Question about Kenmore Dishwashers
The door for the detergent will not open. How do
The door for the detergent will not open. How do I disassemble the door to fix this?
  • 31 Answers
Open door. take out all screws (usually torx) remove FRONT panel. you will see the "wax" motor. and that my friend is your problem.
if you actually know how to use a VOM, you will know how to test the motor, if not. call a technician before attempting any repairs yourself. 120volts is no joke.
Posted on Oct 07, 2009
Detergent dispenser doesn't open
There is a solenoid in the detergent dispenser that opens at the appropriate time to let the door open and drop detergent. The solenoid might be faulty if the door spring appears alright. One option is to stop using the powder detergent and switch to tablets. One tablet like Finish diamond in the cutlery basket does wonders.
Not sure if you can buy the dispenser to replace.
Apr 22, 2014 | Indesit Dishwashers
Door of detergent holder on Bosch dishwasher won't shut. It just pops open. Is there an easy fix?
Proceed with this step:
Timer
check the timer, and the linkage see it is defective.
Bi-metal switch or wax motor
test the swithc or the motor for defective.
Detergent cup, itself
can be clogged, for to open.
sincerely. God bless you.
May 07, 2012 | Bosch Dishwashers
Detergent dispenser will not stay shut so the soap power falls out before washing starts. Last time use I opened the door by mistake part way through the cycle. Could this have messed up the latch...
Opening the door did not affect the latch on the dispenser. The catch does wear out and can be replaced. This involves disassembling the door and a small jigsaw puzzle of springs and levers. If you are attempting I would advise taking pictures to refer to before taking apart.
Eric
Jan 11, 2010 | Kenmore Dishwashers
Covered detergent dispenser not opening
The actuator needs replaced. You have to disassemble the door to find the problem.
Eric
Dec 23, 2009 | Dishwashers
Dishwasher Detergent Dispenser not opening
An automatic dishwashermag-glass_10x10.gif detergent dispenser door can become stuck for a few different reasons. Some problems are easy to fix, while some require more work. Repairs are basically the same no matter what brand of automatic dishwasher you have, although specific parts might be required. Fortunately, even if the detergent dispenser needs to be replaced, the problem is not an emergency. The dishwasher will clean dishes fine even with a stuck detergent dispenser.
    Fixing a Stuck Automatic Dishwasher Detergent Dispenser
  1. Step 1 Move the basket that holds silverware as far from the detergent dispenser as possible, or make sure no tall items are blocking the dispenser. Also, keep other items such as plates and pans away from the dispenser. Anything that winds up touching the dispenser during the wash cycle can cause the dispenser door to stay closed. Run the dishwasher to see if this solves the problem.
  2. Step 2 Remove the front door panel according to your instruction manual, or find the manufacturer's instructions online, which will probably be in a PDF file. The panel is typically held on by 6 to 8 screws along the edge, which you can see when the door is open. With most models, you won't need to remove the screws at the bottom of the door, which are part of the hinge assembly.
  3. Step 3 Clean the detergent dispenser thoroughly from the inside of the dishwasher and the exterior side as well. Accumulated detergent and other material can interfere with the spring mechanism or halt the pivot action of the door. Use very hot water and a micro-sized brush. You also can use a mix of hot water and vinegar.
  4. Step 4 Most dispensers have a bimetallic strip or switch, attached by screws, which triggers the door release. With the front door panel removed, locate the switch, and push on it gently with a screwdriver until the dispenser door opens. You might simply need to adjust the alignment of the switch.
  5. Step 5 Purchase a new switch if re-aligning the old one does not fix the problem. Typically, these switches cost under $10. See Resources for a link to different manufacturers where you can buy the part.
  6. Step 6 Label the two wires connected to the switch so you can correctly reconnect them afterward, and then remove them from the terminals by holding the slip-on connectors --- not the wires --- and pulling firmly. Use a pair of needle-nosed pliers for a better grip. Then remove the switch from the dispenser by removing the screws holding it in place. Connect the wires to the terminals of the new switch, and attach the new switch to the detergent dispenser. Replace the door panel.
