 136 Answers
Your machine has either quite pumping or you have something pluging the line like a babies tiny sock that happend to one time
Posted on Oct 07, 2009
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
Maytag MGD 9700SQ. When I press start, the sensoring light clicks on and that's it. I've cleaned out the lint, cleaned the sensors with alcohol. Will clean the vent, but it seems like a basic fix....
Hi Jamie: After checking all of this and if it still dont work you will need to put in a new control board.
Plug cord into live electrical outlet. Check for proper voltage.
Check fuse or reset circuit breaker.
Push any key to turn ON the clothes washer and press the Rotary Cycle Selector knob to start the clothes washer.
Close door and push the Rotary Cycle Selector knob to start the clothes washer.
Check to see if the clothes washer is in a pause, soak or suds period in the cycle. Wait briefly and it may start. If washer is in suds period, SU and DS will display alternately, instead of the time remaining.
Check for restricted drain system. If there is an electrical problem in the drain system, ND error will occur after 15 minutes.
Check water supply.
Check the line screen and water valve screen.
Check for loose connections at machine control board terminal connections
Replace machine control board.
In this link, with your model could find parts replacement:
- Maytag-Parts/Dryer-Parts/Model-MGD9700SQ
- partsearch/model.aspx?model_id=5140219
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 06, 2011 | Maytag Washing Machines
I have a siemens washing machine that says f21 what does that mean
Many thanks. For F21 fault everyone was talking about the drain valve but found one answer related to power supply n board this helped. Resetting by turning program switch to 12 o clock then turn to 6 o click then keep spin button pressed n move knob to 7 o clock position. Then release spin n move knob to 12 o clock. This way F21 got resetted.
Aug 31, 2011 | Washing Machines
WASHING MACHINE WONT DRAIN
1. check the drain knob if operational or functional. 2. remove the water and check the drain inside of your washing machine if something block it or dirt, like hair, or other small particles and if positive clean or remove it. 3. check also the filter if has then clean it also. 4.check outlet solenoid valve if has, maybe its defective and this is subject for replacement. 5.check the hose pipe drain if possible plug out to the washing machine, check it if clean or dent.
Feb 13, 2011 | Washing Machines
Machine wont fill with water.i have checked pipes and they are okay.if you turn program knob to the spin cycle it will try to enpty.also you can still open the door
Hi there....looking at the programe selector knob....you should see at three positions on the panel a black dot.....ok.......(1) close the door of the machine and switch on the power....(2) turn the programe knob to any one of the dot positions....(2) push the start button....a red indicator lamp should flash 3times and then remain steady indicating the program has been cancelled....(3) Now select a new wash program and push the start button....machine should operate ok....If not check the drain pump to ensure it is not blocked...or wiring loose ...or burned out....if this is ok...then your most likley looking at a module failure...
regards Sir Galahad
Sep 03, 2009 | Indesit W 123 Front Load Washer
Water leaking from underneath pipe connector to the dishwasher
Check the following:
* Loose or mis-positioned hose clamp at the drain spur connection
* Rotted or brittle hose
* Split hose
* Cracked joint at the drain spur connection or split drain spur fitting
Apr 27, 2009 | General Electric Dishwasher Timer
I installed according to guide, but dishwasher will not fill with water. Pump sounds much too loud to be normal. Wiring was checked three times for correct connections. Water supply was checked twice for...
you state the water supply is on.
Have you loosened the compression nut at the dishwasher ell to see if you have pressure to the water inlet to the dishwasher?
Remember the dishwasher will always run a little to make sure any residual water from the last load is out of the bottom, so you could here the pump run a minute or so with no water coming in.
If you have Pressure to the water inlet and no water coming in regardless of the cycle/ timer position, it is most likely a bad electrical connection or switch at the water pressure actuator which is were the compression drop ell connects to the dishwasher.
This is the one and only actuator to let the water in to the dishwasher.
So it could be one of or combination of five things: no pressure to actuator,the electrical connection the actuator is loose or bad, the actual actuator is bad or timer timer is bad.
Most likely it is a loose electrical connection or lack of pressure to the actuator
Apr 03, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Program knob on GE washing machine not functioning
Older washing machines had a 2 position knob push or pull to set and the other position to run, also if the timer is bad it can be replaced the parts are still available on the Internet.
Have a good day...
Tim
Mar 26, 2009 | General Electric Washing Machine Chrome...
Saeco royal cappuchino ventilate
Alternatively, try draining the machine. Page 37 of the user manual, Drainage. Place cup under the steam/hot water tube, turn knob clockwise around to 9. If the pump is ok, it will start automatically and start filling the cup. Drain about 1/2 cup of hot water and return knob counterclockwise to start position. If the flow meter is not damaged, the Ventilate message should be gone.
Jun 30, 2008 | Saeco Royal Professional Espresso Machine
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