  7. Step 7 Run the dishwasher again to see if the switch replacement has done the trick. If not, decide whether to replace the entire dispenser according to the manufacturer's instructions, or call a repair technician.
Nov 14, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Bosch 4002 detergent door will not lock shut at start of cycle
You need to open-up the door sections by removing the screws around the perimeter. This is not easy since it takes three hands to hold and disassemble. Please disconnect electric so you do not short any electric parts within the door shell.
The release mechanism may be no good for the soap dispensor tray, or you may find a corroded wire connection to the release. In many cases if the soap tray does not release (but closes) it can be a faulty signal from control panel,however you say the tray will not stay closed; this is most likely a faulty release/latch mechanism which you will see when you open the door shell sections.
Many models have star head screws and will need a star screwdriver (there are 4 or 5 sizes).
Good luck, MACGIVOR
Oct 24, 2009 | Dishwashers
Detergent door does not open, it completes cycle without using the detergent
  1. The most common problem with the detergent doors on KitchenAid dishwashers is that they either don't open during the cycle or open only halfway. Before looking into more complicated repairs, make sure that the door is able to open. Check the seal around the door and the door latch for soap- and food-related gunk, and scrub it off if present. Sometimes this can keep the detergent door from operating properly. Consider switching detergents, as some liquids and pouch-style dish detergents can gum up the detergent dispensers. Also, make sure that there is nothing blocking the detergent door when the dishwashermag-glass_10x10.gif is loaded. Because of the location of the detergent door, a large item such as a cookie sheet or a pan can prevent the door from opening. Run the dishwasher through a cycle without anything placed in front of the detergent dispenser and see if that solves the problem.
  2. Broken Timer
  3. KitchenAid dishwashersmag-glass_10x10.gif rely on an internal timer to complete the wash cycle properly. When this timer malfunctions, certain steps in the wash process (such as the release of soap from the detergent dispenser) can be interrupted. If the dishwasher detergent door is either not opening or appears to be opening late in the cycle, this is likely the mechanical culprit. A broken timer isn't something that's simple to replace without knowledge of dishwasher repair, so it's best to consult a professional if you suspect that this is the problem.
  4. Malfunctioning Door Components
  5. For the detergent door to function properly, all of its mechanical components must be in working order. Older dishwashers' detergent doors rely on a spring-loaded hinge to pop all the way open when the timer gives the signal. If the door doesn't swing all the way open instantly when it's manually released, the spring may need to be replaced for the dispenser to operate properly. If the particular model is newer and does not rely on a spring to open the door, chances are it either uses a wax motor or a bi-metal switch to release the detergent door at the appropriate time. If either of these components is dying, that can mean that the detergent dispenser will not operate properly.
thank you
vijay(vote for me)
Sep 23, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
The detergent dispenser sliding door will not stay closed
it is a very tiny plastic "tooth" that let open automatically the door when the washing program selected reach the opening point, the only good solution I suggest is to add the detergent after the first hot wash (just open the main door and drop it in!)...of course the best is to change this door locker with a new one...good luck!
Nov 17, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Dishwasher detergent door won't release soap
There's an answer at: http://www.partselect.com/dishwasher+cup-wont-open+repair.htm.
Pretty in depth, but not a simple fix.
May 22, 2008 | Maytag PDB3600A Built-in Dishwasher
Removing the detergent dispenser
I have the same problem--mine is about 10 years old. To disassemble, looks like you will need to disassemble the complete door--screws around the inside edge of the door. At that price for a replacement dispenser, I will either try to fix or replace the blue arm, or replace the dishwasher. I don't believe its worth putting that kind of money in an old dishwasher.
Lew
Dec 10, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
Dishwashers Logo
50 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
